Go Back   HeliFreak > R/C Electronics Support > HobbyWing ESC's
HobbyWing ESC's HobbyWing ESC Support
Like Tree4Likes
Old 09-10-2020, 09:42 AM   #181 (permalink)
That is great Daniel !
But do I need an Atmega32u for that or does it work with the 328P as well ?
And if an 328P is ok; is an Arduino nano-board than sufficient, since I have that lying around already ..?
regards, Andre
hazes is offline        Reply With Quote Quick reply to this message
Old 09-10-2020, 10:25 AM   #182 (permalink)
It works with the 328. I've found a better way to implement the protocol for this mcu. I recommend the arduino pro mini (without usb) as I've found issues reading the esc serial with the nano
DanielGA is offline        Reply With Quote Quick reply to this message
Old 09-11-2020, 03:43 AM   #183 (permalink)
But as you are going to use castle protocol, which is not serial, the nano should be ok (I haven't tested though)
Old 09-13-2020, 01:05 PM   #184 (permalink)
I have a question about the Lua script.
I have a Horus X12 running OTX 2.3.9
It seems that anything inside the rectangle seems to flash rapidly, alternating between the two. When the scroll wheel is moved, the selection moves, but still flashes between the selected and the previous selection.
When the enter key is pressed, it still flashes rapidly (100ms or so as an estimate) but doesn't alternate.
I have spent a couple hours looking through the Lua to see if I could come up with a fix, but I am rather inept at Lua and was unsuccessful. I do, however, suspect it has to do with anything that getflags() doesn't search the element string for "btn", because the "UPDATE" button at the bottom of the screen works flawlessly.
This doesn't render the function unusable, however, it does make it difficult to use.
If there is any more info you need, please let me know, I will try to get it for you.
And, thanks for the work you have done on this. It is a superb project and extremely useful!
I came, I saw, I hovered
Ivan is offline        Reply With Quote Quick reply to this message
Old 09-16-2020, 08:15 AM   #185 (permalink)
These issues can be easily fixed with simple non inverting amplifier connected to RX pin e.g. built using two npn transistors. Main issue there is that HW ESC does not have enough power to pull RX pin down.
L2-Max is offline        Reply With Quote Quick reply to this message
Old 09-16-2020, 01:53 PM   #186 (permalink)
It's a great little solution - I now have them in about 5 or 6 helis and 3 planes. For the cost of the Pro Mini (about $2 - 3) I can have a simple voltage sensor in my planes or full-house volts / rpm / current in the helis.
Thanks again Daniel
Mikej is online now        Reply With Quote Quick reply to this message
Old 09-18-2020, 03:19 PM   #187 (permalink)
Default Castle Link compatibility
Has someone been able to make this work with a castle ESC? i am trying to use it on a Talon 90, Horus X12 Express, I have some issues with the sensors not reading correctly, using with a 6s setup Voltage varies between 24,23,22v. When the motor is running i get values jumping all over the place like, 13, 18, 16 ,25,23, all at the same throttle input. I am somewhat new to Opentx so i dont know what i can do to fix this issue.Also i am using an arduino nano is what i had on hand for this project.
Emilioeer is offline        Reply With Quote Quick reply to this message
Old 11-09-2020, 02:14 PM   #188 (permalink)
Great project!
How do you choose between serial and PWM signal for telemetry with the Hobbywing Platinum v4 pro? When using PWM signal, you can at the same time add a gps via the only available uart port to the board, correct?
It is not clear to me what lead to use from the Hobbywing to the Arduino mini pro to use PWM signal for telemetry.
stefaanbolle is online now        Reply With Quote Quick reply to this message
Old 11-09-2020, 10:10 PM   #189 (permalink)
It turned out that the voltage and current transformations for HW V4/V5 are more tricky than expected...
