Go Back   HeliFreak > R/C Helicopter Support > OXY HELI > Oxy2
Like Tree1Likes
  • 1 Post By jrman83
Old 12-07-2017, 12:53 PM   #1 (permalink)
Default Oxy 2 and RCM-BL250MX motor.
Finally pulled the trigger and got an Oxy 2 sport, the plan was to use the electronics from my old T-Rex 250 (except the fbl) with the motor, the problem I'm having is that the lynx pinion (13t) doesn't fully bite the main gear, probably the motor shaft is not long enough, the pinion only bites 40% or so of the main gear, ,I'm not sure if this will affect performance or wear out the teeth of the main gear, do you guys using this motor had this problem?
Goblin 500/380/ T-REX 450L/250
rockdj is offline        Reply With Quote Quick reply to this message
Old 12-07-2017, 01:04 PM   #2 (permalink)
Not good. Should be full seated. You can just reposition the pinion on the shaft after pulling it off. I used to run this motor on one of my O2 months back for about 100 flights then upgraded. Good motor for low headspeed.
"VOLATICUS INTERRUPTUS"
-- If you don't see these words on my post above asking, "have you ever experienced this" or something to that effect, please keep your "experience" to yourself and just move along -- Neo
e92.M3 is offline        Reply With Quote Quick reply to this message
Old 12-07-2017, 03:00 PM   #3 (permalink)
Yeah I thought of that, but wasn't sure of it since it would leave a few mm of the pinion out the motor shaft, worried it might lose when flying and result in a crash.
Old 12-07-2017, 03:06 PM   #4 (permalink)
We run them high up on the motor shaft. Barely high enough to fully engage the main gear. I have one like this and have had no problems out of it. I scuffed the motor shaft with fine sand paper. Cleaned the pinion with alcohol then after all dried up put it together with green loctite.
The more I learn the more I realize I don't know
T-Rex 800DFC Pro, 700LTOP, 700L Night, 550V2, 470LT, 250DFC, Oxy-2 x2, 3 x2, 4, Goblin 500 Sport(soon), Fireball x2, Blade 230s Night, 180CFX, MCPS, Nano CPX & NQX2 FPV, Vortex 250, Inductrix FPV. K110 Cars/Trucks/Planes AMA#L965241, Part 107 Pilot
#iamundeservedlyblessedandiknowit
TeeJayShelton is offline        Reply With Quote Quick reply to this message
Old 12-07-2017, 03:25 PM   #5 (permalink)
+1 this.
Ignore this part; see below: But red loctite is what recommended for this job: Loctites /
What i meant fully seated above was: gear to gear seating.
Old 12-07-2017, 03:27 PM   #6 (permalink)
I'm running a Trex 250 motor and yes, only about half of the pinion engages on the shaft.
The question has been asked several times and Luca has confirmed it's fine like this. Provided you're using retaining compound it's not going to move.
My Oxy had a 4500rpm inverted crash, hitting hard enough to strip the main gear. The pinion didn't budge, despite the motor shaft only being half way through it, and I'm still flying it today.
myxiplx is online now        Reply With Quote Quick reply to this message
Old 12-07-2017, 06:03 PM   #7 (permalink)
Thank u all, I'm going to just insert half of the pinion in the shaft.
BTW do you know if the DS415M servos will fit in the Oxy 2?, those are the ones from the T-Rex 250.
Old 12-07-2017, 06:16 PM   #8 (permalink)
Nope. Too big and heavy.
Old 12-07-2017, 07:37 PM   #9 (permalink)
I keep posting this over and over, DO NOT USE THREAD LOCKER FOR MOTOR PINIONS !
It is not made for this!!!!
Use retaining compounds for pinion install.
https://www.helifreak.com/showthread...=green+loctite
HW.
Many helis from the 70s to 2000s.
Align,Blade,GMP,Hirobo,Kyosho,Schluter.Flybars cool,FBL too. Currently flying the little ones.
Heliwhisperer is offline        Reply With Quote Quick reply to this message
Old 12-07-2017, 07:53 PM   #10 (permalink)
Oh yeah... Missed that bigtime... All apologies...
Should be this: Omicron Red
Old 12-07-2017, 09:08 PM   #11 (permalink)
When it comes to change pinions how difficult is it to remove existing pinion and put on a new pinion on the motor shaft?
dl5973 is online now        Reply With Quote Quick reply to this message
Old 12-07-2017, 10:12 PM   #12 (permalink)
This: Pinion remover l
Or heat it a few seconds with small torch then pull pinion with pliers. Cover the pinion with thin cardboard before pulling to protect the teeth. Or use flat tip screw to twist pinion away from motor body.
Old 12-08-2017, 01:19 AM   #13 (permalink)
As above, you MUST use retaining compound if you want the pinion to hold securely. When you want to remove it a little heat from a soldering iron releases it nicely.
Old 12-08-2017, 04:27 AM   #14 (permalink)
If you have a decent soldering iron, just holding to the pinion to get good and hot and the pinion will pull off pretty easy.
Sent from my SM-G955U using Tapatalk
rjbokleman likes this.
