Go Back   HeliFreak > Multi Rotor Support > Open Source Flight Controllers (CC3D, Ardupilot, etc.)
Open Source Flight Controllers (CC3D, Ardupilot, etc.) Open Source Flight Controllers (CC3D, Ardupilot, etc.)
Old 02-07-2016, 07:35 PM   #41 (permalink)
Walex, that's perfect. All works now. Thank you for the info
Still Crashing, Still Learning
6HV-U, Logo550 & Protos all vbar
Bee_random is offline        Reply With Quote Quick reply to this message
Old 04-10-2016, 02:33 PM   #42 (permalink)
Hi guys
I have a issue
I just got a spektrum spm4648
I can´t get it to bind whit my DX9 BE
Power on the quad sat flash es, put the dx9 in bind mode and then the sat stop flashing and 3 sec later the dx9 says bind failed ??
Do any of you have any ideers ??
Søren Lohse
Denmark
Soffer is offline        Reply With Quote Quick reply to this message
Old 06-21-2016, 06:05 PM   #43 (permalink)
Default Spektrum ar7700 on a Flip32
I was wandering if anyone has used the AR7700 with a Flip32 set to SRXL yet? I can't find any info anywhere on how to make the connections to the flip32 board. Do I treat the whole setup as if it were a satellite receiver? should I use REMOTE RX or SRXL? If I make my connections as if it were a satellite receiver and connecting to REMOTE RX I'm sure I can get it to work, but will i be loosing my opportunity to get 11ms latency?
A BIG thank you to anyone that can help with this setup.
ncantny1978 is offline        Reply With Quote Quick reply to this message
Old 06-22-2016, 06:48 AM   #44 (permalink)
The AR7700 is not capable of PPM/CPPM/SBUS/Serial output. You have to wire it as a PWM receiver with a wire going from each channel into the board.
Cpl Woody is offline        Reply With Quote Quick reply to this message
Old 09-05-2016, 05:28 AM   #45 (permalink)
Hi guys, nice thread! Thanx a lot for it!!!
Im just waiting till my Naze32 SP F3 Deluxe 10DOF will be delivered to me, and in meanwhile Im looking for a guide how to connect it with teh DSMX Remote Satellite Receiver SPM9645.
Here's the Naze32 pinout:
Is it correct to connect the sat to the IO1 header to pins 1(GND),3(PPM),8(3.3V)?
//edit: or should I use IO2 header pin4(TX) instead of IO1 pin3? Will be there faster response?
Thank you in advance
djsmeegy is offline        Reply With Quote Quick reply to this message
Old 09-05-2016, 10:20 AM   #46 (permalink)
To connect a Spektrum Sat to that board you will take 3.3 from the 3v pad, the ground can go in any ground, and the signal will go to the UART 3 in the RX pad. Then you will turn on UART 3 as a serial receiver in your software and ensure the satellite is bound to the remote.
Old 09-07-2016, 02:31 AM   #47 (permalink)
Thank you. Will test with UART 3
Old 10-04-2016, 09:10 PM   #48 (permalink)
Ive connected a sat rec to the uart 3 ports and the 3.3 wire to the 3.3 pad. I bound the receiver using cleanflight but now every time I plug in a lipo the rec enters bind. Ive tried to set spektrum_sat_bind = 0 but same result. Can anyone help?
Thanks!
Goblin 700c, SK-720 & GPS / Goblin 380, SK-720 & GPS / Blade 130X / Blade 180CFX / ZMR250, CC3D
JoeRuscito is offline        Reply With Quote Quick reply to this message
Old 10-06-2016, 08:19 AM   #49 (permalink)
Depending on the version you are using you may have to set the reset back to 0.
set spektrum_sat_bind_autoreset = 1
and if that doesnt work set it to 0. thats just the command I pulled of my latest flyer.
Old 10-07-2016, 07:01 PM   #50 (permalink)
I have the most up to date sp racing f3 firmware. That command doesn't seem to work but I did use set spektrum_sat_bind = 1 (and = 0) but still the same results.
Old 11-10-2016, 01:32 PM   #51 (permalink)
I am the same. I am trying to use a spektrum sat with naze 32 and cleanflight. I have tried all of the above but I just can't get the sat to light up with a flashing orange light when I power up.
I have pressed save every time.
In the gui when I set it for serial rx and save the command is unchecked when I go into it again.
The CLI commands just don't seem to do anything.
sandersnn2 is offline        Reply With Quote Quick reply to this message
Old 11-10-2016, 06:39 PM   #52 (permalink)
set spektrum_sat_bind=9 is for dsmx
set spektrum_sat_bind=6 is for dsm2
Old 11-22-2016, 05:05 AM   #53 (permalink)
I facing the same problem.
I think it not a satellite problem because I try this on another FC (SP Racing F3) it work correctly.
anyone found and solve this problem?
pls help.
Originally Posted by felborn View Post
This thing is really doing my head in. Been working on it all night, no luck. I can get my DX18 to bind to RX, a DSMX orignal receiver okay. I can see the orange light turn on and of when I turn my radio on and off, but the receiver sees no signal in Cleanflight.
Soldered the signal pin to port4, checked the soldering and everything seems fine. One thing I notice it that it keeps binding to DMSX and 22ms framerate no matter how much I try to say 11ms frame. Could that be my problem?
How on earth can I get my DX18 to bind to 11ms?
ikung is offline        Reply With Quote Quick reply to this message
Old 11-22-2016, 07:59 AM   #54 (permalink)
pls help.
Once you bind it you have to set it up in clean/base/betaflight. on the configuration tab you have to select serialrx and spektrum 2048. hit save and check the receiver tab.
Old 11-22-2016, 08:01 AM   #55 (permalink)
I finally found there must be an issue with the 3.3 v pad on the board. I wired my sat directly to a 5 v pad ( I know its too high voltage) but it works perfect now. Maybe try a isolated 3.3 v step down?
