Like Tree7Likes
Old 02-27-2018, 07:27 AM   #1 (permalink)
Default Do most just run a BEC or anyone run seprate rx pack?
I just got a 700 class heli its a Logo 690, But it has the Castle creations 120 amp Ice 2 HV esc with a castle Pro BEC and just wondered do most run there 700s like this or do you run a separate RX pack.. The servos on mine are the BLSHV servos and shows online they need6.0V-8.4V so maybe that is why they went with the Pro BEC... but just wondered.
I had planned to add a RX pack to it if it didn't have a BEC cause in the ad online he didn't say anything about a BEC or if he did i missed it.
just wondered is it safe to just have the Power pack on board.
whats your thoughts and ideas on this.
Jim952 likes this.
B450X Scorpion Powered,Blade 180 trio,Torrent 110,Tricopter lots of planes AMA 28 yrs.
Old 02-27-2018, 09:27 AM   #2 (permalink)
The Castle BEC Pro is a decent unit and more than capable of supplying the electronics. In this scenario, an Rx pack is just unecessary extra weight and having to keep it charged is just an inconvenience. I would stick with the BEC.
K2Freak likes this.
Mark
So many heli's, so little time.
Crashalotjoe is offline        Reply With Quote Quick reply to this message
Old 02-27-2018, 10:20 AM   #3 (permalink)
I run a BEC off speed control on my 700! I dont even have a backup guard, I trust Hobbywing 100%!!
Spektrum Dx9
Trex 700x, Goblin 500S, Trex 470
Hobbywing, Ikon2, iCharger!
ssschmidt4 is offline        Reply With Quote Quick reply to this message
Old 02-27-2018, 11:51 AM   #4 (permalink)
Cool, thanks for the reply
Sent from my SM-S727VL using Tapatalk
Old 02-27-2018, 11:52 AM   #5 (permalink)
Oh alright. I ran a separate 2 cell a123 pack on my trex600 but it was wired for a rx pack when I got it.
Old 02-27-2018, 12:48 PM   #6 (permalink)
I run BECs on all my helis. Either an external BEC similar to the BEC Pro or my preference these days is an HV ESC with built in BEC which keeps the wiring neater.
K2Freak likes this.
Gob 700 Speed | Gob 770 Comp | Gob 630 Comp | Trex 700X | KDS Agile 7.2 | Compass 7HV U | Trex 600Pro (626 stretch) | Kasama Dune 600 | KDS Chase 360 | Devil 420 | XLPower 520
Grumpy_Old_Man is offline        Reply With Quote Quick reply to this message
Old 02-27-2018, 01:51 PM   #7 (permalink)
I run the Hobbywing BEC, I have had good experiences. I run a small 2s lipo (<500Mah) as backup in case of battery or ESC issues.
daboxe is offline        Reply With Quote Quick reply to this message
Old 02-27-2018, 02:41 PM   #8 (permalink)
Okay imma feel stupid but how do you also run a 2s lipo as back up?
Old 02-28-2018, 04:28 AM   #9 (permalink)
I'm a bit "belt and braces" when it comes to using BECs on large helis.
If I run a BEC, then I also run BEC guards (2x), and an Ultra Guard.
It makes it several times as expensive as an RX pack, but my new ESC has an excellent built in BEC so I might as well use it.
Current fleet: Goblin Thunder Sport, Trex 700L, Logo 600, Gaui X5, Trex 500 ESP, HiSKY HCP100S - Vbar Control - 5" and 3" FPV racing quads and a Taranis
Next heli(s): Logo 550, Logo 700 or a maybe an XL power Specter
Bigpops is offline        Reply With Quote Quick reply to this message
Old 02-28-2018, 05:21 AM   #10 (permalink)
You can do this but it is often necessary to put diodes in the BEC line to stop it being back-fed by the battery. You could also use a BEC guard instead of the diodes.
On the bigger heli's I use Ultra-Guards as the BEC back-up.
Mark
Old 02-28-2018, 09:15 AM   #11 (permalink)
...Castle creations 120 amp Ice 2 HV esc with a castle Pro BEC...
This CC 120HV ESC has an internal BEC, but it is not meant to be used with large helicopters, so make sure to disable it by disconnecting the red wire.
The CC BEC Pro works very well, but it suffers from a few limitations. One limitation is the failure concern with high input voltage. Since you will most likely be using a 12S power system, the recommendation is to supply power to your BEC Pro with only the first 6S battery of the series. Not only is the 6S input "easier" on the BEC Pro than 12S input, but the lower input voltage yields higher current (see pic below). Another limitation is that the BEC Pro has a very small capacitor, so there is a possibility of voltage "dips" when performing demanding maneuvers with power hungry servos. This voltage dip may be more accentuated with coreless when compared to brushless servos. There are some servo brands that are known to have more power demands. You can minimize these potential voltage dips by connecting a ready-made and inexpensive 4700uF capacitor (pic below) to either the FBL unit or the receiver.
