Like Tree220Likes
Old 04-29-2018, 06:19 PM   #2821 (permalink)
Originally Posted by corrosionate View Post
Iím afraid I donít have a good picture of it, but I stripped the wire and soldered it to the little tabs coming off the back. Multiple prongs are available for + and -, so I was able to sandwitch the wire between two and solder each wire to two of them. I covered the whole solder joint up with the liquid electrical tape goop. Then thereís like a jumper thatís needed to make it power on or something. I did all that a couple years ago so I canít remember exactly Lol. I used the goop to hold the jumper from coming unplugged too.
I used a wicked hot soldering iron so I could work quickly in hopes of getting a good solder joint without melting the solder that holds the prongs to the circuit board inside. I find that a hotter iron works better in those cases because you donít have to heat things up as long.
I hope that helps. If I can get a photo of the connection point I will, but you canít see much cus I Goobered it all up with the liquid electrical tape to protect it from something shorting it out. Maybe I can find a pic from back in the day when I soldered it up. Iíll look.
Oh. I got some of the mating connector and plan to design a PCB for it. Though, for now, I soldered some wires to the mating connector and wrapped it all up in electrical tape so I could test things.
Jeti DS14us -- TT e700 -- 6s Logo600se UL -- Logo600-3d -- Logo500 UL -- Charge Case
prototype3a is offline        Reply With Quote Quick reply to this message
Old 04-30-2018, 12:11 AM   #2822 (permalink)
Finished...
Sneeky_Pete is offline        Reply With Quote Quick reply to this message
Old 05-24-2018, 06:50 PM   #2823 (permalink)
Quick question guys....
I'm about to start putting my charger case together and was wondering what size thick of plexiglass will be best or optimal for the inside panel ?
Thanks.
Sent from my SM-N910W8 using Tapatalk
Scorny is offline        Reply With Quote Quick reply to this message
Old 07-09-2018, 09:49 PM   #2824 (permalink)
at least 8mm and up to 12mm
Goblin 650 BT | Goblin 380 | Rush 750 V2 Stretch | Goblin 500 V1
Vcontrol
Citizen 709
higham83 is offline        Reply With Quote Quick reply to this message
Old 07-13-2018, 05:59 PM   #2825 (permalink)
Default Who needs batteries...
Here is mine. Going to eliminate batteries altogether. Feed directly to my heli. Needs a lot of voltage though. There are power lines near my field.
ben_beyer, Dsss, AndyO and 2 others like this.
reichly is offline        Reply With Quote Quick reply to this message
Old 07-17-2018, 01:00 PM   #2826 (permalink)
My Charger case:
Yellow pelicase
2000watt PSU @ 24v
3mm plexiglass with support
1 x T8 charger 1000watt
2x T6 chargers 600watt
1 small 150watt ISDT charger
Fan 50x50mm.
3D printed PDB for 5 chargers.
Rock solid!
ID:	750978   Click image for larger version
terhoutd likes this.
Wind89 is offline        Reply With Quote Quick reply to this message
Old 07-30-2018, 10:27 PM   #2827 (permalink)
Thank you...👍
Sent from my SM-N950W using Tapatalk
Old 07-31-2018, 07:25 PM   #2828 (permalink)
Default My Case
This one houses a single 20A charger, 600 watt power supply, cooling fans all in a Pelican housing. Works great.
I'm in the process of building a similar layout with 2 x 206b (20A) chargers and a 1200 watt power supply.
I'm about to post the single charger set-up in classifieds if anyone is interested.
TNJET
Tnjet is online now        Reply With Quote Quick reply to this message
Old 08-01-2018, 10:00 AM   #2829 (permalink)
Built mine up with a 10mm MDF deck coated with CF-effect vinyl, 1150W 25vdc PSU (Coolice) and PL6 + MPA board. Just fitted a USB socket too. Also has a 12vdc banana socket output on the side. Done on the cheap, happy with it so far!
ID:	752207   Click image for larger version
Coolice likes this.
