Old 09-29-2013, 09:04 PM   #21 (permalink)
Here is some instructions on how to make the divider depending on what sensor your using.
https://www.helifreak.com/showpost.p...&postcount=182
https://www.helifreak.com/showpost.p...&postcount=183
- Gaui NX4 - Pat's Highwind X5 FPV Racer - Armattan F1-5 Pod FPV Racer - DX8 - Taranis Plus -
S.Millar is offline        Reply With Quote Quick reply to this message
Old 09-30-2013, 09:06 PM   #22 (permalink)
Very good information. So for HW sensor, we limit the supply voltage to the sensor whereas the Hyperion sensor needs to limit the signal wire output voltage to Mini Vbar port.
Nano CPx, Hirobo Quark
250 SE, Pro Upper Frame, Talon25, KDE, KST215, DS95i, Mini Vbar
450 Pro (6s), KDE, Lynx, Tarot, RJX, YEP40, KST215 & 515, SK540
465 (6s), Align DFC, HW50AV3, KST315 & 8910A+, SK720BE
lcc014 is offline        Reply With Quote Quick reply to this message
Old 10-01-2013, 10:51 AM   #23 (permalink)
You are correct sir.
A lot of guys are starting to use the Hobbywing Sensor. I hope Mikado updates the website with the proper instructions for making the stepdowns work with it.
Old 10-01-2013, 12:33 PM   #24 (permalink)
Thank you for the confirmation.
Old 04-03-2014, 12:14 AM   #25 (permalink)
This is my lack of understanding of electronics, however, why is one resistor splitting the + wire and the other resister connecting the - and + wire? this does not cause a short?
I just received the HB sensor and have a 5.5v BEC so need to step it down .5 v's.
Just want to make sure I do this properly. It seems I should just put a resistor between the + and a resistor between the - wire. Why do all the diagrams show the + and - wire connected with a resistor?
SAB Goblin 600, Logo 480Xxtreme, Gaui X3, Compass 6HVU, Atom 500
Jmann841 is offline        Reply With Quote Quick reply to this message
Old 04-03-2014, 11:40 AM   #26 (permalink)
Two resistors in series creates a "voltage divider". When current flows across the voltage divider, the total voltage is divided between the two resistors. If the resistors are of equal value, the voltage is equally divided. So if you have a 5.5v source and tap off the center between the two resistors the voltage at that point would be 2.75v. You can raise or lower the voltage by changing the ratio of the two resistors.
You can model different combinations using the calculator in S.Miller's post
http://www.raltron.com/cust/tools/voltage_divider.asp
The total resistance of the two resistors is high enough that amount of current that flows across the resistors is very low. So its not a short. If the combination of the two resistors is low enough it will draw too much current from the buss and put more than necessary load on the BEC or battery. Use some of the examples in this thread to stay in the safer zone.
This is very inexpensive method to lower the incoming voltage. Sort of like what a BEC does. Except this is only suitable for very low current applications.
Gregor99 is offline        Reply With Quote Quick reply to this message
Old 04-04-2014, 01:16 AM   #27 (permalink)
Ok, thank you,
So just to confirm the wiring diagram. Red wire goes to resistor which connects to another resistor that connects to black wire.
The Two resistors connect to the other end of the red wire.
Black wire connects to black wire still.
Is this correct?
Old 04-04-2014, 10:42 AM   #28 (permalink)
This thread is very informative!
- Michalis - OXY Heli -
...let the flying be second nature!
acidla is online now        Reply With Quote Quick reply to this message
Old 04-04-2014, 11:38 AM   #29 (permalink)
Originally Posted by Jmann841 View Post
Ok, thank you,
Is this correct?
To be clear, the center of the two resistors connects to the red wire going to the sensor. Black wire and signal wire as straight through. S.Millar had nice little schematic showing this in his post. Disregard the specific resistor values unless you are using a 2s LiPo. Use the calculator in his post to find the required values for your input voltage. https://www.helifreak.com/showpost.p...&postcount=183
Old 08-16-2014, 01:53 AM   #30 (permalink)
Can I use 2 1k resistors, Or do i really need the 1.5k?
Edit: i followed the link lol.
3dblair is offline        Reply With Quote Quick reply to this message
Old 06-08-2015, 04:04 PM   #31 (permalink)
I also wondered why my HW sensor did not work with mini vstabi and voltage divider on the sensor output signal ..... so even after more than a year still helpfull !!
Sebastien
Lynx team pilot . Compass field rep.