Name:	Screen Shot 2018-02-28 at 10.14.22.jpg
Crashalotjoe likes this.
Protos 700 Evo, Goblin 700 KSE/380 KSE, Logo 700/550SX V2, Synergy E5; Spirit Pro/Neo VLink; VCT/Jeti DS-24/DX8 G2
Simulators (on Mac computer): neXt, Heli-X, AccuRC, RF8, AeroFly RC7 Ultimate
Citizen 259
curmudgeon is offline        Reply With Quote Quick reply to this message
Old 02-28-2018, 09:42 AM   #12 (permalink)
This is an endless... but by no means pointless debate...
I run a separate 2S pack on all my helicopters that are 600 size and larger.... I just do not want to risk my helicopters because I did not want to get a separate powerpack....
Now granted I fly scale helicopters and I am not (too) concerned with extra weight... but even in my pod and boom trainer I prefer a separate powerpack to be safe...
but as with everything there are pros and con's ... especially in the hard core 3D world....
gh
flipboy likes this.
goodhunting is offline        Reply With Quote Quick reply to this message
Old 02-28-2018, 11:39 AM   #13 (permalink)
I run the 2s lipo on a switch. The other end of the switch goes to the FBL (unused port). Plug in batteries, wait for FBL to initialize, turn on switch.
After flight, turn off switch, unplug batteries.
Cheap backup. Just be sure to run the ESC at the same voltage as you have the 2s battery charged to. I think all of mine are 8 volts or somewhere in that balll park.
Old 06-15-2018, 08:12 AM   #14 (permalink)
I'm planning on running the Hobbywing 25amp ubec, that comes with backup leads. I also have some 800mah two cell packs I was thinking of using for the backup pack. I would use it to power up the receiver before pugging in the main packs. Does this sound like a good setup?? Thanks.
Blade MCP-X Brushless, 300CFX, , Trex 450 Pro v2, Trex 600 ESP 6s 3GX v.3.1 and KDE head, Trex 700 Nitro, E-Conversion, Futaba 12Z controle!!
Stevendavis is offline        Reply With Quote Quick reply to this message
Old 06-20-2018, 06:48 PM   #15 (permalink)
I use the hobbywing bec with a scorpion backup guard on my 700 and 550
t rex 450 pro dfc, 550x,700x
dx6 g3
jaffo24 is offline        Reply With Quote Quick reply to this message
Old 06-20-2018, 10:31 PM   #16 (permalink)
I currently have a 2100 mAh LiFe battery on my 700L. It works fine but I bought a Western Robotics BEC to install when i get around to it.
Trex 700L, Trex 700N DFC HB gasser,Trex 700N V2 HB gasser, Trex 550E FBL all with BD3SX
rhodesengr is offline        Reply With Quote Quick reply to this message
Old 06-23-2018, 04:28 AM   #17 (permalink)
I prefer the simplicity of a 2S lipo.
Old 06-23-2018, 04:49 AM   #18 (permalink)
Which is a good solution for sure.
Downside is that you have to find a space on the heli to put the battery, you have to remember to charge and maintain the battery, also it adds about 150g or so to the weight of the heli. Plus you do of course have to run 'true' HV servos capable of operating at 8.4V. None of these things are show stoppers by any means but they are considerations.
I prefer the even simpler solution of an ESC with a built in BEC. Having said that I've used a 2S LiPo in the past and it worked perfectly well, so it's down to individual reference.
curmudgeon likes this.
Old 06-23-2018, 05:35 PM   #19 (permalink)
Depends on my heli size. On my 700, I use a 2s lipo with no BEC. I get 3 flights per charge. It is also nice for tuning because it is separate from the ESC. For my smaller heli's, I use a Western Robotics Hercules BEC. It is smaller than the Castle and works fantastic.
Trex 700L Ikon 2 / SAB Goblin 500 Sport Ikon 2 / HD Cell 500 Ikon 2
It isn't about if, it is about when!
Old 06-24-2018, 12:03 AM   #20 (permalink)
I ALWAYS run a separate BEC on my machines (anything larger than a 450).
I run Western Robotics BEC's exclusively.
The BEC shown has a power bus, eliminating the bottleneck of one or two 5 amp servo style connectors limiting the current flow to the servos.
KBDD-Team Captain/Compass Team Manager/Experience R/C/ Western Robotics Field Representative
6HV-U, Warp, 7HV,Knight Pro,Knight 3D, Atom, Atom Stretch, Odin II, 6HV, 3D Plus, Knight 50, Chronos
