Go Back   HeliFreak > R/C Helicopter Support > Multi Rotor Helicopters - Tandem
Multi Rotor Helicopters - Tandem Multi Rotor Helicopters - Tandem
Like Tree15Likes
Old 09-27-2017, 05:47 AM   #1 (permalink)
Default 2017 Twinn Rexx unboxing and build review!
I will be doing a complete build log of the new 2017 Twinn Rexx kit as well as testing the new fbl board that is do out soon!
More to follow!
billy bob likes this.
Synergy E5, Synergy 516, Align 600n
Goblin 380,600 scale Hughes 500e,230s Huey, 230s v2,Twinn Rex CH-47
chrisl is offline        Reply With Quote Quick reply to this message
Old 09-28-2017, 05:15 AM   #2 (permalink)
Default 2017 Twinn Rexx unboxing and build review coming soon!
Look forward to hearing how it goes.
Please keep us updated
Flyingzook is offline        Reply With Quote Quick reply to this message
Old 09-28-2017, 08:01 PM   #3 (permalink)
I should have my kit sometime next week!
Old 10-03-2017, 05:48 AM   #4 (permalink)
Received shipping notice on 10/02/17 so it should arrive soon!
Ordered two copterx 3-bladed heads and those should be here mid October, I will post pictures as soon as it arrives!
Old 10-05-2017, 07:27 AM   #5 (permalink)
While waiting to get started we decided on these two paint schemes!
ID:	724805   Click image for larger version
Old 10-05-2017, 01:50 PM   #6 (permalink)
Default Unboxing
The kit is very well put together with numbered bags to go along with the instructions! There is a comprehensive list of instructions that can be downloaded to your computer or you can print a hard copy like I did. I put the complete instruction set in a binder for ease of reference!
ID:	724881   Click image for larger version
ID:	724882   Click image for larger version
ID:	724883   Click image for larger version
ID:	724884   Click image for larger version
Old 10-06-2017, 03:56 AM   #7 (permalink)
Looks good! I vote for the camo paint scheme.
Old 10-06-2017, 05:03 AM   #8 (permalink)
Thanks, we will be building both paint schemes, I will be doing a fuselage build as well after the mechanics are set up! Keep watching!!
ID:	724905   Click image for larger version
Old 10-07-2017, 08:20 AM   #9 (permalink)
Default Frame assembly
Twinn Rexx V2
The following is my critique of the assembly instructions of the Twinn Trexx V2 produced by Tech Model Products.
Let me start by mentioning a few caveats. First this is not a model that someone should consider if they have no experience with model helicopters. This is for intermediate and above experience levels. This should not be considered a negative but is simply a result of the flexibility that this kit provides when choosing rotor heads, electronics, etc. Secondly, some of my critical comments may be a bit petty, but the intent is to provide input to improve the ease of assembly in the future as I believe this kit has great potential.
Overall the assembly of the main mechanics was accomplished with little difficulty. Assembly is best accomplished by utilizing the Assembly Instructions in combination with the Assembly Figures (drawings). The instructions are laid out in a logical approach that requires very minimal disassembly of previously completed sections. Overall the Assembly Figures are well drawn and provide the clarity required to resolve orientation questions. One minor exception was the main gear assembly. The addition of an exploded view of the main gear assembly would be helpful. This would streamline the orientation of all of the parts in that assembly. One way to add additional clarification to the drawings overall would be to include a reference to each individual hardware size. A symbol indicating the type of adhesive (CA, Loctite, etc) placed appropriately would also be beneficial.
The bolts, screws, and nuts are packaged in multiple small plastic bags. It was unclear which bag to use for each assembly section. I did not see a correlation between the bags and the assembly steps. Because there are only a few different sizes of hardware utilized, the solution for me was to simply use the hardware size referenced in the instructions irrespective of the bag where you got the part. My recommendation would be to either have a direct correlation between each specific step and the associated hardware, or to simply package all like parts together to avoid confusion.
All parts seemed to be of high quality and all parts fit together properly. I would however recommend a different screw on the anti-rotation bracket. The small M2x6 Button Head screws have such a small hex area that disassembly may be problematic especially when you consider that they are set in place with CA.
In conclusion the mechanics overall were a pleasure to assemble and I am looking forward to acquiring the balance of the items required to complete the final assembly.
ID:	725038   Click image for larger version
ID:	725039   Click image for larger version
ID:	725040   Click image for larger version
ID:	725041   Click image for larger version
ID:	725043   Click image for larger version
ID:	725044   Click image for larger version
ID:	725045   Click image for larger version
ID:	725046   Click image for larger version
rudyrov and billy bob like this.
Old 10-16-2017, 04:15 AM   #10 (permalink)
Looks good. Have you had a chance to do any more?
Old 10-16-2017, 05:24 AM   #11 (permalink)
Default New scorpion motor installed!
Got this Scorpion motor today! Copter x 3-blade heads are here also!
ID:	726362   Click image for larger version
Old 10-18-2017, 10:09 AM   #12 (permalink)
I just ordered a kit last week as well as the body and the CopterX 3 blade heads. I'm looking forward to this build as well. Thanks for the review
RNDMAXE is offline        Reply With Quote Quick reply to this message
Old 10-19-2017, 05:02 AM   #13 (permalink)
Default Gartt 1800kv motor
We are also going to be using this motor in Wayne's Twinn! I beleave it's the same as the Align motor!
Old 10-24-2017, 05:53 AM   #14 (permalink)
Should have the Orange 3-axis controller here this week as well as the TH-2 XPR mixing board from Joe. The three blade head from Copter-x seem to be of decent quality and went together easy!
ID:	726871   Click image for larger version
Old 10-24-2017, 07:04 PM   #15 (permalink)
Could you use the Baverion Demon FBL unit on this heli
Synergy N5C, Gaui X3 x 2, Gaui NX4, Cell 500
billy bob is offline        Reply With Quote Quick reply to this message
Old 10-24-2017, 07:52 PM   #16 (permalink)
I believe you can, I haven't tried one yet!
Old 10-30-2017, 05:01 PM   #17 (permalink)
Default TH-2 controllers in the house
Received the TH-2 controller the other day and it looks like a very well made board! Solder looks great! The picture depicts a board, board mount w/foam tape,connector cables, a pen screwdriver and USB cable.
ID:	727524   Click image for larger version
ID:	727525   Click image for larger version
Old 10-31-2017, 04:31 PM   #18 (permalink)
What size are the main shafts
Old 10-31-2017, 04:53 PM   #19 (permalink)
Main shaft size is 5mm
Old 11-08-2017, 06:04 PM   #20 (permalink)
Getting closer to set up on the TH-2 board, servos installed and everything in its place! Going to start the process of setting up the TH-2 at the end of the week! We will have an extensive write up sometime next week!
ID:	728292   Click image for larger version
ID:	728293   Click image for larger version
ID:	728294   Click image for larger version
