Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Nano CPS
Like Tree29Likes
Old 03-04-2019, 11:48 PM   #101 (permalink)
Originally Posted by Psycho_dad View Post
grips and hub made a 'little' difference, the most noticable upgrade is the metal swashplate Microheli.
I'm struggling with my stockmotor again....I'm considering to make it brushless.
Yup, I will never use a stock swash on the CPS ever again. Microheli swash made it a whole new bird, an enjoyable on. Everything else will always remain stock though. Except the motor. I only run MicroMotorWarehouse motors in mine. I'm saving the brushless mod for the new S2 when I get it in a few weeks. Assuming I like the S2 better than the CPS
Nano CPS - 230s - Align 470LT - Goblin 570 - Goblin Black Thunder 700 - Rustler VXL - Hubsan H107D+ X4 FPV - LaTrax Alias
motoxxxman is offline        Reply With Quote Quick reply to this message
Old 04-21-2019, 10:22 AM   #102 (permalink)
started to learn inverted flights with my cps... and goddam*** it's hard. I have no issues performing an inverted hover (nose-in) but as soon as I try to make an "8" my brain goes bananas and there goes dumb thumbing
so for now ==> learn inverted hover tail-in until my brain is able to switch between inverted nose-in and tail-in.
THE HANGAR
Nano CPX - Nano CPS (2) - Nano S2 (3) - Micro Apache - 180CFX (2) - 230S HUEY - 230S V2 - 250 CFX - 270 Fusion (2) - 270 CFX (2) - 360 CFX (2) - Align 450 PRO - Align 150X ** Spektrum DX8E *** Hangar out: MCPX BL - 130S - 230S V1 Trio
Psycho_dad is offline        Reply With Quote Quick reply to this message
Old 04-21-2019, 10:58 AM   #103 (permalink)
Nanos are great for this, but I had to spend hours on the simulator first. Even now, after months of practice, my inverted flight is very sloppy.
navigator2011
Oxy2 190 FE / Oxy2 190 Sport / Fusion 180 / Blade 150S / Trex 150X / Blade mCPX BL2 / Brushless Nano S2 / Spektrum DX9.
Old 04-21-2019, 05:43 PM   #104 (permalink)
I like using the Nano even in the sim. To me it flies very realistic to life with the same power. The Nano was the very first helicopter that got me into the hobby and to this day it is still one of my absolute favorites to learn on.
The inverted flight will take a lot of time and patience to master but what a great feeling when you get it down!
Chris1683 is offline        Reply With Quote Quick reply to this message
Old 05-07-2019, 07:33 AM   #105 (permalink)
Default trying to fix my cps
For the past year I had to put up with this minor toilet bowl effect of my CPS. Today I replaced the entire rotor head using brand new parts. Also replaced main shaft, main gear, new main motor, new tail rotor, bearings on the frame. I also serviced all servos. Done the blade tracking. Re-leveled the swash. Tried all the lipos that I have. I also made sure there is no binding in all moving parts. But sadly the TBE is still there.
I'm starting to think it could be my main board or its bad-shaped antenna. As flybars were used to stabilize the heli, any damage or binding on flybars will certainly cause TBE in the old days that's what I heard. So I suppose fault in a flybarless control unit could also cause TBE?
I have a spare ESC board with broken battery wires, am going to solder a new power connector tomorrow to find out if it will solve the issue.
Heli-X, DX6 G3, DXe, V977, K110, 130S, Nano CPS x 4, MCP S, Nano S2. since 08/2017.
koopa137 is offline        Reply With Quote Quick reply to this message
Old 05-07-2019, 09:13 AM   #106 (permalink)
Could be the feathering shaft is slightly too tight?
navigator2011
Old 05-07-2019, 09:39 AM   #107 (permalink)
Yeah, I bet something is too tight. Check also the blade grip tightness. I had TBE when I cranked down the screws.
xoexoe is offline        Reply With Quote Quick reply to this message
Old 05-08-2019, 04:18 AM   #108 (permalink)
No there was no binding in the blade grips at all, they can free fall without linkages. Today I repaired the spare ESC board and replaced the current one, nope didn't improve at all. Then I noticed the left servo acts funny, its horn goes a little bit sideway when being moved up and down, and there is slop on its gear. So I replaced that servo with a spare. Bingo! TBE was greatly reduced. I then replaced the main blades with brand new MicroHeli high performance blades, Finally, after all these hassles the TBE has been eliminated
xoexoe likes this.
