800 Class Helicopters 800 Class Helicopters |
#1 (permalink) |
![]() New to me Trex 800e DFC Pro super combo. I've gone over it in detail, and it should be in the air, BUT...
When I run the Spirit Spectrum Analyzer (vibe test) with all blades off, it shows a nasty vibe level spike on the Y-axis starting around 1300 RPM, so I know that as the Spirit manual says, "there is a problem with the main gear, main shaft, main shaft bearings or rotor head". Here's what I have tried: 1) replaced main shaft - no help 2) checked spindle - perfectly straight 3) In case bearing blocks were not perfectly aligned with mainshaft, I rotated main gear to tightest point (least/zero lash), then loosened screws on all bearing blocks, re-applied Loctite and carefully re-tightened the screws. Tested a LITTLE better, but still way too high. Seller said the heli had never been crashed, and I don't see any indication of trauma. Main bearings all *seemed* good when i had it apart. OWB seems good. Disassembled the head, greased thrust bearings and reassembled (one of the thrust bearings was installed in wrong order, but was undamaged and it's good now.) Swash has a very tiny amount of lateral slop. Any suggestions would be much appreciated. Last edited by torpicaltrail; 08-13-2017 at 07:00 PM.. |
#2 (permalink) |
![]() i dont own spirit, if it was the case and found nasty vibe i would try head of after that swash off. eliminate maximum component. i know vibe can be amplified by other part. if no vibe record with only mainshaft and main gear. reinstall part one a the time. not on 800 but on 500 i found wear-out swash bearing causing random vibe.
trex 800e pro dfc, trex 700n dfc, trex 450l 6S, trex 150 |
#3 (permalink) |
![]() Where is the spirit mounted? What mounting tape are you using?
#4 (permalink) |
![]() Join Date: Mar 2012
#5 (permalink) | |
![]() Quote:
