Like Tree2Likes
Old 10-11-2017, 08:25 PM   #21 (permalink)
Originally Posted by sprokkel View Post
Today I got the new reciever mount iT is much stiffer then the original one. The weight difference is 4 grams heavier then the original. So that is nice. Mounted it today and tomorrow I will do some flights and compare the logs.
Cheers
good news.
I'm waiting.
XLPower Brazil - www.xlpower-rc.com.br
thallescsantiago is offline        Reply With Quote Quick reply to this message
Old 10-11-2017, 08:27 PM   #22 (permalink)
Originally Posted by kazanci View Post
I put the fbl unit on top of plastic receiver mount and I don't have any wag or problem.
Can you try that?
Hi, what's your fbl unit?
If it's NEO, could you post an picture?
Old 10-11-2017, 08:35 PM   #23 (permalink)
Originally Posted by msallua View Post
Good flight!,
Do you have an excellent flight time for your flying style , what brand and how many mah of lipo do you use?
Which voltage do you have in the end of the flight?
Thanks in advance
Hi,
thanks man, I use 2x gens ace new generation 6s 5000mah 60c and my time in vbc is 3:30, on each flight it is consumed between 3500mah to 3800mah and I get 3.74 ~ 3.77v per cell. But on this flight I passed the time and consumed 4000mah and the voltage was 3.71. Pack with about 100 flights. 100 flights in this battery pack.
Cheers.
Old 10-12-2017, 04:56 AM   #24 (permalink)
Sure,
I'm using spirit pro,
here is how it looks from side
kazanci is online now        Reply With Quote Quick reply to this message
Old 10-12-2017, 10:21 AM   #25 (permalink)
So......
I have it mounted and did two test flight just some tic toc side upright nose down. Funnels some hurricanes it does fly very nice but unfortunately I see the same amount of extreme vibrations. Like 4 times in one flight. I do notice that the high vibration messages are less. To me it is not really worth to upgrade to the new nose although it?s much stiffer.
So what to do now. I can run a bench test blades off and then with blades to see the difference. Could also mount the unit with 2 mm tape instead of 1.2.
I did the two test with 2250 rpm and vtx blades 696.
The thing is are we not over concerned... if you had a beast u would not ev n see the vibes..
mounting the vbar neo with v link between the motor and esc is possible but I think a bad idea, this was also confirmed to me by mikado support.
Kind regards
Dennis
sprokkel is offline        Reply With Quote Quick reply to this message
Old 10-12-2017, 10:31 AM   #26 (permalink)
We could also try the external
sensor...
Old 10-12-2017, 01:45 PM   #27 (permalink)
Sure,
Attachment 725682
Thanks for this, friend, this unit fbl is smaller than neo.
Old 10-12-2017, 02:00 PM   #28 (permalink)
So......
Kind regards
Dennis
My hopes are gone.
I think I'll try to install the NEO directly into the carbon frame. I studied a possible location, and found the end of the Bottom Plate, this location seems ideal for the unit to work properly because that is quite firm.
I think the external sensor at the top of the box is a solution, but I've gotten used to the feeling of the NEO's internal sensor.
Cheers
Thalles
Old 10-12-2017, 03:36 PM   #29 (permalink)
You are welcome buddy, I think you should give it a try with external sensor at that position.
It has been over 100 flights, I did not see a important event at logs.
Old 10-12-2017, 03:50 PM   #30 (permalink)
so....
my idea about mounting it in the back...
i just read some of the logs of my gaui x5 which has it mounted in the bottom plate also carbon.. i was shocked... i only see extreme vibration messages.... like 20 per flight or so on each flight... and only extreme vibrations, no high or raised...
i never noticed anystrange behaviour of the heli in the air. and never saw an Aileron Sensor Value Out Of Range message.
what i can say is that the new nose improved it a little bit. but since it is stiff as hell i dont think it will make any difference. also the tail assembly is mounted in the back and that can also cause vibrations.
i think i will just fly it we are going mental here.. the Aileron Sensor Value Out Of Range needs to be fixed on your side though.
what you could do to check if its a faulty servo which also can be the case , swap the two aileron servos and see if it behaves opposite to what you had experienced..
tomorrow morning i will do a bench test without the blades and see what i measure then.
cheers,
Dennis
Old 10-12-2017, 06:50 PM   #31 (permalink)
Hi guys,
I decided to change the location of the FBL. Wow, what a hard work!
