Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > 270CFX
270CFX Blade 270CFX Helicopters Information and Help
Old 03-04-2018, 08:42 AM   #1 (permalink)
Default Linkage length
Hello,
I had so many crashes and rebuilding with my 270cfx. Don't get me wrong. I like the bird.
What are the factory length of the Linkage?
Thanks,
tomasito is offline        Reply With Quote Quick reply to this message
Old 03-04-2018, 08:51 PM   #2 (permalink)
The reason I am asking this because the negative pitch is not the same as the positive pitch. If I increase the negative to be equal to the positive pitch. The result will not be a balance -/+ pitch.
I think this can be fix mechanically. Any ideas how to do this.
Old 03-04-2018, 09:51 PM   #3 (permalink)
Mechanical adjustment to make the pos/neg pitch becoming equal...
Is simply a matter of lengthen or shorten each linkage the exact same amount of turns
Doing so will raise/lower the swash position at servo center
If your swash is level...this adjustment doesn't change that...but you must start with the swash perfectly level - I'd recommend setting zero pitch at the same time
Only the max throw of the swash in each direction changes...thereby changing the pitch for pos/neg so they are equal
This method does not set zero pitch...it just changes the ratio of pos/neg
Steps in order:
1) Level the swash
2) set zero pitch
3) Check pos/neg
4) Adjust pos/neg with equal linkage turns
nCPX(3)*mCPX(25)*130X(10)*130X-L(6)*180CFX(3)*300X/CFX(3)
450X(7)*470LP*GauiX3*nanoQX*180QX*DX9*HF180060*AMA 988253
JonJet is online now        Reply With Quote Quick reply to this message
Old 03-05-2018, 10:49 PM   #4 (permalink)
In #2 - set zero pitch, is this using the beastx?
