Old 12-23-2012, 11:05 AM   #121 (permalink)
Anyone using BeastX on Velo 50N2 flb to post his settings...?
salasgr is offline        Reply With Quote Quick reply to this message
Old 01-03-2013, 03:36 AM   #122 (permalink)
I guess im the only one all over the world flying velocity 50N2 fbl with beastX... ...well, not yet !! i will post mine when time comes
cheers
Old 02-16-2013, 01:51 PM   #123 (permalink)
formerly koi-fish
Anyone have beastx settings for X2, 093 and 095 servos?
/ 180cfx, 300x, X3,X4-II, Protos 380, Chase 360, x5, Logo 480, Gob 380, Gob 500, Gob 570, Warp 360, 450x, forza 450/450ex, T-Rex 600 Dom, Logo 600, DX9, 1973 Ford f100, Traxxas Summit/Bronco/Bandit/X-Maxx
"Everyone wanted his soul, all he gave them was a smile" - Steve Marriott
Diogenes is offline        Reply With Quote Quick reply to this message
Old 03-21-2013, 04:49 AM   #124 (permalink)
Trex 450 Pro V1
Equipment
Scorpion HKII-2221-8 main motor with 15T pinion
Spektrum H3020 servos on cyclic
Futaba S9257 on tail
Align Pro FBL head
Align ESC
DX6i transmitter
Transmitter mode
15 percent expo on aileron and elevator
10 percent expo on rudder
100 percent ATV on aileron, elevator, and rudder (I might experiment with 10 percent more
on aileron and elevator and 5 more for tail)
70 percent gyro gain
0-40-80-80-80 normal mode throttle curve
85 percent flat idle up throttle curve
40-45-50-75-100 normal pitch curve
0-25-50-75-100 idle up pitch curve
Parameter menus
Everything is stock setting with the exception of the following:
B control behavior: transmitter
G cyclic response: slightly increased
Batteries used
Sky Lipo 2200 mAh 40C 11.1V
Gens Ace 2200 mAh 55C 11.1V
Gens Ace 2200 mAh 60C 11.1V
Ze Povinho is offline        Reply With Quote Quick reply to this message
Old 04-30-2013, 11:43 AM   #125 (permalink)
Hello All.
Now got myself a 450 sport v2 with the ar7200bx and i love it. Been reading manuals since i got it second may i add and wondered what settings i should be running on a dx6i with the ar7200bx
Cheers
Wardy1982 is offline        Reply With Quote Quick reply to this message
Old 05-19-2013, 08:39 PM   #126 (permalink)
Question MicroBeast
Good day all,
I set up my Trex-600 Pro Nitro using Align Head and parts from Ron's. All seems well except setting my D/r . Should I leave the cyclic with over 12 degree +- or some how reduce those numbers.
If I reduce the travel by the TX it takes from 100% to 20% to get travel within range of normal flight.
I also use a Airtronics SD-10G.
Use of D/r seems to slow the swash movement down is this OK?
RBoyne is offline        Reply With Quote Quick reply to this message
Old 06-29-2013, 05:48 PM   #127 (permalink)
Align Trex 450 pro V1
MKS DS95 on cyclic
Futaba BLS257 on the tail(tail has the new v3 pitch slider)
Castle ICE 50 set rpm mode @ 3200rpm (3:45 min flight)
Scorpion 2221-6 motor (3s lipo)
KDEdirect head with Align pro FBL grips and swash driver arms
Stock Align 450pro V1 Swashplate
EDGE FBL 325mm V1 blades
Spektrum DSMX satellite on the BeastX
Spektrum DX7
Transmitter mode
30% expo on aileron and elevator
18% expo for the tail
100% ATV for aileron and elevator
80% ATV for the tail
33% transmitter gyro gain (end point menu)
Parameter menus
B control behavior - transmitter
C pitching up behavior - medium (red)
D headlock gain - high (blue flashing)
E stick deadband (default)
F torque precomp (off)
Blade MSR, MCPX v2 & 400 3D NightRig
Align Trex450 pro.
Align Trex700LE N.
SAB Goblin 700Comp.
CoolKD is offline        Reply With Quote Quick reply to this message
Old 07-02-2013, 01:25 AM   #128 (permalink)
Can anyone post their ATOM500 beastx setup?
Compass Atom 500/Beastx/Radix/KBDD
Cube is offline        Reply With Quote Quick reply to this message
Old 10-17-2013, 09:24 AM   #129 (permalink)
Originally Posted by bryman021 View Post
Trex 450 sport w/ DX6I
Converted to fbl with align fbl hub, grips, swash driver, and links.