Synergy 696
Minicopter Triabolo 700BE
MSH Protos 380Evo
MSH Brain2 Beta Team & Egodrift Team
AndyO is online now        Reply With Quote Quick reply to this message
Old 08-01-2018, 03:34 PM   #2830 (permalink)
just finished mine,
Try to throw everything in it,I think the result is pretty decent.
Pelican 1510,dual pl6, 6s 90ah battery pack, 220v powersupply, and a low-fi Bluetooth speaker system.
ID:	752215   Click image for larger version
ID:	752216   Click image for larger version
higham83 likes this.
Chafflare is offline        Reply With Quote Quick reply to this message
Old 08-02-2018, 06:50 PM   #2831 (permalink)
308 duo with a power matched industrial power supply below in a Seahorse SE-520
Old 08-06-2018, 07:53 PM   #2832 (permalink)
I built this a few years back,thanks to forum member,pctomlin.
I'm about to build another one using my PL8 in a case for the field and use this as a home charger setup.
Old 08-07-2018, 07:37 AM   #2833 (permalink)
Look forward to seeing the new one, keep us posted.
Paul
Agile 5.5 - Q 4125-1100, YEP 120, Brain2 HD FBL / Outrage 550 - HK4020-1390, Edge 120, Brain2 HD
Rave Ballistic FSO - Q 4530-500, Edge 160HV, Brain2 HD / Protos Max V2 - MSH 4530-500, Edge 160HV, Brain2 HD
pctomlin is offline        Reply With Quote Quick reply to this message
Old 08-09-2018, 04:38 AM   #2834 (permalink)
This is my case without the fans just remove it and off you go!
ID:	752914   Click image for larger version
ID:	752915   Click image for larger version
MikelG likes this.
Following Jesus !!!!! My Lord, He Never changes!
1#SAB RAW Scorpion Tribunus V2 300A ,
NEO-Vcontrol Touch,The only Way to Fly!
2#SAB Kraken 700 Scorpion Tribunus V2 200A
Helicrazy2 is offline        Reply With Quote Quick reply to this message
Old 08-09-2018, 05:03 PM   #2835 (permalink)
Had this idea for a year or so and finally had it made.
Amazing charging solution for Doug Darby. One of a kind! (10 min 51 sec)
Breezyjr, higham83, Grimmy and 2 others like this.
doug
TRM Power - RC Racing Engines - - Blackout Mods Conversions - - VP Racing / Powermaster Fuels - - Gas-Powered-Helicopters.com
Doug Darby is offline        Reply With Quote Quick reply to this message
Old 08-09-2018, 10:09 PM   #2836 (permalink)
Looks great. Just when I thought I couldn't possibly be any more jealous of Doug's toy hauler
Doug Darby likes this.
Too many helis, too little time
AliTajeldin is offline        Reply With Quote Quick reply to this message
Old 08-13-2018, 04:13 AM   #2837 (permalink)
Default Charging Case
220v & 12v Charging Case
ID:	753215   Click image for larger version
ID:	753216   Click image for larger version
ID:	753217   Click image for larger version
ID:	753218   Click image for larger version
ID:	753220   Click image for larger version
ID:	753221   Click image for larger version
ID:	753222   Click image for larger version
ID:	753223   Click image for larger version
andriesb is offline        Reply With Quote Quick reply to this message
Old 08-15-2018, 08:15 AM   #2838 (permalink)
You've done well here mate! killer effort and nice Chargers! Hows the D2 go?
Vcontrol
Citizen 709
Old 08-19-2018, 12:41 PM   #2839 (permalink)
Default Ecage ver2.0
do a little update..
decide to add a bump a tablet, two more pl6 and one more power supply...
now it's bascially a big chunk of metal....
ID:	753661   Click image for larger version
ID:	753662   Click image for larger version
ID:	753663   Click image for larger version
ID:	753664   Click image for larger version
ID:	753666   Click image for larger version
ID:	753667   Click image for larger version
ID:	753668   Click image for larger version
kaiserliu likes this.
Old 08-19-2018, 04:33 PM   #2840 (permalink)
Revolectrix will give you a STEP file for their charger cases if you ask. Junsi, on the other hand, claims they have no such files...
