MSH Brain FBL Unit MSH Brain Support Forum |
08-23-2016, 07:51 PM | #1 (permalink) |
Ikon2 Gov sensor
Hi Guys
I just bought the new Ikon2. I am using the Algin sensor. I have changed the plug on my Align sensor to a standard female plug to fit the new gov port in the Ikon2. However the sensor does not work. > Do you have to swap the red and black wire's? > Or what sensor should I use. Keen to get this resolved and get out and fly my new black nitro |
08-24-2016, 10:01 AM | #2 (permalink) |
I had to flip the polarity on mine.
XL Power 700v2 Nitro NME - OS 105HZR - Power Tune - Rail 716/106 - Brain2 HD |
08-24-2016, 10:29 AM | #3 (permalink) |
Back when I had the 700N with one of my mini Brain2's using the Align pickup sensor I only had to swap the micro JST style connector to a standard Futaba servo type connector and plug it in.
I wonder why you ended up having to reverse polarity on yours.... Sent from my SM-G935T using Tapatalk
Mike Martin, MSH BRAIN USA Team Manager MSH USA FLIGHT TEAM, CYCLONE BLADES, XNOVA MOTORS, JETI USA www.MSHUSA.com, www.MSheli.com |
08-24-2016, 10:34 AM | #4 (permalink) |
Align sensor has wire color reversed from normal. Black is positive, red is negative and white is signal. If you solder a servo end to your align sensor (like I did) it will be red to black, black to red, and white to white.
Field rep for Discover Card and team Visa. MSH Brain super fan and crash test dummy. |
08-25-2016, 05:00 AM | #5 (permalink) |
I used this as a reference...
08-25-2016, 04:52 PM | #6 (permalink) | |
My 570 and 700 are running the same sensor. 570 polarity is normal, 700 it's flipped. I think it really depends on how it gets soldered on the other end.
XL Power 700v2 Nitro NME - OS 105HZR - Power Tune - Rail 716/106 - Brain2 HD Last edited by Sowa; 08-25-2016 at 11:29 PM.. |
08-03-2017, 08:12 PM | #7 (permalink) |
Hi,
Replacing my Brain1 with Brain2 in a nitro helicopter with Align Sensor Just doble-checking due to is an old thread. The image shows the correct wiring in the servo plug? Thanks in advance
Align 800e PRO DFC // KRAKEN Yellow // RAW Nitro // Align 700N DFC // RAW Yellow // 2x Goblin 420 // RAW 420 // RealFlight 7.5 // neXt // AccuRc // Tribunus - Vbar Control Touch - Vbar Neo |
08-03-2017, 10:14 PM | #8 (permalink) |
It doesn't damage the sensor or the Ikon if plug it in with the wires wrong.
Plug it in, if it doesn't work, swap wires and try again. |
08-04-2017, 08:53 AM | #9 (permalink) |
Yes, this is correct for old align sensor only (3 pin plug) The beastx one is color coded correctly (6 pin connector) and would be wired using standard color scheme.
08-19-2017, 05:38 AM | #10 (permalink) |
I'm about to do this as well. My sensor has the beastx end on it. So I cut off the end and put a standard servo plug on it with red going to the negative on the Ikon?
Bill |
08-19-2017, 06:34 AM | #11 (permalink) |
No, black is neg, red is pos, white is sig.
08-19-2017, 09:18 AM | #13 (permalink) |
Pic is wrong for beastx sensor.
08-19-2017, 09:23 AM | #14 (permalink) | |
Brain rail is Neg on bottom, Pos middle, Signal top
180CFX (uIkon), 300X (2208, Ikon), 300X (2213, Ikon), X3 Brain2, X3 stretch Brain2, X5 Brain2, DX9, DPL8 w/ Bump |
