xk k110 Replacement Boom/Motor - Page 3 - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters > V977/K110/K120
Old 02-23-2017, 11:49 AM   #41 (permalink)
Was keeping an eye on Bangood and they were supposed to get a restock this week, so was waiting as was thinking (hoping) it would be a corrected stock. But looks like that got bumped to March 1st now.
Anyone having any luck getting the right part from any place else?
RyanRC700 is offline        Reply With Quote Quick reply to this message
Old 03-17-2017, 07:28 AM   #42 (permalink)
Hello all
Just thought I would post a update.
I saw that the boom assemblies had come back into stock at Bang-Good, so I took the chance and ordered 3 of them and they just came in yesterday.
Via the great info here, I was able to check them over and it looks like they are the correct ones and much like the ones that were getting sold before this issue.
The shaft seems to be a 1.00mm, the motor circumference is 7.00mm, and the length of it is a little hard to tell as its all encased (an am not taking it part) but it measures 21.68, which is just about what the factory one that came with my 110 measures.
Also for the bag, all it has on its sticker for the SKU is just the SKU261779 number and other then the K110.008 PN and some Asian letters and the bar code, it reads nothing else. Also are no numbers or stickers on the cardboard part of the bag either.
So it just my order I know, but looks to me like they may have gotten the issue of a wrongly packed part corrected.
Old 03-18-2017, 08:58 AM   #43 (permalink)
Interesting thread. I ordered a tail assembly through banggood a few weeks ago. I can confirm it is correct. I realized that the tail assembly I have had on there is as discussed - incorrect with a smaller motor and shaft.
natedg200202 is offline        Reply With Quote Quick reply to this message
Old 03-28-2017, 07:26 PM   #44 (permalink)
Yes I just received mine - same bag/markings as yours and it's the right size. So looks like problem solved!
DX8G2, mSR, mCPx V2, 130x, xk k110, 450x, JR Forza 450, Gaui X5 Formula, Align TREX 500X (build in progress). MAAC Member since April 2015
ACITceva is offline        Reply With Quote Quick reply to this message
Old 04-03-2017, 09:05 PM   #45 (permalink)
When I ordered the boom I also bought a package of tail rotor blades... I just discovered that they won't fit on the motor shaft. Nice.
Old 04-04-2017, 01:23 AM   #46 (permalink)
Originally Posted by ACITceva View Post
When I ordered the book I also bought a package of tail rotor blades... I just discovered that they won't fit on the motor shaft. Nice.
The ones that do fit (at least mine) after a while get loose. I have had to use a heat to carefully "adjust" the hole smaller. It's probably from impacts where they don't break ? Brand new they and the K120 ones work fine but still aren't as tight as I'd like. I really don't want to use glue.
Old 04-06-2017, 06:09 AM   #47 (permalink)
When I got my tail unit I got a set of tail blades and they didn't fit either. Basically on the first try of a insall I couldn't evne get one on without damaging it.
Not that this may be all the answers, but after I did a lot of research and the blades that are the correct part number even in the OM all seem to be described as for both the 100 and the 110.
Which is odd as the 100 has a smaller shaft.
In looking at the ones I got under that number frm BG and the spare one I never used that came with the helo, its clear to see the ones I got from BG are smaller.
In the end there could be a lot I suppose that could be talked about it, but since I couldn't seem to find ones listed for just the 110 I just decided to use a .96 drill from my Pin Vise drill set, and opened it up.
Also should mention and I don't know if others have gotten these in XK bags, but the ones I got from BG were not in XK bags.
Anyway, I have been told that the 120 is the same 1.0 shaft size and are a little bigger and stronger and so are supposed to be better, so I currently have those on order, but in the mean time I have just been drilling out the ones I got from BG if I need one.
Old 04-06-2017, 09:16 AM   #48 (permalink)
I've been very happy with the performance of the K120 tail blades. You do not need to drill them out. I bought the v977 spares kit and had to use a 1mm drill for the tail blades that were in that kit.
P Max v2, G570, G500 speed, Oxy 3+, P380, XK K110, Open-TX
JWeber is offline        Reply With Quote Quick reply to this message
Old 04-09-2017, 12:49 PM   #49 (permalink)
I didn't have a drill but I was able to use a pin and dig out the whole enough to get it onto the motor shaft... only to find out that the motor doesn't work anyway.
I'm done with this thing. I've wasted way, way too much of my life trying to accomplish what should be an incredibly simple and straight forward task.
On the bright side though - the transmitter that came with it has worked exceptionally well as a PC simulator transmitter (Heli-X).
(I realized after writing this that I sound somewhat bitter and angry but mostly I'm just frustrated and venting. Not trying to rain on the parade of those of those who really do enjoy this helicopter. Keep enjoying it! Not everything in this hobby is going to be to everybody's liking equally. I get that)
