Satellite and bec?? - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Atom 500
Atom 500 Compass Atom 500 Model Helicopter Discussion
Like Tree7Likes
  • 1 Post By ARM_Coder
  • 2 Post By ARM_Coder
  • 1 Post By Wargamer
Old 12-28-2017, 09:26 PM   #1 (permalink)
Default Satellite and bec??
Just wondering do i need a separate bec and satellite rx for my atom 500? Im using a ar 7200 bx and hobbywing 100amp esc. Tx is dx6. Thanks.
helionfire is offline        Reply With Quote Quick reply to this message
Old 12-29-2017, 10:15 AM   #2 (permalink)
I highly recommend a sat so you get radio path diversity. Just be careful with the wiring, because a sat with a flaky cable can do nasty things.
In my Atom 5.5 I use a separate Hobbywing 5A BEC, but I'm not sure whether it's really mandatory. My ESC is a Hobbywing Platinum Pro 60 Amp.
Cheers!
Ah Clem likes this.
We are made of star stuff.
Compass 7HV / Atom 6HVU / Atom 5.5 / Align Trex 500L / Spektrum DX8
ARM_Coder is offline        Reply With Quote Quick reply to this message
Old 12-29-2017, 12:21 PM   #3 (permalink)
Thanks. I tried my spectrum sattelite but during the binding process the light came on during binding but went out afterwards? Will not stay lit but ar 7200 bx bound properly.
Old 12-29-2017, 02:15 PM   #4 (permalink)
Check wiring.
Check whether your sat is DSMX and not DSM2.
Redo the binding, but moving your TX some meters away. Sometimes the received signal is so strong that the binding goes wrong.
Cheers!
Ah Clem likes this.
Old 12-29-2017, 02:21 PM   #5 (permalink)
Originally Posted by ARM_Coder View Post
Check wiring.
Cheers!
+1. It could be a wiring issue. I am also using the AR7200BX on my two Atoms... Both have satellites.
KBDD Team Pilot / Team Compass
Compass Chronos | 7HVU | 550U | Atom 5.5 | Gaui X3 #1 | X3 #2
cyclo is online now        Reply With Quote Quick reply to this message
Old 12-29-2017, 03:12 PM   #6 (permalink)
Why wont dsm2 work?
Old 12-29-2017, 03:33 PM   #7 (permalink)
Why wont dsm2 work?
DSM2 is not compatible with DSMX. The AR7200BX is DSMX as far as I remember.
Ah Clem and cyclo like this.
Old 12-29-2017, 04:26 PM   #8 (permalink)
Thank you all for your replies. The satellite i used did not have the x on the case. One more question.....i do have a dsmx sat reciever on my warp 360. If i take that one off will it affect anything? Figured i would use that one since they say a sat rx is mandatory for 500 and up size helis.
Old 12-29-2017, 04:53 PM   #9 (permalink)
I always played on the safe side, using sats even in small helis, but if I had to opt between a smaller and a larger heli, the sat would go to the larger heli, no doubt.
The larger heli has more mass, so it will shadow the received signal more than a smaller heli. Being larger, you will most likely send it farther away. In all honesty, I don't think a Warp-sized heli really needs a sat, but when I had a Warp, I equipped it with a sat, to be (or feel) safer.
You be the judge.
Edit: Just to make it sure, I would never fly a 550+ sized helicopter without a sat. Even a 500 would make me quite nervous...
Cheers!
Old 12-29-2017, 05:15 PM   #10 (permalink)
Your Warp 360 will be fine with just one Rx, or even just a single sat as the Rx. The Atom really needs two to play it safe. So moving your spare sat from the Warp to the Atom would be a good move. Also, if looking for sats in the future, the Lemon DSMX sats are every bit as good as the Spektrums, and will cost you about $10 rather than $35. (They are not clones...)
On BECs, I have a HW 80A on my Atom and the built in BEC is just fine.
cyclo likes this.
Compass Atom 5.5; Oxy 2/3
XK K110 K120
Wargamer is online now        Reply With Quote Quick reply to this message
Old 12-29-2017, 06:17 PM   #11 (permalink)
Thank you all again for the info. Happy new years to you all!!
Old 12-29-2017, 08:52 PM   #12 (permalink)
Yes the dsmx satellite bound perfectly to the ar 7200bx. Thanks again. My bad on my lack of knowledge.
Old 12-31-2017, 01:56 PM   #13 (permalink)
Lack of knowledge is just an opportunity to experience the pleasure of learning something new! This is a crazy deep hobby with so much to learn. Enough new things to keep us all happily occupied pretty much forever.
XK K110 K120
Old 01-02-2018, 10:12 AM   #14 (permalink)
Well said!!
Old 01-16-2018, 09:07 PM   #15 (permalink)
I run WR Hercules Super BEC's on both of my Atoms (standard and stretch). These have a small footprint and two output leads (so that all 10 amps can get to the electronics).
Both have been upgraded to DMSS, but I always ran a receiver and satellite on them (antenna diversity and redundancy is a very good thing).
When I had DSM2 on my Warp with an AR7200BX, I always ran a satellite as well (again, antenna diversity and redundancy is a very good thing).
$30.00 for a satellite, even on a small helicopter, is very cheap insurance.
ID:	734899   Click image for larger version
KBDD-Team Captain/Compass Team Manager/Experience R/C/ Team JR Americas/ Western Robotics Field Representative
6HV-U, Warp, 7HV,Knight Pro,Knight 3D, Atom, Atom Stretch, Odin II, 6HV, 3D Plus, Knight 50, Chronos
Old 02-04-2018, 05:02 PM   #16 (permalink)
Thanks again to all for your help.
