Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600 PRO Class Electric Helicopters
600 PRO Class Electric Helicopters 600 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 11-12-2016, 06:14 AM   #21 (permalink)
Originally Posted by TR450ZS View Post
Is the nitro auto gear and front TT gear mod a direct drop in or do you need to slot the frame holes?
Slot the frame holes. A little round file does the trick. You can do it the KDE way, they send a drill bit and a c&c bling piece for the outside of the frame.
I prefer to use the file, it is much easier to control and washers on the outside painted flat black. Once the gear mesh is set, it will fly sweet. I fly my stretched ones at 17&1900 rpm on the head.
I didn't crash. I just ran out of airspeed, altitude, and idea's all at the same time.
cobieg is offline        Reply With Quote Quick reply to this message
Old 11-12-2016, 06:30 AM   #22 (permalink)
Ok thanks cobieg.
Allan
TREX 250 PRO,Talon15, GPRO, Zeal ----TREX 500 EFL PRO, GPRO, RAILS ----2x TREX 450PRO V2, 1xGPRO&1xBRAIN, Talon35, RAIL , Zeal ---- SAVOX powered TREX500 EFL in Roban scale UH1-N ---- TREX 600 EFL PRO, GPRO, RAILS ---- DX9 ----
TR450ZS is offline        Reply With Quote Quick reply to this message
Old 11-12-2016, 07:25 AM   #23 (permalink)
Or if you are doing a stretch anyway just allow for larger tail blades. 105mm blades make a huge difference.
Old 11-12-2016, 09:50 AM   #24 (permalink)
4.5:1. Not sure if you need to slot the frame or not.
http://www.aligntrexstore.com/M06-To...AX_p_4648.html
"must with H60020AA":
http://www.aligntrexstore.com/180T-M...A-_p_2584.html
Keith - FrSky | OMP | KST | KC3D
Protos 800X Evo | OMP: M7, M4 MAX | M4*2 | M2 EVO*2 | M1 EVO | So Many Airplanes
KC3D LLC - Charge Cases, Starter Adapters, Heli Upgrades, and More
Number is online now        Reply With Quote Quick reply to this message
Old 11-12-2016, 01:39 PM   #25 (permalink)
To get the correct gear lash, yes.
Old 11-12-2016, 01:46 PM   #26 (permalink)
Yeah, that works too. I ran 105's on it when it was a stock 600. The tail blades would take out front tt gears from the grass cutting. I went with the Auto gear mod and 95mm tails, no more blow out or stripped gears.
Old 11-12-2016, 02:48 PM   #27 (permalink)
The solution to the 105s and ground clearance is to get the 700E skid (the stock one is the F3C version) and replace the stock rear one only. That will raise the tail quite a bit and prevent some of the gear stripping when landing.
Andreas M.
Compass 7HVU
Logo 600SX V2
Blade 450X
Heli.Maniac is offline        Reply With Quote Quick reply to this message
Old 11-12-2016, 03:03 PM   #28 (permalink)
Or buy this set....
http://shop.align.com.tw/product_inf...oducts_id=5824
Lots of Spirits + Jeti....TT Raptor's E820 x 2....E760......E700.....Synergy E7SE....Soxos Strike 7 + 7.1...Align 600 Pro...
Island Heli is offline        Reply With Quote Quick reply to this message
Old 11-12-2016, 03:09 PM   #29 (permalink)
I actually put the old style nitro skids on mine. I re-enforced the back side with 1/8" piano wire. It stands up off the ground good and has some spring on not so smooth landings.
Old 11-12-2016, 03:19 PM   #30 (permalink)
Originally Posted by Island Heli View Post
Yup, love them on my 700n
Old 11-12-2016, 07:06 PM   #31 (permalink)
Niiiiice!
Old 11-23-2016, 11:04 AM   #32 (permalink)
Getting back on topic> Has anyone used the Red 34t front gears on the 600EFL and if so how are they holding up?
Mikado 550SEV-2 w/Brain2, and XL Power 380 w/ Mini Brain2 controlled by Futaba 18SZH
BigEddie is offline        Reply With Quote Quick reply to this message
Old 04-15-2017, 08:05 AM   #33 (permalink)
Stripped after 6 flights.
Now I convert with belt.
I hope it will be better !!
Inviato dal mio iPhone utilizzando Tapatalk
aisella is offline        Reply With Quote Quick reply to this message
Old 04-15-2017, 08:26 AM   #34 (permalink)
Is that grease in the gears? I thought we're not supposed to use grease and those gears
Sent from my SM-G935T using Tapatalk
S7STEM_HACK is offline        Reply With Quote Quick reply to this message
Old 04-15-2017, 11:59 AM   #35 (permalink)
No, no grease.
It's teflon , made for gear lubrication.
Old 04-15-2017, 04:26 PM   #36 (permalink)
But I thought the gears were self lubricating. Adding more may cause slippage, hence the stripping. Please correct me if I am wrong.
Old 04-15-2017, 04:58 PM   #37 (permalink)
Delrin (aka POM) is self lubricated. In some cases adding more can do more harm than good. It's not necessary.
Old 04-15-2017, 05:56 PM   #38 (permalink)
What are you using for a gov.? How tight was the mesh on those?
Old 04-16-2017, 12:09 AM   #39 (permalink)
Skookum governor. The mesh perfect.
Old 04-16-2017, 04:29 AM   #40 (permalink)
Since i started using Drylube gear, in am seeing a lot less wear on the gears.
But setting the least amount of backlash in the bevel gears is more important
Sirolf is offline        Reply With Quote Quick reply to this message
