Like Tree203Likes
Old 05-05-2019, 05:50 PM   #1021 (permalink)
Originally Posted by BrokeDad View Post
Very simple. Put on a longer tail boom from a 250 or make one (aluminum knitting needles work good) then just install 250mm or 255mm main blades. DONE
I use a 450 canopy for better visibility (old eyes) which fits fine. If all you want to do is fly around upright you can put up to a 2300mAh lipo under that and go 20 minutes.
What is the length of the 250 boom?
thank you
captjack01 is online now        Reply With Quote Quick reply to this message
Old 05-05-2019, 05:58 PM   #1022 (permalink)
thank you
You can make it any length you like if you make your own from knitting needles. The ones I've seen for 250 helis are generally 241-245 mm. You may have to extend the tail wires depending on how you route them. I just spliced in a little extra.
If you want to try the bigger blades alone you can just put them on and it will work with the standard boom for sport flying.
Team USED
Shape S8,G700/G500,Shuttle 550,Trex 500 EFL Pro,Oxy 3 (2),B400 (7),450X,360CFX,Fusion 270,230S (V1/V2),200S,120S,Nano (CPS/S2),K110/120/130
Old 05-07-2019, 09:02 PM   #1023 (permalink)
I want to use one of my 230's just for fast sport flying. don't know if I should stretch it, or buy a speed fuselage from Microheli
Harder, Faster, Louder.....works for Me !
Brick is offline        Reply With Quote Quick reply to this message
Old 05-08-2019, 04:41 PM   #1024 (permalink)
It was super windy (25-30 mph) and gusty today but the 255S did very well using 1350 packs for some extra weight.
lucidchaos likes this.
Team USED
Old 05-09-2019, 09:41 AM   #1025 (permalink)
I got my V2 a little over a week ago. I had been flying a sim and Nano S2 for a few weeks before that.
I had been flying the V2 in the back yard practicing my hovers, pirouettes, and very small figure 8s. Trying to get comfortable with the idea of the bigger heli.
Yesterday evening I took it out to the local park and let it stretch its wings. It's so much more fun flying when It has room to move around. I'm still ran a few packs of upright pirouettes, but then let it loose with some large almost stall turns, and figure 8s. I was starting to get a little too comfortable with the speed and distance so I had to reel it back in to settle my nerves.
I played hooky from work this morning to visit the park again. I had my first actual crash which bent the tailboom a little. Gently bent it back into place, and got back up in the air. I started to get a lot smoother on my sweeping figure 8s. (smooth right turns still elude me sometimes though)
I came back with a big grin.
Brick likes this.
phlakvest is online now        Reply With Quote Quick reply to this message
Old 05-10-2019, 09:19 AM   #1026 (permalink)
Skipping work to fly, that's commitment to a hobby. Or some would say addiction
xoexoe and phlakvest like this.
T-Rex 250 450x 300x 180CFX MCPX-BL B400 130X MCPX 230S NANO-CPX NANO-CPS MSRX 120 SR MSR MCX
IF IT CAN'T BE FIXED WITH DENTAL FLOSS, THEN IT CAN'T BE FIXED..LOL
Liduno is offline        Reply With Quote Quick reply to this message
Old 05-10-2019, 01:24 PM   #1027 (permalink)
Default What did you do with your Blade 230s today?
Skipping? No. You mean reallocating work schedules to increase future productivity.
Which means procrastinate so youíll be busy later.
Thatís a big thumbs up from me!
xoexoe is online now        Reply With Quote Quick reply to this message
Old 05-11-2019, 08:22 AM   #1028 (permalink)
I've taken a "sick" day to work on and fly helis. But really, it's like a mental health day. With all the free OT given to my company, I certainly don't feel guilty for a break here and there. I've had plenty of my weekends and evenings taken by work.
Heli on and take your mental health breaks fellas.
blarks and BrokeDad like this.
Thickfog is online now        Reply With Quote Quick reply to this message
Old 05-11-2019, 03:45 PM   #1029 (permalink)
Finally found time to put a new frame on. Well, put everything on a new frame is more accurate. Thereís nothing fun about it.
Also wrapped some orange electrical tape around the boom for added visibility. Iím dropping the extra weight of the Microheli full fuse.
Originally Posted by xoexoe View Post
This weekend was all about crashing.
My 230 S V2 frame was already cracked from a previous crash. Today a moderate crash caused big damage.
New frame time.
Old 05-16-2019, 08:22 AM   #1030 (permalink)
Looks like you might have hit the ground upside down there. I did that plenty of time learning to do inverted circuits. Replacing the frame is a pain of a job. I really hate those little screws and the fact that all the electrical connections need to come apart.
