Like Tree4Likes
Old 03-07-2018, 06:28 PM   #81 (permalink)
Originally Posted by Learn'in2Fly View Post
Thanks "TheBum"!
I tried your suggestion and changed "Sensor at CH5" to yes. Didn't help. The ESC is connected to CH1. What I'm talking about is the lead wire from the data port on the ESC to the iKon. Attached is a link to the readme file from MHS. Go to page 2, #1 and you can see what I mean.
http://update.mshbrain.com/Software/..._telemetry.pdf
Thanks,
Gary
Did you power cycle the transmitter after changing the "Sensor" setting? The transmitter will not pick up any new modules beyond 30 seconds after it links up with the receiver.
HeliFreak Support
Graupner MZ-32
Old 03-07-2018, 06:44 PM   #82 (permalink)
Yes I did. Made no difference. I also read on a forum that someone had the same problem and he reloaded the firmware on the ESC and it started to work. I tried that with no success. I also tried a different receiver and connection leads. Nothing has worked!
Learn'in2Fly is offline        Reply With Quote Quick reply to this message
Old 03-09-2018, 07:41 AM   #83 (permalink)
Started a new thread on my problem.
Old 03-11-2018, 06:25 PM   #84 (permalink)
Does anyone know how to access brain telemetery on the mz-12 pro? I've made the special sumd cable and ran it from sat 1 to port 6 on my gr-12l. Channel 5 (T) is connected to channel 3 on the brain. Heli works as is, I just can't get any data or access the brain menu.
I'm attaching images of my cable ends to very my pins are in the correct position.
Sumd is set to yes as well as data on channel 5.
Any ideas?
Sent from my Pixel 2 using Tapatalk
rlane4osu is offline        Reply With Quote Quick reply to this message
Old 06-09-2018, 12:28 PM   #85 (permalink)
So ive been on the vcontrol neo wagon for awhile and just sold all my mikado gear. I just bought a graupner mz24 pro radio and will be using the best brain fbl controller once again. Brain units have the best tail behavior out of any fbl unit Ive ever used. My question is (how is the integration between graupner and msh brain). Is it up to speed?
dbirds2 is offline        Reply With Quote Quick reply to this message
Old 06-09-2018, 02:01 PM   #86 (permalink)
Welcome back!
Update your HoTT receiver to the latest firmware if you want a really fast behavior of Brain2 integration and telemetry.
www.msh-electronics.com
BrainDev is offline        Reply With Quote Quick reply to this message
Old 08-19-2018, 08:27 AM   #87 (permalink)
Can anyone with the MZ-32 share screenshots of the Brain integration?
TIA
(2) Protos Max Leggero/VBarNeo/Tribunus200/Xnova/VTX717;rEVO715, Logo 200, VBar Control Touch
Caeguy is offline        Reply With Quote Quick reply to this message
Old 08-20-2018, 01:48 PM   #88 (permalink)
TIA
I'll try to get some posted this evening. The textual part of the menus is the same, but the navigation buttons are better IMO.
HeliFreak Support
Graupner MZ-32
Old 08-20-2018, 07:00 PM   #89 (permalink)
As requested. Please forgive the reflections: I took these at the back of my car in the driveway.
Felix the cat and Caeguy like this.
Old 08-20-2018, 07:33 PM   #90 (permalink)
^^ Looks good...thanks
Old 08-26-2018, 01:33 PM   #91 (permalink)
closed
Hi there,
Which radio manufacturers are already integrated with Brain or are willing to do so, please? Jeti, Spektrum and Graupner?
I fly Futaba and as far as I know they will not integrate with Brain. So, I am planing to change radio brands.
Thanks.
Trex600EFLStretched-Vbar, Logo600SE-Vbar, XLPower700-Vbar, Trex150X, Futaba 14SG, VControl
hilarious is offline        Reply With Quote Quick reply to this message
Old 08-26-2018, 01:50 PM   #92 (permalink)
Originally Posted by hilarious View Post
Hi there,
Thanks.
You answered your own question: Jeti, Spektrum, and Graupner.
HeliFreak Support
Graupner MZ-32
Old 08-26-2018, 02:00 PM   #93 (permalink)
closed
hi,
I never had a graupner before. Will ikon/brain integrate perfectly with an mz-12 pro or a bigger radio model would be needed?
thanks.
Old 08-26-2018, 02:17 PM   #94 (permalink)
Default MSH Brain and Graupner integration
The Brain2/iKON2 should integrate fine. All that is required is the Settings & Data View screen, which the MZ-12 Pro has.
Old 08-06-2019, 10:40 PM   #95 (permalink)
Just a note, if you can't get the GR-12L integration working after verifying all wiring is correct and the rx is set up correctly, try the beta 2.05 fw update if you are running the 1.92. Spent the better part of tonight tearing my hair out to find that out. Current fw on the GR-16 is working fine.
Brute71 is offline        Reply With Quote Quick reply to this message