Old 05-08-2019, 09:51 AM   #109 (permalink)
Glad to hear you solved it! Seems like there's 101 causes for a given symptom.
Brian — Oxy 2 & 4 Max — S2 & CP X — 150X — iK2N/Brain2/Spirit — Horus X10S — OpenTX — AccuRC —
Old 05-09-2019, 06:48 AM   #110 (permalink)
Lol thanks! So the tbe was cured but here comes a new problem: occasionally it gets the shakes, more like a wet dog shake type. I suspected it was the spare left servo I just installed that causes this. Then I opened it up to inspect. Woah looks like the metal strip was covered by a layer of ink! So I cleaned it up with a qtip lightly soaked in isopropyl acohol. Will test fly again this weekend.
Sent from my EVA-L09 using Tapatalk
Old 05-09-2019, 11:05 AM   #111 (permalink)
That servo looked very dirty! Hope cleaning it fixes your problem.
navigator2011
Old 05-09-2019, 04:10 PM   #112 (permalink)
The servos can always use a good cleaning after about 30 or so flights - more often if you are crashing in or around dirt / dust.
The "wet dog" shake is likely slop in the servo. If you can wiggle the white arm of the servo where the rod connects and move it up and down a lot, it needs to be retightened. I usually chip off the layer of CA glue on the top of the nut with a tweezer, screw it down with the included spindle tool and then place a dab of CA on top of the nut and let it dry. This will usually clear up the shakes.
Old 05-11-2019, 04:40 PM   #113 (permalink)
Practiced neat, tight piros in a small space. That was ugly, and I thought I was okay at piros.
130X parts wanted! The Precious! You has the Precious!
Mrowka is offline        Reply With Quote Quick reply to this message
Old 10-06-2019, 03:10 PM   #114 (permalink)
Yesterday I crashed my cps in mid-air... went from inverted to normal flying and right after flipping the heli in normal position, it was 100% incontrollable.
Picked up the heli and noticed immediately there was something wrong with my Microheli swash... it was missing the small metal bar (which goes into the original anti rotation bracket of the cps) .
Will need to find a replacement part or need to install the MH anti-rotation bracket (= PITA).
THE HANGAR
Old 10-07-2019, 08:36 PM   #115 (permalink)
Default What did you do with your CPS today?
I have the antirotation bracket installed instead of using the stock plastic one.
Yep, total PITA to deal with. I only have to unscrew and reinstall it when switching frames. But it’s not something I look forward to.
Supposedly it’s more precise than the stock one since it inhibits elevator-aileron mixing. But meh.
Old 10-13-2019, 12:27 PM   #116 (permalink)
Found a replacement part ==> the axis of an old brushed ncps motor
Just cut the old motor in pieces and used the axis, its the same diameter (1mm) as the 'missing' metal bar in the Microheli swash.
THE HANGAR
Old 11-08-2019, 03:19 PM   #117 (permalink)
the saga continues...
I needed to replace the tailboom with tail rotor on my cps...no biggie, just remove tailplug from main board, pull out tail boom, insert new tailboom and insert plug in main board. Took about 10 minutes and it was good to go.... so I thought
After 20 seconds in the air, heli started spinning like hell. Picked up the heli and noticed tail rotor did not work at all. Re-checked the plug, checked all wiring, checked the main board, what else could be wrong?
I used a brand new tailboom with rotor, could this be defective out of the box? Okay, replace brand new tailboom with another working tailboom... same result, tail rotor does not respond.
All of the sudden my brushless ESC starts to smoke
Damage Result:
main board ==> gone
brushless ESC ==> gone (smoked)
brushless main motor ==> gone
THE HANGAR
Old 11-08-2019, 03:24 PM   #118 (permalink)
Oh, dude, sorry to hear you had a complete Fatal Error!
navigator2011
Old 11-08-2019, 04:41 PM   #119 (permalink)
Thanks Navigator2011. I'm left now with one working CPS and since I'm not that keen on the S2, I'm searching for a second cps (brand new)...I'm aware this will be a difficult journey since most of the nano cps have been sold out.
To ease the pain, I'm taking delivery of my Align 150X super combo tomorrow 09/11/19 (finally pulled the trigger )
THE HANGAR
Old 11-08-2019, 05:45 PM   #120 (permalink)
Congrats on the 150X -- that's still my favorite micro-heli. Been flying my S2 like crazy lately, trying to learn inverted tail first flight. Once I've sort of got that down, then I'll be back to the 150X. Just don't want to crash the 150X as much as I've been crashing the S2.
navigator2011