I teste in bench with the tail blade installed.
Before the vibration was 150, now it's 48 in the vbc spektrum analyzer, I'm very optimistic about that improvement. Tomorrow is practice day, I'll tell you if the "Aileron Sensor Value Out of Range" problem is gone.
Thank you so much of your interaction!
Here are some photos of this modification:
ID:	725754   Click image for larger version
ID:	725755   Click image for larger version
ID:	725756   Click image for larger version
ID:	725757   Click image for larger version
ID:	725759   Click image for larger version
Martinshelis likes this.
Old 10-13-2017, 04:43 AM   #32 (permalink)
hi,
It looks very nice and i really hope that u dont have servos out of range anymore.
this morning i did a bench test and saw some peaks during spool up of 250. when at full throttle i saw a steady value of 60.this was without the tails.
with tail blades on i saw a value of 62 which looks nice.
i will spool it up later with the mains on the field and i will check again.
regards,
Dennis
Old 10-13-2017, 06:30 AM   #33 (permalink)
Dennis.. hope you will have some good result then.
See you tomorrow?
KDS Chase 360 | Align Trex 600NSP | Align Trex 700E | Align Trex 700X
Sirolf is offline        Reply With Quote Quick reply to this message
Old 10-13-2017, 01:40 PM   #34 (permalink)
Hi everyone, I bring good news.
The problem "aileron sensor value out of range" is gone, the log is cleaner of extreme events. The heli flies a lot better, it's like I've been flying another heli. It was worth this work.
Trex 700X - Aileron Sensor Value Out Of Range Problem Solved (4 min 0 sec)
Trex 700X - Treinando Caixa Aberta - Thalles Santiago - 13/10/2017 (3 min 54 sec)
Old 10-13-2017, 03:50 PM   #35 (permalink)
Good man! Iam happy for you! Enjoy flying
Old 01-30-2018, 07:45 AM   #36 (permalink)
MINE ALSO HAVE THIS PROBLEM CAUSE TO CRASH OF MY 700X,IT ALSO SHOWN THE ALIERON SENSOR AND ELEVATOR OUT OF RANGE IN THE VBC!!! AFTER THAT I BOUIGHT THE NEW RECEIVER MOUNT AND I MODIFIED THE PIECE OF THE METAL TO TAP THE BOTTOM OF THE MOUNT LET SEE THE RESULT BUT I DID NOT PUT BACK THE ELETRONIC YET.
ID:	736228   Click image for larger version
imloo3 is online now        Reply With Quote Quick reply to this message
Old 03-07-2018, 06:49 AM   #37 (permalink)
Hey guys, I'm having a similar problem. I mounted my VBar on the left side of the receiver mount (just where the fbl unit is supposed to sit according to Align pictures). Unfortunately the mount seems to be slightly bent. This means the VBar is slightly leaned to the left. So it's not an 90 angle between VBar and main shaft, but more like 91-91.5 (measured with digital gauge)
Anyone with the same problem and suggestions how to solve this?
I feel like this may impact flight performance.
coom1234 is offline        Reply With Quote Quick reply to this message
Old 03-07-2018, 10:57 AM   #38 (permalink)
I have never mounted a Vbar, but this is where I mounted my Ikon2. Several flights with no problems at all.
Spektrum Dx9
Trex 700x, Goblin 500S, Trex 470
Hobbywing, Ikon2, iCharger!
ssschmidt4 is offline        Reply With Quote Quick reply to this message
Old 03-07-2018, 11:25 AM   #39 (permalink)
Silly question., I just finished building my 700x. While installing the Icon FBL unit and landing the servo wires I have noticed that the reinforced servo wires are very stiff and there is no way I can install them that they aren't a little ridged. I't making me a little uncomfortable. Could this be the source of the vibration issues everyone is having? I have had the vibration log going while spinning up the motor with out blades on and don't see anything to be concerned with but it is still making me a little nervous.
Helidork
Butch Miller is offline        Reply With Quote Quick reply to this message
