Like Tree9Likes
  • 3 Post By CFerry
  • 4 Post By Smoggie
  • 1 Post By CFerry
  • 1 Post By Smoggie
Old 08-10-2019, 05:39 PM   #1 (permalink)
Default Heli slams down when closing throttle
I have set my TX up like the manual says, I have really lowered the ail and ele expo which as helped BUT when I close the throttle fully when in trouble the heli slams down,
What do I need to alter ,pitch curve or throttle curve. I am only hovering at moment. Thanks
Bugle call is offline        Reply With Quote Quick reply to this message
Old 08-10-2019, 05:58 PM   #2 (permalink)
Alter your pitch curve so there is only a small amount of negative. Many people do that when learning just because of what you are experiencing. Keep enough to move downward and keep the heli planted on the ground.
Team USED
Old 08-10-2019, 07:04 PM   #3 (permalink)
Since this is a collective pitch heli, you're better off to learn to hit 'throttle hold' when in trouble and leave the throttle stick alone.
This will be a good habit going forward.
Chris
Smoggie, Number and tporter416 like this.
minicopter Diabolo, Spirit, AR8010T, Xnova, Castle
Align 550 DFC, Spartan VX1e, Castle Talon
Oxy4 Max, AR7200BX
iCharger, deep cycles, DX8 G2
CFerry is online now        Reply With Quote Quick reply to this message
Old 08-11-2019, 02:07 AM   #4 (permalink)
On a Collective pitch heli the left stick shouldn't be thought of as 'throttle' it's the collective stick. Throttle is controlled primarily by the throttle hold switch.
If you think this way and set your heli up this way life becomes much simpler when flying CP helis. (i.e. dont use 'normal mode' throttle curve)
K2Freak, CFerry, Number and 1 others like this.
Gob Kraken |Gob 700 BT 'T' | Gob 770 Comp | Gob 700 Speed | Trex 700X | SoXos Strike 7| Tarot 600| | XLPower 700 | Henseleit TDR & TDR2 | Kasama Dune | UK distributor for Tarot 550/600 helis - ScotiaRC.co.uk
Smoggie is online now        Reply With Quote Quick reply to this message
Old 08-11-2019, 04:58 AM   #5 (permalink)
Very good advice
K2Freak likes this.
Oxy4 Max, AR7200BX
Old 08-11-2019, 05:03 AM   #6 (permalink)
Learn to use throttle hold as suggester above.
Get out of the habit if slamming collective down.
Throttle hold is your friend.
HW.
Many helis from the 70s to 2000s.
Align,Blade,GMP,Hirobo,Kyosho,Schluter.Flybars cool,FBL too. Currently flying the little ones.
Heliwhisperer is online now        Reply With Quote Quick reply to this message
Old 08-11-2019, 05:13 AM   #7 (permalink)
Yes to what everyone else here said. AND...
It is a BAD habit to use the left stick to shut down. It is terrible that the cheap controllers that come with RTF kits do not have TH.It is bad for us and good for the parts manufacturers.
TH is your friend. It saves money. When a little bird gets into trouble--either my thumbs or mechanical--TH lets me ease it to the ground. I still have collective and rudder control. If it is upright I can give it full positive pitch near the ground to slow the headspeed and soften the landing. Or if inverted give it full negative.
Learn two good habits: use IU before you take off (even if flying sport mode for now) and useTH anytime the heli is not flying.
Good luck and happy landings.
daveapplemotors is offline        Reply With Quote Quick reply to this message
Old 08-11-2019, 05:28 AM   #8 (permalink)
Thanks taken most of that onboard. I get the left stick in not throttle.
I have 3 flight modes set up like manual suggests, I have been using normal thinking its the most docile. Not sure about the IU comment and use? Lastly what mode should I be in and what values should I be looking at please?
Old 08-11-2019, 06:19 AM   #9 (permalink)
If it were me I'd set the throttle curves in the three flight modes to:
N: 70-70-70-70-70
1: 80-80-80-80-80
2: 100-100-100-100-100
Pitch curves for all modes I'd set 0-25-50-75-100. But if you felt that the collective was still too sensitive then you could soften response by setting the pitch curve in 'N' to: 15-33-50-67-85
To start the heli you put the collective stick in the middle (pitch = zero) and release throttle hold. The ESC soft start ensures a smooth spoolup. Get used used to using throttle hold to start and stop the motor, this is an essential habit to get into as you progress in RC helis.
xoexoe likes this.
Old 08-11-2019, 08:10 AM   #10 (permalink)
Grumpy Old Man, That's excellent, thank you very much.
Old 08-12-2019, 09:37 AM   #11 (permalink)
FWIW, I have my 130Xs at or near 100% in all three modes, but I have a fairly flat pitch curve in Normal Mode (say, 20-35-50-65-80), a steeper curve in IU1, and the usual 0-25-5-075-100 curve in IU2.
Seems to work for me, seems to be more stable.
130X parts wanted! The Precious! You has the Precious!
Mrowka is offline        Reply With Quote Quick reply to this message
Old 08-16-2019, 02:33 PM   #12 (permalink)
Maybe the main gear has slipped down the shaft
Is there any up down play in the head?
If there is put a finger on the head and press main drive gear up
HTH
MCX2,NanoCPX,MCPX V2,NanoCPS V2,MCPS,
130X,Trio 180 CFX,70S,230S V2,450X,DX8,DX8G2
Stormbringer is online now        Reply With Quote Quick reply to this message
