Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600 PRO Class Electric Helicopters
600 PRO Class Electric Helicopters 600 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 09-29-2016, 03:07 AM   #1 (permalink)
Default 600l front tt stripping gears
Hi all, I'm looking to buy the 600L Dominator but been put off by reading about the front tt gears stripping. Does this still happen or did align make the gears stronger?
GlideslopeRC is online now        Reply With Quote Quick reply to this message
Old 09-29-2016, 09:57 AM   #2 (permalink)
Nothing changed on the gears unfortunately. With that said, if you use shims to tighten the gear mesh on the umbrella gears, use some grease and watch your tail and governor gains, you increase the lifetime of those gears by a lot. The lifetime of the gears also depends heavily on your flight style, sport 3D and cruising around is just fine, it's on hard 3D and very aggressive pulls that the gears take a beating.
Andreas (formerly known as anmatheextreme)
Compass 7HVU
Logo 600SX CF
Blade 450X
Heli.Maniac is offline        Reply With Quote Quick reply to this message
Old 09-29-2016, 10:46 AM   #3 (permalink)
im not hard 3D flyer so I should be ok then? I'm still unsure might get a 550l instead!
Old 09-29-2016, 10:48 AM   #4 (permalink)
You'll be fine with them in 95% of flying styles. It's when you crank the gain too high and do lots of piro reversals that causes issues. Shim the gears properly (buy some 0.1 and 0.2mm shims) and they're solid.
Both are good machines. The 550L is a bit smaller. The 600L has much more power and a bigger presence in the air, but crashes will cost significantly more.
You also need more expensive packs for the 600 (2 x 3000mAh 6s vs 1 x 5000mAh 6s)
CLACKCLACKCLACKCLACK
LOGO 480 XXtreme
FrSky Horus X10S
Keith
Number is offline        Reply With Quote Quick reply to this message
Old 09-29-2016, 10:55 AM   #5 (permalink)
I think I will go for the 600l then. I already have lots of 6s 3500 packs from my fixed wing aircraft so the lipid suit the 600 More. I will get some shims for the build then too!
Old 09-29-2016, 12:08 PM   #6 (permalink)
I've got the 600 Pro with the upgraded motor, so mechanically identical to the 600L. I stripped those gears on mine early on but I've now had two years of flying without any issue on one single set of gears (and I'm running 105mm tail blades which increases the load on the gears).
I did the shimming mod to tighten the mesh but i think that maybe the biggest issue is that the governor on the Castle ESC is brutal, the gain needs to be set really low to avoid shocking the drivetrain. I understand that the very latest 600L comes with the Align/HW 130A ESC which should avoid the problem.
Gob 700 Speed | Gob 770 Comp | Gob 630 Comp | Trex 700X | KDS Agile 7.2 | Compass 7HV U | Trex 600Pro (626 stretch) | Kasama Dune 600 | KDS Chase 360 | Devil 420 | XLPower 520
Grumpy_Old_Man is offline        Reply With Quote Quick reply to this message
Old 10-03-2016, 02:13 AM   #7 (permalink)
Yeap agree re gov. I currently have mine set around 11-12. Curious how low others are going.
Goblin 380 KSE - MSH Brain2 / HW60A V4
Trex 500l Dominator- MSH Brain / HW100A Pro V3
Trex 600l dominator- MSH Brain / CC Edge 80HV
Synergy E7se - MSH Brain / CC Edge 120HV
nabl74 is offline        Reply With Quote Quick reply to this message
Old 10-03-2016, 03:23 AM   #8 (permalink)
I think I was at 12 with the 750mx and Castle ICE2 80HV
Compass 7HVU
Logo 600SX CF
Blade 450X
Old 10-03-2016, 04:20 AM   #9 (permalink)
A gov gain of 18 blew by TT gears, I dropped it to 12 and all was ok. You can hear it when it's too high, it makes a sort of 'chirping' sound under hard collective input, it's quite subtle but once you know what to listen for it's not hard to detect.
I've since tried a YGE ESC and a Hobbywing and had no problems on default settings, so it does seem to be a combination of quite fragile gears and a ESC with a brutal governor.
Old 10-20-2016, 11:45 AM   #10 (permalink)
shims help but its easy to tear out some gears with a high gain gov setup
i'm still flying my steal gears with no issues been 2 or 3 years
should have bought a few extra sets since you cant get them anymore
4 x Rush 750/stretched V-bar KDE 700XF-495 HV servos Greys reactor CC 160-HV
Trex 600EFL V2 V-Bar ds610 ds650 CC bec/pro Scorpion 130a HV KDE 600XF-530
450L KDE 1750 cc50 4xDS215MG k-bar
X-8 FPV Wing, TBS Discovery FPV, TBS Caipirinha FPV
satgod is offline        Reply With Quote Quick reply to this message
Old 10-23-2016, 08:56 PM   #11 (permalink)
+1 to shimming and 12 gov gain setting. I think i followed your lead on this originally....
Been good to me for 12months so far
Sent from my SM-G928I using Tapatalk
