130X Blade 130X Helicopters Information and Help |
#1 (permalink) |
![]() I bought a 130X ages ago and never really took it out the box.
Just decided to try my luck with a heli again. plugged the supplied power supply and charger in then the lipo . All its done is flash 1 light. reading the back of charger its says red and green lights. I am terribly colour blind and the lights are the same to me. can anyone tell me if , left or right or both lights as a system will work if so can anyone tell me that,this is no joke, the only leds I can tell are bright white and blue.thanks |
#2 (permalink) |
![]() My charger is at work. But if I remember right on it after you push the button to start the process. The left (red) LED will blink. The right (green) LED would blink indicating balancing. When battery was done the left LED would be constant on.
Hope this helps you. I fly mine almost daily. I take one or two to work with me. Sent from my LGL63BL using Tapatalk |
#3 (permalink) |
![]() Join Date: Aug 2019
![]() Thanks for the clear info. I tthink mine as a prob somewhere, left light never goes solis,blinks full time. I read somewhere I am sure that the supplied power supply is not right for the charger,not enoghh amps but cant find the post?
#4 (permalink) | |
![]() Quote:
Logo 600 (VBar Neo), Gaui X5 FES (BD3SX), Warp 360 (MiniVbar), Trex 450 Pro FBL (Spirit Pro), OXY 3 stretch (Spirit), OMP M2 Explore, two 180CFX (one uSpirit), 130X, XK110, Nano CPX |
#5 (permalink) |
![]() FWIW I have had at least three of the factory supplied chargers go on the fritz on me.
130X parts wanted! The Precious! You has the Precious! |
#6 (permalink) |
![]() The post from Passin Thru shows the correct sequence of lights. The chargers do seem to be fairly slow at charging and not great at balancing. I just use 12v 1amp as a power supply. The actual charger has an output of 300mAh hence it is fairly slow.
