Like Tree14Likes
Old 05-18-2019, 02:04 PM   #61 (permalink)
9.56.. 153 divided by 16 = 9.56.. at least that's what the taught me in school. not sure if something has changed since then.
with a 1100kv motor, governed will get ya around 2200.
Old 05-19-2019, 11:16 AM   #62 (permalink)
I maidened the 550 today, and i had the infamous logo wag as well...
I changed the whole tail section with the one from a friends logo and all wagging was gone. I guess i have to find those thrustbearings somewhere
mr. mark is offline        Reply With Quote Quick reply to this message
Old 05-25-2019, 09:56 AM   #63 (permalink)
I changed the tail thrust bearings with a set of new mikado bearings (I could not find the MSH bearings anywhere). Also i sanded the tailshaft with some 600 grid paper. When I pulled the tailblade holders, the slider was binding although it was smooth when I didn't pull the blade holders. After sanding it was much smoother
The tailag is now gone for 90%. I'll do a few flights and hope all gets a bit smoother over time.
Freeskiken likes this.
Old 11-24-2019, 02:35 PM   #64 (permalink)
Hey Thickfog,
what mks servo did you put in ?
talking about a logo 550 sx
6 logos no wag. I did buy a used 480xx that was like a happy dog. I removed the the spedix tail box and parts, bought new logo stock parts. The tail shaft and hub were bent and one tail box bearing was bad. Not sure how he expected the tail to work properly.
It also had the stock combo savox tail servo and still had slight wag. So in went an mks servo and all done.
Thanks ,
filo
filo is offline        Reply With Quote Quick reply to this message
Old 11-24-2019, 03:12 PM   #65 (permalink)
For me I've never had wag like many others. I do have all older grips though.
I have a few nip sets I'll use one day. We'll see.
I use futaba, mks, bk and kst servos. Ko issues.
On my logo 480xx i did have wag with the savox packaged servo. Went away with the mks tail servo.
Thickfog is offline        Reply With Quote Quick reply to this message
Old 11-24-2019, 04:23 PM   #66 (permalink)
I fixed a friend’s wagging Logo 550 with grips from a Tarot 600. Worked like a charm.
Gob Kraken |Gob 700 BT 'T' | Gob 770 Comp | Trex 700X | SoXos Strike 7 | XLPower 700 | Henseleit TDR & TDR2 | Kasama Dune | OMP M1&M2 | UK stockist for OMPHobby M1/M2 ScotiaRC.co.uk
Smoggie is online now        Reply With Quote Quick reply to this message
Old 11-24-2019, 06:16 PM   #67 (permalink)
i grabbed a set too but the dog bone on the grip was bigger than the mikado one. it fit but was really tight. did you size it?
Old 11-24-2019, 11:52 PM   #68 (permalink)
I used the tarot dog-bones and slider (see pic).. But yeah, if it was tight I would size it with a reamer.
Old 11-25-2019, 08:42 AM   #69 (permalink)
oh shit, I didn't get them.. I just ordered the grips.. np, their quick to ship. thanks dude.
Old 11-25-2019, 08:52 AM   #70 (permalink)
Tony I used a Tarot slider with mikado grip. Tight as heck, but works fine.
Old 11-25-2019, 09:44 AM   #71 (permalink)
thanks, just ordered 2 dogbones and another grip set.. a whopping 25 bucks.
there is a nice duel slider there but I don't think it will retro fit. as well as a complete metal tail case.. like the speedx one.
Old 11-25-2019, 12:23 PM   #72 (permalink)
Dual slider assembly should fit ok (I've not tried it on the Logo but i dont see why it wouldnt work). The metal tail box unfortunately is for the 'fatter' 600 boom only.
Tarot have also released metal tail grips (see pic), through these are hot off the press so may have not hit all the dealers yet
Old 11-25-2019, 01:24 PM   #73 (permalink)
I saw them but the angle that the control balls sit are diff from the plastic ones. so there are some other parts that go with them, but they look really nice.
I think for what im doing, the plastic will be fine.
Old 11-25-2019, 01:28 PM   #74 (permalink)
The metal grips are sold as an assembly complete with tail shaft, bearings and balls. Here's a pic:
Recommended retail for the assembly is £11.28 (UK pounds) so that should work out about $14.50.. You have to love tarot prices!
Name:	ScreenHunter_41 Nov. 25 19.27.jpg
Old 11-25-2019, 03:30 PM   #75 (permalink)
Yea, thatís what I saw on their site.. see how the balls are right over the tail shaft? Thatís not how they are on the plastic ones. No biggie, I think the plastic is gonna work fine for me.
Old 12-17-2020, 10:42 PM   #76 (permalink)
Smoggie/Tony
Does the Mikado bell crank work with the Tarot slider?
Thanks,
Raz
Razmo is offline        Reply With Quote Quick reply to this message
Old 04-17-2021, 12:25 AM   #77 (permalink)
I tried everything recommended here pretty much gave up couldn't get rid of the tail wag. This past Christmas bought a new servo from Spectrum and Mikado servo arms. Has since flown like a dream the three times had it out this year.
genbud is offline        Reply With Quote Quick reply to this message
Old 04-18-2021, 03:06 PM   #78 (permalink)
I've not had difficulty with a Mikado tail, but I can sure recall two past helis where the journey was a chllenge. On a Trex 700N once, after a perfect working tail, following by a crash, I replaced the tail shaft, tail rotor hub, tail servo, and Vbar gyro. Seemingly, I was out of options. I then replaced the complete tail rotor assembly. Solved. Undected damage in the tail grips I believe. On an earlier experience with a different model, the tail began wagging after some maintenance. Someone asked me if I checked the tail thrust bearings? I said, of course...they are perfect. then, after replacing the tail shaft and hub, and still had the wag, I swapped the tail rotor from another model that used the same design. Solved. Put the "bad" rotor on the donor model....and it wagged. Relaying this on yhe forum, another member said "check the stack sequence of your tail grip thrust bearings". So, I did....sure enough. That was it. Lessons learned for me
= Rb43 =
Rob43 is offline        Reply With Quote Quick reply to this message
Old 04-25-2021, 06:57 PM   #79 (permalink)
I have had that same battle in the past took the tail rotor apart 100 times very thing looks good. Also replaced some parts in the tail rotor assembly still having tail problems. Replaced the hole tail rotor and it fixed it.
joecass2 is online now        Reply With Quote Quick reply to this message
Old 04-26-2021, 09:10 PM   #80 (permalink)
I also fought this wag on my 550 when it first came out. The only way I fixed it at the time was to replace the grips with the old smaller bearing system I had laying around. Fast Forward to a few months ago, and I had to redo my tail again. I finally measured the outer thrust bearing race inner dimensions, and found that the original outer race had a smaller ID than my newer one, and wouldn't turn on the shaft. I figured that if the race wouldn't turn on the shaft, I would have to turn on the OD against the grip, and I didn't think it was designed like that. I tried a new set of thrust bearings (#00727), and all is well. I think Mikado initially got a bad set of thrust bearings. Try your outer race on the shaft and see if it will turn freely......
Bob
robertmrankin is offline        Reply With Quote Quick reply to this message
