Go Back   HeliFreak > R/C Helicopter Support > MSH Protos > Protos 380
Like Tree1Likes
  • 1 Post By whitehedr
Old 01-16-2018, 01:55 AM   #1 (permalink)
Default Rotational play in the main rotor shaft
Hi guys,
not sure whether I missed something when attaching the main gear to the rotor shaft. The bolt (M2,5x16 according to the manual) isn't exactly a tight fit in the rotor shaft hole, so there's quite a bit of rotational play… almost 3cm (!) at the blade tip.
I'm worried this will put too much stress on the bolt. Any ideas?
Cheers
OliP
OliP is offline        Reply With Quote Quick reply to this message
Old 01-16-2018, 11:56 AM   #2 (permalink)
Well, I've got twice that. 2 1/2" at the blade tip. I haven't had an issue with it or noticed, but I think I'll pull my bolt through the drive hub and take a look at it.
As a comparison, I've got 1" on my trex500.
Specter 700, Protos 700 Gasser, XLPower 550, Protos 380 - Jeti DS14
Citizen - #202
Dowquest is offline        Reply With Quote Quick reply to this message
Old 01-17-2018, 12:48 AM   #3 (permalink)
Once the blades are spinning and under load that play will be gone.
ROG
Michaelinpr likes this.
Retired Old Guy MOLON LABE
Synergy N7, E5, 516, 766, 556
V-Bar Control Touch (Neon Yellow) Neo all around
whitehedr is offline        Reply With Quote Quick reply to this message
Old 01-17-2018, 04:18 AM   #4 (permalink)
Well, I don't care too much about the play itself. I'm thinking if the bolt doesn't fit snugly (as it does in my other heli) then the contact area between bolt and shaft is greatly reduced, even under load… and the bolt will be stressed a lot where the edges of the shaft hole bite into it. Wrong?
Old 01-17-2018, 08:42 PM   #5 (permalink)
I pulled my bolt out and inspected it, it looked fine. After reinstalling it, most of my play was gone.?? It was tight originally, but, I'm just gonna fly it and not think about it.
Citizen - #202
Old 01-23-2018, 04:00 AM   #6 (permalink)
Pretty normal. Once you spoil up the bolt will not have play as the force against it will only be in one direction. I have about 3cm rotational play on the bench as well.
Scorpion Power Systems
Michaelinpr is offline        Reply With Quote Quick reply to this message
