Go Back   HeliFreak > R/C Helicopter Support > Scale Helicopters > Heads and Rotor Blades
Heads and Rotor Blades Heads and Rotor Blades Discussion
Old 02-16-2017, 08:45 AM   #1 (permalink)
Default Scale Blades for 500 Huey?
I am working on a 500 Sized UH-1C Build, and have been wondering if there is a way to get the best of both worlds for a scale set of blades. I want to get that distinctive wide-cord flat tipped look of the Huey blades and scale rotation direction. A month ago, I pulled the trigger on these: https://derblattschmied.com/epages/5...T-GS-435/43%22. The blade profile was listed as S-profile, which I foolishly assumed to be short for symmetrical profile.Now that I have them, I realized that they are asymmetrical and only good for a non- scale rotation direction. Is there something out there where I can get both scale profile and direction? Maybe some way to safely cut down a 600 size blade to get the wide chord and square tip?
EnstromPilot is offline        Reply With Quote Quick reply to this message
Old 02-17-2017, 12:52 AM   #2 (permalink)
HF Scale Support
There are very few places that make square tipped blades in any size and I know what you mean by finding out a set of blades just doesn't fit the bill you want them to. I have never been disappointed by Rotor Tech blades and you will find them available in a couple of styles for the 500 size helicopters.
If the Rotor Tech blades are still not what you are after, you might try to see if Midland Helicopter in England can order a set from NHP. NHP does make a 500mm symmetrical blade that has a flat, square end. The product line is called Razor Pro Blades.They do make a 480mm set but that seems to be for a tri-blade heli like the Goblin. Good luck.
Old 02-17-2017, 10:58 AM   #3 (permalink)
Thanks Keyrigger! The 500mm Blade looks like almost exactly what I am looking for, but I'm not sure I could swing that on a 500, and I'll have to check the MR/TR clearance with a longer blade. I have a 1200kv Savox motor sitting around that I could drop in to bring down the headspeed, but I'm not sure that would be enough, maybe go to a lower tooth pinion as well. Otherwise, I might try using the Heli Tec blades, and see how it works out, just not fond of the non scale rotation. I did look up RotorTech blades as well, but only found one style available, with a 45 degree tip cut. Really wish there were a few more scale manufacturers out there at the 500 size for this kind of stuff.
Old 02-20-2017, 12:23 PM   #4 (permalink)
Default UH-1 Huey 500 size
This is my setup on my Huey:
TREX500DFC
SAVOX BSM3750 1200KV AT 1650RPM
CASTLE CREATIONS EDGE 75A
NAZA H - ATTI MODE
SPINBLADES 525MM BLACKBELT MAIN BLADES 85MM TAIL BLADES
STOCK ALIGN SERVOS
CHINAHOBBYLINE LIPO 6S 3300MAH
A123 LIFE 2500MAH FOR RECEIVER
The Huey has the raised tail which extends the length of your main blades.
TACO88 is offline        Reply With Quote Quick reply to this message
Old 02-20-2017, 12:51 PM   #5 (permalink)
Thanks for the info Taco88! I have that same motor in my spare parts bin, so I'll out it to use in the Huey. Went ahead and pulled the trigger on 2 sets of the NHP blades.
Old 03-15-2017, 08:56 AM   #6 (permalink)
Well, just received the NHP blades, and they are not quite what I expected. The blade chord is huge, to the point of looking ridiculous, even on a Huey. So, back to square one.. I did find these though: http://www.modeltec.ch/de/product?info=1864. Perfect shaped, left hand 500 sized Huey blades. But they are metal, so AMA would be an issue.. . Seriously tempted to buy them anyway though, who knew trying to find a blade with a flat tip would be such a pain!
Old 03-15-2017, 12:44 PM   #7 (permalink)
Due to the basic shape I'm going to try to make my own set. I've been following your thread in hopes of a good looking set coming along. I have a set of asymmetrical 600mm I'm going to model from and make them from fg. Should be a fun first spool.