I have one heli with the Rakon frame which is easier to work with but I don't like the way the tail boom is held and the bracket breaks easily. I am working on an idea I have where the tail boom is held by two rubber grommets. I have found some that are quite a tight push fit on the tail boom. The object is to mount these in a thin sheet metal bracket so the tail boom is a push in affair with just friction holding it. Also the rubber might be a good vibration isolator. I will post pictures when I can get my camera talking to my computer again.
Old 05-16-2019, 08:50 AM   #1031 (permalink)
Some of the screws are short and lose grip/spin easily if you tighten just a bit too much. I've replaced several of them with longer and slightly larger ones. The ones holding the boom and motor mount come to mind.
Team USED
Old 05-18-2019, 08:12 PM   #1032 (permalink)
I was flying my V1 today, I accidently hit the throttle hold switch like 70 feet up. I switched it back....it didn't like that ! popped off a dog bone and it dropped like a rock. I figured all servos would have been trashed. I was surprised only thing broke was the frame ( in the usual spot ).
This thing can take a beating
Old 05-19-2019, 12:28 PM   #1033 (permalink)
Default Man Down. Temporarily.
I had my first crash resulting in broken parts. I was practicing my stall turns, came out a little too low, and either caught a wind gust, or just didn't have enough power and smacked the ground.
I bent the tail boom, and broke the control horn on a blade grip.
I straightened out the boom, and replaced the grip, but I'm a little concerned about the crease in the boom.
I flew it some after the repairs and it didn't have any issues, but I would hate for the boom to fail mid flight. I have a replacement boom, and some knitting needles on the way, but should I reinforce it a little with some epoxy and carbon tow in the mean time?
Also after the crash I was feeling a little brave and did my first flip. The first one was at IU1, and felt like it took forever to continue once I made it upside down. I switched to IU2, and those ones felt a lot better, but after a handful of flips I was shaking too much, and had to land.
Old 05-19-2019, 03:52 PM   #1034 (permalink)
Shame you lost the dog bone otherwise you would have been ok. I would say once you have hit TH leave it. Unless you have really hard ground it will usually survive ok. I fly over grass and the heli will be ok hitting that . If it is high up it usually orientates upright so the skis hit first but I have never broken them in a dead stick landing.
Old 05-19-2019, 07:00 PM   #1035 (permalink)
Yesterday I was doing tic-tocs and let the motor bog a bit. Tried to level it out but bounced the tail pretty good. It still flew but the tail was screaming to keep up.
Fortunately, I had spares. Replaced the tail rotor and put it back in the air.
The tail still couldn't keep up. Wasn't sure if it was motor bearings or what.
To keep a long story short, I took the motor off and checked everything for smoothness and balance. It checked out. Took it out again and the tail was just whining like nobody's business.
Eureka.
Flipped the tail rotor. Holds like a boss
This was the first crash that actually did damage I couldn't fly away from 100%... Hell of a little beater bird.
Gaui X7 Tribunus 200A, Xnova XTS 4530-525, Xpert, iKon2
Epic MD-7 Mezon 130A, HKII-4525-520KV, Savox, SK-540
TSA 700E Mezon 130A,HK-4530-540KV LE, Torq, iKon
Gaui X5 HW 100A V3,Gaui 4020-910,KST, iKon
lucidchaos is offline        Reply With Quote Quick reply to this message
Old 05-19-2019, 07:35 PM   #1036 (permalink)
Around 16 flights on weekends. Got the Zeal 238mm main blades and decides to white color spray on skid. Looks great.
230s, Fusion 270, 360 cfx 3s & DX9
2005h4 is online now        Reply With Quote Quick reply to this message
Old 05-19-2019, 07:55 PM   #1037 (permalink)
Your boom will not fail in flight, no benefit to reinforce.
Save to grip ball.
RCFred is offline        Reply With Quote Quick reply to this message
Old 05-19-2019, 08:43 PM   #1038 (permalink)
Thanks Fred.
I still have the broken horn in my bag, so I'll save it in case I need the ball at some point.
Too late on reinforcing the boom. I glued an ugly strip of carbon there, but the glue didn't stick well to the aluminum, so I'll probably peel it off.
Old 05-19-2019, 10:49 PM   #1039 (permalink)
Like mentioned, it will probably hold. If anything, you could stick something inside the boom to push out the dent.
Old 05-20-2019, 09:08 AM   #1040 (permalink)
I turned up a bit of metal to be a good sliding fit in the tail boom. It has a domed end and I put some grease over the end when tapping out the dents. The grease seems to help a lot. Funny but since I bought a batch of knitting needles I haven't broken a tail - typical
I have also bought the metal blade grips as the plastic ones are not well designed.
