Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 700X
Blade 700X Blade 700X Helicopters Information and Help
Old 10-02-2017, 02:31 PM   #1 (permalink)
Default 700X and DX9 setup.
Fainely hawe my 700X redy for MAIDE hower
ar7200bx setup as sudgested.
esc as james setup.
evrything chimed and copter is in balanse.
is there something that i nead to cnow befor i go to test hower?
haw set my radio as for my 360cfx.
think it is a god starting point for 700x to..
any tips / hints is haily acsepted..
Miiku is offline        Reply With Quote Quick reply to this message
Old 10-02-2017, 08:18 PM   #2 (permalink)
1. Check your bevel gear mesh - shim as needed, and make sure your 2nd gear counting from front does not move side to side when you press on it.
2. Verify all controls and gyro corrections twice before flight. Also do a range check it you haven't already.
3. Make sure the main blades are pretty tight so they can't fold during spool up.
4. Give yourself lots of room!
During first flight check for tail hold, if it has a fast wag / chatter during a banked turn (sounds like fit-fit-fit-fit-fit really fast) then move servo ball in one hole and reset tail endpoints in 7200bx. After a couple flights recheck the tail gear mesh and verify no movement in number 2 gear.
Have fun! These fly great!
Jherison is offline        Reply With Quote Quick reply to this message
Old 10-03-2017, 04:13 AM   #3 (permalink)
Haw bean rely careful whit the build.
Haw bean building it for 1 year
all gear mesh is ok. haw chimed all gears sow i think all is ok..
ar7200bx settings haw bean checked 3 ore more times that they are ok.
for the ruder/tail servo arm i use the arm from the kit.
haw been running it with no blaids so i can find problems if there was some.
and everything looks ok..
Old 10-03-2017, 06:55 PM   #4 (permalink)
Sounds like you are ready then. If you do get the tail chatter use a standard horn and move it in one hole from the stock measurement. Pretty common on this machine.
Have fun!
Old 10-04-2017, 04:26 AM   #5 (permalink)
Haw read abaut the tail problems..
Blade setup is 700mm mains and 115mm tail Zeal blaids.
Im not (yet ) doing any hard 3D flights so i hope this setup is ok for my.
For mainpower i use 2 x 6s 4500mah 30c turnigy (timer set at 4:30)
For AR7200bx and servos i have 2s 1350 lipo and Optiguard..