Bm421 is offline        Reply With Quote Quick reply to this message
Old 03-15-2017, 01:20 PM   #8 (permalink)
That really does sound like the way to go at this point. I have thought about getting the same blade set, cutting off the blade grip portion, and wrapping some FG around the other end and using it as the mount to get correct rotation direction out of it. Please let me know how your custom blades turn out, I would be interested in a pair if they work out..
Old 03-15-2017, 06:48 PM   #9 (permalink)
Will do.
Old 03-16-2017, 03:37 PM   #10 (permalink)
Spinblades has very nice, high quality asymmetrical blades. I have had great results in my experience with them
They also have the narrowest chord I could find at 39mm for the 600mm sets. https://spinblades.com/Matt-Black-Scale-5-blade-600
For my 700 scale effort, like you, I wanted the square tip look and a more accurate length which is about 650mm. I asked around about cutting down some 700mm blades and had mixed opinions. After weighing the pros and cons I took the leap and cut them down.
The trick was getting them exactly the same length. I cut each blade with about 1-2mm extra from the target line then I made a rig to hold all the blades together and used a disc sander to take them down to the final length. Perfect.
Then used 3 layers of thin paper towel saturated with CA to seal the ends - light weight and sandable once dried then and a little black paint.
After many flights they are still holding up great . No signs of compromise.
1:5 BK-117 - 1:4 MD500E - 700 MD500E - 700 B222
- TREX 600ESP
Trooper7 is online now        Reply With Quote Quick reply to this message
Old 04-17-2017, 09:28 AM   #11 (permalink)
And just over a month later, I saw this. Fantastic work Trooper7! That is exactly what I would love to try. The spin blades are great, but they don't come if left hand rotation at 500 size. I wonder if this could safely be done to some 3D 600 size blades? That would probably give the wide chord, flat-tipped look that I am after..
Old 04-21-2017, 07:19 PM   #12 (permalink)
600 size blades are most likely too thick for your 500 blade grips.
getsuyoubi is online now        Reply With Quote Quick reply to this message
Old 04-22-2017, 08:50 PM   #13 (permalink)
How about 550 blades?
Old 04-23-2017, 04:46 AM   #14 (permalink)
You don't want something like these ?
https://derblattschmied.com/epages/5...T-WS-470/43%22 - 470mm x 43mm
or if you can fit another 30mm, these;
https://derblattschmied.com/epages/5...HT-G-500/43%22
Unfortunately the next size up is 515mm, with 53mm chord and 12mm root, so they probably wouldn't fit in 500 size blade grips.
https://derblattschmied.com/epages/5...HT-G-515/53%22
I run Spin asymmetrical 465mm x 51mm on my recently deceased UH-1N at 1700rpm, and it flies well with plenty of lift - they do have rounded tips though. From memory there was plenty of space between main and tail blades with 465mm, so longer blades could probably be OK.
Colin
Vario Long Ranger 700e
Seahawk 600
UH-1N 500
Baumann EC-145 800+ (coming soon )
Andy01 is offline        Reply With Quote Quick reply to this message
Old 04-24-2017, 08:17 AM   #15 (permalink)
Andy, those are exactly the blade profiles that I want, but the problem is rotation direction. For a Huey, I really want to make the blades rotate the scale direction. However, since all the correct looking blades are either metal or asymmetrical, it seems I can only get one or the other.
Old 04-25-2017, 05:03 AM   #16 (permalink)
yeah, I didn't bother about scale rotational direction on my little 500. The Long Ranger and EC-145 are both CCW/LH, but I just left the UH-1N as CW/RH. It was just a fun everyday flyer. I don't many people noticed that it was wrong.
Colin
Seahawk 600
UH-1N 500
Old 07-02-2017, 08:21 AM   #17 (permalink)
Finally managed to get some blades that match what I was hoping for. It took a bit of modification, but they finally look the part. I got a set on the 470mm Align blades and cut the tips similarly to what Trooper7 did. Here are a few photos of the test fit.
ID:	714112   Click image for larger version
