Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > Outrage RC > Outrage 550
Outrage 550 Outrage 550 Helicopter Factory Support Forum
Old 07-07-2008, 01:39 AM   #1 (permalink)
Default Outrage 550 Setups
List your Outrage 550 setups! It's never to early to start making planes. I'l go first.
Jazz 80 ESC
9252 cyclic servos
9256 on the tail
Solid G Gyro
Motor... undecided
560mm Rototech Mains
92mm tails
6s 5000 Outrage Lipos
Western Robotics BEC High Current
AR7000
I'm kicking around the idea of running an 8s setup on this heli.....
Just a guy and his heli....
LITHIUMSTATIC is offline        Reply With Quote Quick reply to this message
Old 07-07-2008, 04:56 PM   #2 (permalink)
Well if it's a 550 then the Z-Power Z30A should work pretty good but I've no idea what kv the bird is designed around. The Z30A is normally 1150kv. Although they do an 800kv version as well.
trextuning is offline        Reply With Quote Quick reply to this message
Old 07-07-2008, 05:21 PM   #3 (permalink)
I have in my possession:
FASST 8CH Rec
Spartan Gyro
CC HV 80
CC BEC
I am thinking
560 Rotortechs (If Outrage 550s are not available yet)
92 Rotortech tails.
BLS 251
3 BLS 451s (Hope I have the #s right)
Not sure on the power yet. Charley is testing with a Z30 and 6S 5000s
SteveL is offline        Reply With Quote Quick reply to this message
Old 07-07-2008, 10:09 PM   #4 (permalink)
If I had one Here would be my setup:
- Jazz 55-10-32
- Tonic-X 800kv
- Outrage 8s 3700
- Rotortech 560
- Futaba s9452s on cyclic
- Spartan + 8900G on tail
Long Nguyen
Long Nguyen is offline        Reply With Quote Quick reply to this message
Old 07-08-2008, 03:02 AM   #5 (permalink)
interesting, I was planning on 8S 3700 as well
Castle HV-110
Outrage 8S 3700
CSM 720
not decided on blades but have some Rotortech's here
BLS-251 tail servo
Z30A motor
need to find some cyclic servos, I'm sure I have some here somewhere
Old 07-17-2008, 06:07 PM   #6 (permalink)
Jazz 80 ESC
[SNIP]
Probably stating the obvious, but the Jazz 80 won't do 8S. Now the Jive 80+ HV...
Logo 600 3D V-Bar, Jazz 55-10-32, Tango 45-7, 0.7/13T, BLS451/BLS251, JR R921, Maniac623
Logo 500 3D V-Bar, Jive 100+LV, Scorpion HK-4020-1100, 0.7/15T, S9452/S9256, AR7000, RT560
T-Rex 600 CF, Jazz 80-6-18, Neu 1515/2.5D/F/H, 11T, S9451, ds760/S9254, AR7000, Radix600
T-Rex 500 CF, stock ESC/motor/rotors, 13T, HS-5245MG, ds760/S9254, JR R921
th3tick is offline        Reply With Quote Quick reply to this message
Old 07-18-2008, 07:30 AM   #7 (permalink)
true, but he list his setup as 6S , only thinking about 8S..... but thanks for the clarification
Old 07-20-2008, 01:51 AM   #8 (permalink)
Well, my setup is going to be.........
Ouch!.......Woman!........Stop!........Hitting!... ....Me!...........
okay maybe this one will have to wait awhile unless i want a permanent room at the hospital.
Okay shes gone will let you all know my setup at later date
Why So Serious!!!
darthdecon is offline        Reply With Quote Quick reply to this message
Old 07-20-2008, 04:03 PM   #9 (permalink)
Wayne
http://www.abgrafx.com
WayneD is offline        Reply With Quote Quick reply to this message
Old 07-23-2008, 02:46 AM   #10 (permalink)
I've been kicking around what I run on this heli.... Think about this...
Keeping with the spirit of high voltage low amp draw (like the G5) I'm kicking around the idea of using a 10s setup. Now hear me out before you "Jeremy has lost his mind". If I can get a Lipo pack around 700-800 grams and a mah of around 2600-2800 running a 10s setup would really work well. I don't know the gearing on this heli so I can't start matching components, but I think it could be done.... CC85-HV ESC.... Hummmm......
Old 07-23-2008, 09:54 AM   #11 (permalink)
Just to add even more options to the mix, I'm running 10S A123 on my Swift. Pack weight is 775g, 2300mah (and 2000 mah of that is usable, no 80% rule like with lipo). Output voltage under load is ~29 volts.
In my Swift, running a Neu 1910/1.5Y / CC45HV, I get 6 minutes of aggressive sport flying at 1950 rpm on 550 SABs.
Now the bigger question is whether the 10S A123 "brick" configuration will fit in the frames.
Chris Boultinghouse
JustPlaneChris is online now        Reply With Quote Quick reply to this message
Old 07-30-2008, 04:11 PM   #12 (permalink)
CC85HV ESC
Hacker A40 10L Electric Turbine
Futaba 9252s
Jr 770 with 8900
outrage 6S 5000mah
rotortech 560s
k&B 92mm tails
CC BEC
Beaver Rat is offline        Reply With Quote Quick reply to this message
Old 08-11-2008, 08:34 PM   #13 (permalink)
Would it be allright to use a non HV CC80 esc?
Old 08-12-2008, 08:13 PM   #14 (permalink)
Yes unless you run more than 6s.
Long Nguyen
Old 08-13-2008, 07:37 PM   #15 (permalink)
Is there any need to run more than 6s on this heli?
Old 08-18-2008, 01:42 PM   #16 (permalink)
Not if you watch the video's of Henry Caldwell, Steven Fox and Craig Martin, they were all running 6S 5000ma Outrage packs.
Clyde Fox
Port Charlotte, FL.
Team Rotorworkz/Outrage
Foxden is offline        Reply With Quote Quick reply to this message
Old 10-10-2008, 10:44 PM   #17 (permalink)
I decided on going with a 6s setup for sure. I'm also going to use the ESC the Team Pilots are using (PHX-120) with the Z30-1100 or Scorpion HK-4020-1100 motor.
Getting closer!!! Can't wait. Unloading stuff to make room in my hanger.
Old 10-10-2008, 11:59 PM   #18 (permalink)
Getting closer!!! Can't wait. .
Seems you have inside info ? When ???
Got to have the first 550 in (South) Africa !
Lotus7
lotus7 is offline        Reply With Quote Quick reply to this message
Old 10-13-2008, 07:26 AM   #19 (permalink)
could useing 2 3s 2200 packs from their 450 w/ a z20 motor work. only for sport flyin. ive seen a bunch of ppl do this w/ their g550, but then again, that bird is LIGHT. just an idea for those budget flyers.
airsoft1779 is offline        Reply With Quote Quick reply to this message
Old 10-13-2008, 12:33 PM   #20 (permalink)
The Capi
2x 2200mah pack is going to be a VERY short flight and pushing it in the power dept.