Compass 7HV , OXY3+, Goblin 700 comp , Gaui X7 formula, Jeti 2.4, Mikado vstabi
666yeti666 is offline        Reply With Quote Quick reply to this message
Old 06-08-2015, 08:00 PM   #32 (permalink)
Sebastien
On the hw sensor you do not cut down the voltage on the signal wire. You must cut down the voltage powering the sensor.
Heli's I have:
Goblin 500 (Vbar Neo), Gaui X5(Vbar Neo), X7(Vbar Neo), Innova 600 Night heli (Vbar Neo Vbar Vcontrol
I'm the not so newbheliusr as I have been here a while. But I like this name.
newbheliusr is offline        Reply With Quote Quick reply to this message
Old 06-09-2015, 01:16 AM   #33 (permalink)
I know, that's why I said that this thread is stull usefull, even after more than a year ... ;-)
Seb
Old 06-16-2015, 07:40 PM   #34 (permalink)
It was my understanding on the mini vbar that you don't apply voltage to Rx a at all since all 3 pins are signal pins.
I'm using a YGE 160hv esc with a mini vbar. To plug my second BEC lead in (first BEC lead into Rx c) I used a Y cable on Rx B. and i have not burned anything up. advised by Mrmel to do as such. I also just ran the orange lead from the programming lead to Rx a. Also advised by Mrmel. The hobbywing sensor can take an input of 3.7 to 8.4v
http://www.falconsekido.com/products/rpm-sensor
Perhaps I'm understanding this incorrectly. If that's so I'm sorry for butting in.
Sent from my iPhone using Tapatalk. Spelling is optional.
I know it's an old post but thanks for the hobbywing link I'm looking to use some of my old vbars with the Vcontrol and esc's that have no rpm wire. This is perfect. no point in putting a Neo and replacing a perfect esc on a 5 year old heli. But it would be nice to use it on a new radio.
__________
Goblin 380, 500, 570, Mikado 690SX, 480Xx(Stretched 500) , Protos Mini, Max V2 , Oxy 3, Vbar Control/Neo Vlink (Citizen 758)YouTubeProgress:http://tinyurl.com/oliver1071
oliver1071 is offline        Reply With Quote Quick reply to this message
Old 06-23-2015, 10:25 AM   #35 (permalink)
Maybe this is an odd question but why not just use RX C for the rpm sensor (signal and power)?
__________
Old 06-23-2015, 11:05 AM   #36 (permalink)
Because RxC is in use when not running Spektrum satellites. It's either the tail gain/bank switching port or the single line input port.
Also, if you're running a HV setup, the voltage on RxC will be too high for the sensor.
HeliFreak Support
Protos Max Evo 700 (Brain 2), Protos Max V2 770 (iKON 2), Synergy 516 (Brain 2), DT520Ev2 (VBar)
Graupner MZ-32
Old 06-23-2015, 11:13 AM   #37 (permalink)
I'll be using the VControl and the HV hobby wing sensor. http://www.falconsekido.com/products/rpm-sensor
So really all of the ports are open on the mini. I'm still getting used to the control so I don't know if there's anyway to point it to that channel for the rpm sensor.
Also the first heli that I'm going to repurpose the mini vbar is only running a bec at 5.5volts so I assume that may be ok in RX A
But my next one may be higher this is just a test since I have some vbars laying around.
__________
Old 06-03-2016, 08:14 AM   #38 (permalink)
I'm using a hobbywing sensor, Sat 2 port for power. Unfortunately when I first plugged it in to the mini blue vbar, I plugged it into the RXA signal port rather than the ground port. I'm not getting any output rpm reading on the software. Is there a chance I fried it from the wrong plug in? Thanks.
Jim
gapagod is offline        Reply With Quote Quick reply to this message
Old 06-03-2016, 09:40 AM   #39 (permalink)
Jim
Not sure what you did there...
What did you plug into what?
Gaui X3 HW 50A V3 OMG H1/H2 Servo's BL450MX Mini-V (M.I.A.)
Gaui X5 FES Polaris BEC BLS451/251 Silverline V-Bar Formula Swash/Head
JR Forza 700 Scorp 160A opto + 4525 520 JR NX8925/SLG01 Vbar Neo
JR XG14 PL8 v2
mverhorst is offline        Reply With Quote Quick reply to this message
Old 10-10-2017, 09:58 PM   #40 (permalink)
Default Hw rpm sensor voltage
I have just installed a hw rpm sensor on my g700 with 8.4v rx pack and mini Vbar. The product I have limits the sensor output to 5 volts, I am suspecting there has been a change to the product?
Laidback_racer is offline        Reply With Quote Quick reply to this message
