Like Tree4Likes
Old 10-13-2016, 07:14 PM   #1 (permalink)
Default New Align 250X
Heard of rumours of Align bringing out a 250X swinging 250mm blades?
Could this be true? Would you buy one?
Old 10-13-2016, 07:56 PM   #2 (permalink)
Might be interesting if there make some other changes like the tail.
yakky is online now        Reply With Quote Quick reply to this message
Old 10-13-2016, 07:57 PM   #3 (permalink)
Hmmmm, interesting. I have my mind set on an Oxy2, but I'd love to know more about a new Align 250X.
I'm stoked to see this size-class is continuing to be being developed.
navigator2011
Oxy2 190 FE / Oxy2 190 Sport / Fusion 180 / Blade 150S / Trex 150X / Blade mCPX BL2 / Spektrum DX9.
navigator2011 is online now        Reply With Quote Quick reply to this message
Old 10-13-2016, 08:48 PM   #4 (permalink)
It would be cool if this turns out to be true I wondered if they would release a 250X recently and I see I am not alone
I just hope it can use the same battery I have a few now and like the fact that I use them on my 230s as well as my Align Trex 250's
I guess we wait
C
Blade 230S, Nano cpx, nano qx/3dqx/fpv, 200qx MCPX V2, Align Trex 250, 250 DFCplus, Trex 450 plus,Trex 500, JR Forza 450, and more I retired
Cman is online now        Reply With Quote Quick reply to this message
Old 10-14-2016, 04:21 AM   #5 (permalink)
A true 250 size T-Rex250X would be nice but I donít see it somehow, the new T-Rex250 I saw was just servo changes and nothing else.
A new 250 with just new servoís will not have people upgrading, at most people may buy the new servoís as replacement for broken / worn-out ones.
T-Rex 550E V2 Spartan VX1n, T-Rex 250 PRO DFC Spartan VX1n, Blade 130X. Futaba T8FG Super
Toocool4 is offline        Reply With Quote Quick reply to this message
Old 10-14-2016, 06:53 AM   #6 (permalink)
if there going to change anything. FIX THE BLOODY HEAD GEOMETRY.
even with the dfc head, its bad. havnt tried the dfc swash yet (which hassmaller distance fromm centre ball but not by muhc)but cant see it improving things much.
12 degrees pitch with kbar at 60!
Old 10-14-2016, 06:57 AM   #7 (permalink)
With which servo horns and hole distance?
Allan
TREX 250 PRO,Talon15, GPRO, Zeal ----TREX 500 EFL PRO, GPRO, RAILS ----2x TREX 450PRO V2, 1xGPRO&1xBRAIN, Talon35, RAIL , Zeal ---- SAVOX powered TREX500 EFL in Roban scale UH1-N ---- TREX 600 EFL PRO, GPRO, RAILS ---- DX9 ----
TR450ZS is offline        Reply With Quote Quick reply to this message
Old 10-14-2016, 07:32 AM   #8 (permalink)
How can you complain about Align, when you donít even own an Align helicopter?
Old 10-14-2016, 08:50 AM   #9 (permalink)
I dunno, he's got a lot of align parts on it.
Old 10-14-2016, 09:53 AM   #10 (permalink)
Align carbon fibre 205D blades
Align DFC head
Align DFC Mainshaft
align feathering shaft
Align tail belt pulley
Align tail belt case
Align carbon fibre boom
Align complete tail unit including blade grips and hub
Align main gear and one way bearing
Align plastic anti rotation bracket.
Align bottom frame plate
Align landing skids
Copterx Frame
Copterx battery mount
Old 10-14-2016, 06:34 PM   #11 (permalink)
Okay so you have bought a Lada and replaced a lot of the parts with Volkswagen parts, now you expect it to perform like a Volkswagen even though all these parts are hanging off a Lada chassis, good luck.
Old 10-14-2016, 06:45 PM   #12 (permalink)
A Lada? Got to admit it, I had to look that one up.
navigator2011
Old 10-15-2016, 06:45 AM   #13 (permalink)
will the align frame fix the head geometry?
Old 10-15-2016, 06:48 AM   #14 (permalink)
I have a 250 T-rex Pro. What is the issue with the head geometry? I have it apart for repairs at this time. Anything to look for on the rebuild?
Micros: Hisky HCP80, ESKY 150x,K110, Trex-150X x 2 Mid: Oxy 3 T New Version, Oxy 4 360 Big: Trex-500X, Oxy 5, Trex-550X, Trex-700X Scale: MD500 TOW Defender (Trex 500 size) Vintage: Trex 450 SE V2
ic-racer is offline        Reply With Quote Quick reply to this message
Old 10-15-2016, 06:48 AM   #15 (permalink)
Well you donít see many around these days, well maybe in Russia
Old 10-15-2016, 06:52 AM   #16 (permalink)
I really donít know, but best advice is start again with the real thing.
You have spent enough time and money now to get the real thing, well if you enjoy tinkering rather than flying then you can keep trying till you get it flying good luck.
Old 10-15-2016, 11:19 AM   #17 (permalink)
It's not that the frame will fix anything, it's just that starting with the real thing is so much less trouble and expenditure. I've done things both ways, and I can promise you that starting with Align right from the start is much better on both counts. I spent a ton of money and struggled for a long time to get my CopterX/Align hybrid 250 to fly correctly.
With that said, however, you can get things to work with the frame you already have. You just have to follow all the known rules for setting up the head, swash, links, servos, rx, etc.
navigator2011
Old 10-15-2016, 06:26 PM   #18 (permalink)
Thats the point im trying ti make. The frsme has heehaw to do with aligns poor head geometry and i want to know if they are ever going to fix it.
The problem is that even with the servo to swash links on the 2nd servo horn hole (10mm instead of 12) the controm loops are just on the edge of being i. The optimum range.
There are stacks of posts of people struggling to get into the recomenfed rsnge of there fbl (vbasr beastx. Zyx just to name a few)
These are posts from slign users not copterx.
If align are adressing this aswrll as there sloppy tail. Ill buy it.
While copterx isnt of best quslity. My poor choice of servos hsve caused the biggest ptoblems.
The heli will still fly with things not bei g i. Thr bst range id just rsthet have more resolution
Old 10-15-2016, 07:19 PM   #19 (permalink)
That is just crap, if you look at my pic below you will see I am using hole 4 on the servo horn and everything aligns perfectly to give me the correct FBL range.
Old 10-16-2016, 12:54 AM   #20 (permalink)
Yeah, my 250s are just fine, so I don't know about this servo hole issue. What I do know is that with all the Align parts you now have, you should be able to set up and fly your 250 even though the frame is still CopterX.
navigator2011
