Like Tree1Likes
  • 1 Post By Xrayted
Old 01-13-2018, 01:49 PM   #1 (permalink)
Default ikon cyclic setup question
hi. when setting the cyclic pitch is it done elevator or aileron(blades over the boom) ? it doesnt mention it anywhere
helifreak member since 2003
south of boston
iheliflyer is offline        Reply With Quote Quick reply to this message
Old 01-13-2018, 02:40 PM   #2 (permalink)
ive done quite a few and set pitch with blades cross ways with heli level in all directions
690sx
birchbore is offline        Reply With Quote Quick reply to this message
Old 01-13-2018, 04:18 PM   #3 (permalink)
ive always done it with the blades side of the heli.. not inline with boom.. i only set my Pitch with inline to boom
RAW 580 ,lots of Planes Powered by IX14 AMA 36 yrs.
Old 01-13-2018, 08:05 PM   #4 (permalink)
Iv wondered if there is a specific orientation. Iv quite quite often found I get more cyclic pitch in one direction than the other, and have not been able to achieve the requested 10 degrees in every direction?
Dan. is offline        Reply With Quote Quick reply to this message
Old 01-13-2018, 08:35 PM   #5 (permalink)
The only way to get the 10 degrees in all directions would be to have the swash at absolute level , and the main shaft absolutely perpendicular at all angles to the surface you used calibrated your pitch gauge. I have found it is something that can be abscessed over, but in the end makes little difference. For me with Brain/Ikon I find it more bothersome that my pitch settings are not uniform +/-. I saw a mention from OTS about using the transmitter to fine tune these values, but I dont think my collective management is good enough to be able to tell the difference
Compass Chronos, Logo 550sx,Logo 400se Jeti
Protos Max Leggero Evoluzione 800
Pygmaeus is offline        Reply With Quote Quick reply to this message
Old 01-14-2018, 08:34 AM   #6 (permalink)
It makes no difference whether setting cyclic or collective pitch. The only difference on cyclic is which control you will need to make on the TX to move the blades to test depending on whether you have the blades parallel or perpendicular to the boom. Use whatever position is easiest for you.
The same applies to collective pitch. Place the blades in whatever position is easiest for you to access. The important thing is that once you choose, you must zero out your pitch gauge in that exact same position and only the readings in that blade position are valid from then on.
You cannot rotate the blade you just checked to another position or move the gauge to the other blade position and check again without first zeroing the pitch gauge out again at the new position, otherwise the numbers will be different. The only way around this is to shim the model perfectly level in all orientations, and there is no need for this as long as your device can set zero on its own for any specific location.
The fastest for me is choose one position for checking both collective and cyclic so I only have to zero my gauge once, then simply spin the opposing blade around to the exact same position to check and adjust the blade links until both show the same zero collective value at mid stick. I only measure and match both blades like this for collective pitch to set proper tracking. I then measure only one blade for cyclic just to see if I'm getting the proper range I need. I could care less about the exact value as long as in the 8-10* range
Tony
Synergy 516, Gaui R-5 Speed (RIP), Cypher Vtol Jet (RIP), Spirit FBL, Hobbywing and Scorpion Tribunus ESC, Xnova motors. The girl in my DX9 tells them all what to do
Xrayted is offline        Reply With Quote Quick reply to this message
Old 01-15-2018, 08:31 PM   #7 (permalink)
Default bluetooth question
i have the one with internal bluetooth.. when my phone is linked to it can i fly or do i need to close the app first?
south of boston
Old 01-15-2018, 11:31 PM   #8 (permalink)
It's definitely recommended to disconnect for every day flying just to be on the save side.
The only time I would keep it connected would be for the real time vibe analysis on a brain 1 since it can't log vibes. On a brain2 I see no reason to keep bt connected during a flight.
zomaar is offline        Reply With Quote Quick reply to this message
Old 01-15-2018, 11:41 PM   #9 (permalink)
You need to connect your laptop with the software to see the realtime analysis. I don't believe it is available in the app ?
Why introduce more variables than needed ? Disconnect.
Dawiev is offline        Reply With Quote Quick reply to this message
Old 01-19-2018, 10:44 AM   #10 (permalink)
Zero pitch, blades parallel with boom
Collective, blade parallel with boom
Cyclic, no binding full collective +- and while full AIL& ELE cyclic tilt. You can spin the blades but does not matter.
Diabolo 700, Oxy 5 Nitro, OMP M2, Futaba
DanMcN is offline        Reply With Quote Quick reply to this message
Old 01-19-2018, 12:01 PM   #11 (permalink)
I may be misunderstanding your post, but you appear to be saying that the blades must be parallel to the boom to check these things correctly. Maybe you are only saying this is "how you do it" and I apologize if this is the case.
Having the blades parallel to the boom for setting cyclic and collective is great if that’s the way you do it, but there is absolutely no rule or reason that that is how it needs to be positioned to do it properly. When testing cyclic, only aileron will have any effect on blades parallel to the boom. Elevator cyclic must have the blades perpendicular to the boom for the blades to move at all, so you can't check both with the blades in one single position.
It doesn't matter because cyclic is cyclic and as long as you have the desired amount on one position there is no need to check the other assuming you have the same servo travel on both.
Our blades are never in one single position at all times so it's completely irrelevant where you set or check these values as long as you zero out your pitch gauge at that position and do not move it from there without resetting zero to any new position.
Any specific position claims other than what is required specifically to see aileron or elevator cyclic movements at the blades are internet myths. We are all free to use any position we want.
ticedoff8 likes this.
Tony
Old 01-19-2018, 04:05 PM   #12 (permalink)
I assume that is because your heli is tilted forward (nose down) on the skids?
It does not matter.
Like he said, if that's the way you do it, no problems.
I lay the digital pitch gauge on top of the gyro's case and push its "Zero" button.
Now, all the blade's pitch measurements are in relation to the gyro's case.
By replacing your morning coffee with green tea, you can lose up to 87% of what little joy you still have left in your life.
... You can increase it by replacing said coffee with beer.
