setting rescue/gyro with futaba t10j - HeliFreak
Go Back   HeliFreak > R/C Electronics Support > Spirit FBL system
Spirit FBL system Spirit FBL System Discussion
Old 11-02-2017, 03:42 PM   #1 (permalink)
Default setting rescue/gyro with futaba t10j
Hello everybody,
I am trying to set my new tx ( futaba t10j) with spirit pro.
I am stuck not with the gyro/rescue setting.
What I would like to have is:
1) rescue on the spring? switch
2) be able to change the gyro value when I am using the switch idle up.
that means be able to have differents values each idle up.
what I did so far is that I am able to use the rescue but not to change the sensibility of the gyro for each idle up.
Is there any guide or something who can help me?
thank you so much!!
matty609 is offline        Reply With Quote Quick reply to this message
Old 11-02-2017, 03:43 PM   #2 (permalink)
Old 11-02-2017, 05:11 PM   #3 (permalink)
Hello,
you can assign F: Stabi function in the General tab/Channels window - for example for Channel 8.
Then you can assign a momentary switch to change the value for channel 8 in your radio.
From this moment rescue mode should work if it is configured in the Stabi/Function to Rescue.
You can set Gyro Gain for each flight mode as you wish in your radio in the GYRO menu. In each flight mode it should be configured to AVCS, not NORM.
Spirit System - www.spirit-system.com
ZeXx86 is offline        Reply With Quote Quick reply to this message
Old 11-03-2017, 12:51 PM   #4 (permalink)
As ZeXx says assign rescue to a channel (8) in the software then in aux channel screen on your Tx assign that channel to your spring loaded switch
To change gyro sensitivity in flight modes assign gyro to Cond switch in the gyro sens menu on the Tx ( you have it on switch H) and make sure to stay in avc in all flight modes or you will put the tail in to rate mode
andy6409 is offline        Reply With Quote Quick reply to this message
Old 11-03-2017, 05:15 PM   #5 (permalink)
I think I did all right. thank you so much
