Downloading tribunus logs - HeliFreak
Go Back   HeliFreak > R/C Electronics Support > Scorpion ESC and Motor Support
Scorpion ESC and Motor Support Scorpion Power Systems ESC and Motor Factory Support Forum
Old 04-13-2017, 09:29 AM   #1 (permalink)
Default Downloading tribunus logs
My tribunus has connected to PC no problem since the begging as well as downloading logs, but when I do click on download logs, I get a box in the top corner that starts at 0/100 and slowly goes to100/100. This process takes about a half hour. Is this normal? It seems that there's no way to select which parameters you want it to log. I could limit it to a few important ones to reduce download times. It seems that the ESC automatically logs everything and you just select which parameters you want to look at. Am I understanding this correctly? Is the half hour download time normal?
MSH USA TEAM PILOT
Protos max v2
RCHN #232
quinn is offline        Reply With Quote Quick reply to this message
Old 05-09-2017, 11:53 PM   #2 (permalink)
I was trying tonight to upload the logs from the ESC. I didn't get any thing. Can anyone help me with this ?
Synergy 766, E7SE, E5SS, E5S, 516, V Control, Neo, Tribunus
Freeskiken is offline        Reply With Quote Quick reply to this message
Old 05-11-2017, 07:34 AM   #3 (permalink)
To get the logs, you need to:
- Once "Connected" to the ESC so that you are seeing the live telemetry on the PC software dashboard
- Click the Load Log button. That will take a little while. There is a tiny progress window in the corner that reads percent done.
- Once the Load has finished, click the Export Log button, browse to pick a location and file name, and click the Export button.
Just a note, the current version of the PC software is 1.02. However, there is the original Jan.17/17 version and a March7/17 version! I don't know why they didn't change the version number. I was told you need to use the newer version to get full logs off. This was regarding a Tribunus200 but I'm not certain whether the issue is the hardware or the newer firmware versions.....which would also apply to the T120. To be safe, just make sure you are using the most current PC software.
Also, the ESC only holds approx. 4-5 flights and then overwrites the oldest data. So, if you have been doing a lot of bench testing, you may have already overwrote the data from your shutdown flight.
KevinB
KevinB is offline        Reply With Quote Quick reply to this message
Old 05-11-2017, 10:24 AM   #4 (permalink)
KevinB
how do we know which version we have
| Atom 6HV : vbar NEO pro rescue | Goblin 700 : vbar 5,3 pro | HD Cell 500 : brain2 |
Old 05-11-2017, 11:55 PM   #5 (permalink)
Check the content creation date of your install file for the date. I don't know if you can tell from the installed program. If in doubt, just uninstall, download a fresh version., and reinstall from that.
KevinB
Old 08-30-2017, 09:30 AM   #6 (permalink)
maybe you can help me too
after I load the log from the ESC and export it the logs on the ESC cleared?
I mean it write new log evry time?
koko is offline        Reply With Quote Quick reply to this message
Old 08-31-2017, 06:25 AM   #7 (permalink)
To find the version, simply open the program, look in the upper left corner, and then click on help. In the drop down window, click on about and it will open a window. The version number is found in the blue band.
Hope this helps.
Specter 700, Logo 700, Logo 690SX, Goblin 700, Trex 700DFC, Gaui X7, Trex600EFL Pro, Trex 600 ESP, Trex 500 ESP, DJI 550
Amain Team
Rep
rcflyerheli is offline        Reply With Quote Quick reply to this message
Old 08-31-2017, 10:32 AM   #8 (permalink)
Hope this helps.
was refering to this
KevinB
Old 09-01-2017, 10:53 PM   #9 (permalink)
Look at the "Content created" property of the 1.02 install file you used to install it to your PC. That shows which version you have.
OR, you can just download it now and install from the new file. Then you'll be sure to have the latest version.
KevinB
