UniSense - E and 14SG / R7008SB - HeliFreak
Go Back   HeliFreak > R/C Electronics Support > Futaba Radios and Electronics > 2.4G Futaba Radios
2.4G Futaba Radios Futaba 2.4G Radio Help and support forum
Old 01-30-2017, 05:08 PM   #1 (permalink)
Default UniSense - E and 14SG / R7008SB
Hello Fellow Members,
Anyone have success with setup of SM Modell Bau UniSense-E telemetry sensor and 14SG with R7008SB? I think I followed the setup and wiring correctly, but am not receiving any data on the S.Bus-2 Telemetry
I've setup my UniSense with the OEM software (UniSense-E Tool 1.0.7) and updated my device to the current FW revision of 1.11
I've also set the sensor for "fixed serial number" per the manual
in the revision notes: "5. new option "fixed serial number" sends the serial number 12345 via telemetry at Jeti and Futaba -> so that sensors can be interchanged and may not need to be programmed again"
UniSense Telemetry Link Connector & Cable is plugged into the R7008SB S.Bus-2 Port
Questions:
1) Do I still need to register the sensor using the Futaba procedure with the S.Bus-2 programming S-I/F (sensor interface) port? I've "registered" each sensor with the "12345" code in the Telemetry setup menu already.
2) According to the manual I don't need to terminate the second "link" signal wire... this is used to trigger Min, Actual and Max readings... leave open if not used?
Thanks!
Citizen 358
Synergy E5 / HW100v3HV / Brain
Mikado Logo 600 / HW100v3HV / Brain
KC8CYF is offline        Reply With Quote Quick reply to this message
Old 01-30-2017, 05:11 PM   #2 (permalink)
See my questions in the 2.4Ghz sub forum
Looking from help from any experienced users of the UniSense telemetry device.
Thanks!
Citizen 358
Old 01-30-2017, 06:47 PM   #3 (permalink)
Default Problem Solved
Case closed
You must register the sensor using the Futaba S-I/F port on the back of the radio even when selecting the "fixed serial number" option in the UniSense software.
Sensors are working now. Altimeter, Vario, Temperature, RPM, Voltage, Current and most importantly mAh consumed!
UniSense Rocks!
Citizen 358
Old 01-30-2017, 06:47 PM   #4 (permalink)
Case closed
UniSense Rocks!
Citizen 358
Old 01-30-2017, 07:57 PM   #5 (permalink)
Please do not cross post.
Merged.
Thanks in advance,
Mike
TowPilot is offline        Reply With Quote Quick reply to this message