DS410m on cyclic, DS520 on tail
Stock motor and esc from super combo
Tail gyro gain @ 67 in hh mode
Blue light @ 6 degress, transition from red to blue around 5.75 degrees
All parameter menus at stock setting except B control behavior set to pro
Dial 1 - cyclic gain at 7 o'clock
Dial 2 - direct feed at 9 o'clock (stock)
Dial 3 - tail dynamic at 8 o'clock.
Flies on rails!
could you give tx settings for me?
notsobad is offline        Reply With Quote Quick reply to this message
Old 08-10-2015, 06:03 AM   #130 (permalink)
TREX 600E PRO DFC
All stock
Spektrum AR7200BX
Spektrum DX18
Transmitter mode
20% expo on aileron and elevator
15% expo for the tail
110% ATV for aileron and elevator
100% ATV for the tail
55% transmitter gyro gain
Parameter menus
A blue
B blue
C red
D red
E red flashing
F purple
G Blue flashing
H Blue flashing
Throttle Curve
N 0%
1 70%
2 100%
H 16% (Castle ESC Autorotation Bail-Out - must be adjusted/calibrated for each setup)
Dials
Dial 1 - cyclic gain at maximum positive
Dial 3 - tail dynamic at 6.5 o'clock
CZorzella is offline        Reply With Quote Quick reply to this message
Old 09-08-2015, 06:36 AM   #131 (permalink)
T rex 450L Dominator
ESC - hobbywing platinum pro v3 with gov store
motor 460mx align
servos 3x mks ds95 HV + tails ds525 align
beastx plus 4 pro
all servos to highest pulse and hz.....
parameter B to blue (pro) all the rest to default...transmitter gain 30% (beastx to medium 'red') i think....
gov off cause i use the governor of the ESC which is perfect....3680 rpm
attidude control to 3d mode + collective 6 degrees (just to hover and lock the down direction to avoid crash in fast rescue)
heli has over 60 flights....no crash or problem till now....(its my 2nd 450l dominator with the first and the stock parts i had many issues regarding the tail wagging and vibrations)and i blame for that my shopper who after 30 years he dont know that with the governor mode you use a flat line on TC and not something line 0-40-65-75-80 etc.
Acid Junkie is offline        Reply With Quote Quick reply to this message
Old 06-17-2019, 03:48 AM   #132 (permalink)
Default T REX 600 and Spektrum AR7200BX MICRO BEAST
Hi, I am setting up an AR7200BX on a T REX 600, nitro and have a problem.
1. when setting the hovering pitch in menu J, the pitch if 6 degrees doesn't seem to save? when I check later it zero - if I move the throttle stick up from mid point to one click above it goes to 6 but not at mid stick?
2. Menu N - pirouette teaching - the swashplate moves whichever option I pick i.e. RED solid or BLUE solid.
Any ideas? I can only think I have set up something wrong on the transmitter - spektrum DX6 ? should I have reversed servos to get the swashplate moving in the right direction - or ignore and leave until all menu items are complete?
I have selected 120 CCPM in menu H (RED solid), with NORMAL in the transmitter.
Any ideas much appreciated, thanks Andy
andyprima is offline        Reply With Quote Quick reply to this message
Old 06-17-2019, 08:00 AM   #133 (permalink)
Default no 6 degrees?
Hi, I cannot get the set up to save the 6 degrees of pitch in menu j. At the end of setup, its at zero pitch. And, I cannot get the final set up pirouette rate to work - whichever I pick, red or purple the swashplate moves as i rotate the helicopter. Any ideas?
Old 06-17-2019, 08:37 PM   #134 (permalink)
Please do not cross-post. The thread you created in the Main forum has been merged with this one.
-Kevin
No helicopters were harmed in the creation of this post.
AMA CD # 7309, Turbine Waiver# RW 890
Click Here For Bergen Intrepid Turbine Build Videos
Skiddz is online now        Reply With Quote Quick reply to this message
Old 06-18-2019, 04:35 AM   #135 (permalink)
Hi Andy
Set-up step J has nothing to do with hovering pitch. If you think this, then you must not have a set of proper instructions to follow. I suggest downloading a full version from BeastX for their MicroBeast. Although it will include a section on receiver type, of which you have no choice, just ignore that part, and everything else will be covered in much more detail.
If after going through this alternate manual, you still have questions, create a thread about your issue in the BeastX FBL system forum.
This thread is dead, and was for posting your completed BeastX set-ups, so others could see what worked.
Regards, Sutty
BeltEXI, mCX, mSR, 4G3, FBL Trex250SE B, FBL Trex450Pro B,
sutty is offline        Reply With Quote Quick reply to this message
