Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 700X
Blade 700X Blade 700X Helicopters Information and Help
Old 04-22-2016, 04:34 PM   #1 (permalink)
Default 700 X Complete
Another build for a friend. Went together smoothly. gg Blade.
Off for a test flight hopefully tomorrow then back to the owner it goes.
I've ordered some shims to get the tail gears tight.
ID:	648556   Click image for larger version
ID:	648557   Click image for larger version
Keith - MSH Brain2 Beta Test Team - KST Heli Division Team Pilot
Synergy N606 | Synergy 516S | GAUI NX5 | Protos 380 | T-REX 470LP
FrSky Help Click Here
https://kc3dprint.com - 3D Printing on Demand and Printed RC Helicopter Upgrades
Number is offline        Reply With Quote Quick reply to this message
Old 04-22-2016, 09:42 PM   #2 (permalink)
Default Nice!
Nice, another blade 700. Glad to see it, after a few other 700 models that one is still my favorite, both in building and flying. The mechanics are so clean and simple, and it fly's very connected.
TimBaconHeli is offline        Reply With Quote Quick reply to this message
Old 04-23-2016, 02:31 PM   #3 (permalink)
Blade 700 X Test Flight 3 (4 min 12 sec)
Old 04-25-2016, 10:31 PM   #4 (permalink)
Looked like that motor was pretty hot after landing when you touched it.
Mike680 is offline        Reply With Quote Quick reply to this message
Old 04-25-2016, 10:37 PM   #5 (permalink)
For sure It's a pretty small motor.
Old 04-25-2016, 10:38 PM   #6 (permalink)
It still shouldn't be so hot that you can't touch it for more than a second or two.
Old 04-25-2016, 10:54 PM   #7 (permalink)
Meh, that's pretty much what Scorch-pion motors are like (-:
Old 04-25-2016, 11:45 PM   #8 (permalink)
That's why I won't run them. I don't like hot motors and, IMO, it isn't necessary.
Old 04-26-2016, 07:23 AM   #9 (permalink)
I also don't use Scorpion for the same reason.
KDE or Xnova for me. They run much cooler. Heat won't harm them at all, but it's kind of annoying when you touch them and they burn you
Old 04-26-2016, 08:11 AM   #10 (permalink)
That and Scorpion says you have to oil them frequently like every 10-15 flights. Some people say you don't have to do that, but a lot of others do. Ain't nobody got time for dat.
Old 04-29-2016, 06:32 AM   #11 (permalink)
It's plenty,,, unless you like big power the 700x lightness helps hope you enjoy the cyclic its IMO pretty nice,... Shimm those gears Number you are everyeres man,,, lol
rc enthusiast"
snapcrklpop_g is online now        Reply With Quote Quick reply to this message
Old 04-30-2016, 10:19 PM   #12 (permalink)
Default +1
I agree with the previous post in that the cyclics are tight. I didn't understand that "connected feeling" until I had other 700+ heli's to compare it to. It's a very crisp, yet forgiving and rigid cyclic on the blade 700x. It is, and to date will be until I find better, my favorite heli to flip-roll-3d. I just feel like I'm certain it's going to do what my sticks say, if that makes any sence? I'm sure there are many other good kits out there, but for me, between the kits I've built it's up there. Too bad company b.s. had to come into play and slow, or basically stop, the roll. :/ I know everyone rips on Blade, but in the 700x they built a real contender. And the tail gears, who haven't stripped them on another kit? Just my 2 cents....
Old 05-01-2016, 12:36 AM   #13 (permalink)
Cyclic is pretty slow for me, but that's probably just the BeastX setting. I'm at 150% in travel adjust on my radio. Not my heli, so I'm not going to crank it up in the gyro.
Old 05-01-2016, 12:43 PM   #14 (permalink)
For informational purposes, it's a combination of cyclic response in the menu settings and turning up the center pot. The higher pot #2 is, the more direct control goes to the swash and is untouched by the FBL unit.
Old 05-01-2016, 01:02 PM   #15 (permalink)
Thanks.
I just mean rotation rate, if I do continuous flips it's really quite slow. I would go for a lot faster if it was my heli.
Old 05-08-2016, 08:50 AM   #16 (permalink)
Default Rotation...
I find if I have cyclic response set high, dual rates high and a fair amount of direct servo control via pot 2 the rotation rates get almost out of hand, for me anyways. I've played around with different combinations this spring and as I have it set now, which is far from the fastest I've had it, it flips quite fast and stays very locked in through the flip/flips and or rolls. I can definatly slow it down if I time the collective improperly though, but with good timing it whips right around, and I'm sure the better I get with timing the quicker my flips and rolls will be. Even though the beastx is short on settings, I'm finding that even with the ones that are there it's possible to craft a very different flying and feeling heli in short order, it's just getting the right combination for what feels good for you.
Old 05-25-2016, 11:48 AM   #17 (permalink)
Blade 700 X - Test Flight 5 (3 min 37 sec)
I set cyclic rates in BeastX to "Transmitter", I'm at 135% in my aileron and elevator travel in my radio.
Old 05-26-2016, 11:34 AM   #18 (permalink)
Default Nice.
Blade 700 X - Test Flight 5 - YouTube
Nice flying, very smooth which is my kinda 3d. Occasionally I like the tareq alsaadi insane direction changing etc, but pretty much 90% for the style in your video. And wow, 135%, that's up there, at least it would be for me. I'm flying spektrum and my dr's for 3d are at 105ish cyclic and elevator 20%expo and 100 on the rudder with 0%expo. If I cranked the dr's up that high I'd probably mow the lawn with it......and not the stunt mow the lawn inverted hover style, the drive it in and leave a divit where the wrecked heli is style. Lol
Old 05-27-2016, 12:39 AM   #19 (permalink)
BeastX has always been slow for me. I fly Vbar and my agility is almost always right on 120 in the Vbar (not 120%... it's just the setting number).