- At least there are two voltage dividers, depending on the model, one for LV models and other for HV models
- Current is a shunt/diffamp sensor and has different offsets for V4 and V5
- Temperature is ntc resistors and seems to be the same circuit so far
Due to this now there are four options for HW V4/V5:
- HW V4 LV
- HW V4 HV
- HW V5 LV
- HW V5 HV
Thanks to Commodore8888 for looking into some HW V4 PCBs to check characteristics of the sensors
Also I made some improvements on the castle link protocol
v0.5 released
- Added castle link protocol
- Improved voltage and current transformations for V4/V5. Added different models
- Fixed wrong number of averaging elements for V4/V5
Maybe something similar with Hobbywing Flyfun HV vs LV ESCs and the RPM data? That could explain why the RPM PWM signal generated from telemetry on the HV units is wrong while it woks fine with the LV units.
Old 11-10-2020, 12:28 PM   #190 (permalink)
From lua config script select PWM as Protocol and press UPDATE
Correct
Use the yellow lead from the esc and connect to arduino pin 8
Old 11-10-2020, 12:50 PM   #191 (permalink)
Sorry for the delay...
What about the other sensors readings: BEC voltage, temperature and RPM? Are they correct?
Nothing to do with opentx, except for the lua config
Arduino nano should be ok (not tested though) as long as you are not using serial Hobbywing protocol (see previous comment 185)
It can be an issue related to telemetry reading. Check pin2 and pin 10 (including the pullup) connections
From lua config script change sensor averaging to 1 and check if you are getting 0 values sometimes
Old 11-10-2020, 12:59 PM   #192 (permalink)
Could be... Is the deviation linear (I mean could be fixed by a multiplier/divider) or is non linear?
Old 11-10-2020, 01:18 PM   #193 (permalink)
Correct
Thanks!
Old 11-10-2020, 02:13 PM   #194 (permalink)
Flickering is normal. Can be improved though
Regarding the alternate issue, I can't reproduce. Are you using the last lua version 0.7?
Old 11-10-2020, 02:36 PM   #195 (permalink)
At any rate, it would take more programming and a throttle signal input for the arduino to handle the issue, but I am under the assumption that there's not much more memory available after flashing the current code.
Curves for diffamp and ntc have been implemented for HW V4/5 and may be adjusted in escHW4.h if needed. Circuit values are required though:
Code:
const float voltageDivisor_[4] = {11, 21, 11, 21};
const float rawCurrentOffset_[4] = {15, 15, 660, 660};
#define ESCHW4_NTC_BETA 3950.0
#define ESCHW4_NTC_R1 10000.0
#define ESCHW4_NTC_R_REF 47000.0
#define ESCHW4_DIFFAMP_GAIN 13.6
#define ESCHW4_DIFFAMP_SHUNT 0.25 / 1000
Alternatively, if no circuit values are available or esc firmware is buggy and doesnt follow the expected the curves, it can be aproximated by measurement points but this increases the required flash for each curve and as you pointed there is not much free flash
Old 11-12-2020, 06:04 AM   #196 (permalink)
I am going to try an all-in-one sensor for my 470LM (to replace 3 different FrSky sensors and interconnecting cable bundles)
Pending deliveries:
- Arduino Mini Pro 328p 3,3V with FTDI board
- BMP280
- BN220
- Hobbywing ESC Platinum v4 (already installed) connected to Arduino via PWM
In a second phase I'll add to the board additionally:
- 6S voltage measurement
- 100A/XT60 current measurement (considering HGLRX XT60 board)
Looking forward to use your code, thanks for sharing!
Old 11-12-2020, 12:40 PM   #197 (permalink)
Great! Keep us informed
Old 11-16-2020, 07:37 PM   #198 (permalink)
hello,
i got a handful of Arduino pro minis 3.3v
I want to get ESC temp and RPM (headspeeds) from my Hobbywing V4s. to my frsky/open tx . only frsky sensors I use are the FVLSS
im confused on where to start to be honest.
did I miss a step by step setup guide? or do i need to speak the language to implement this?
thank you.
Goblin 770S - eXo 500 - HD 502 - Oxy FE, MEG - Few Fixed wings
Spartan VX1n/e, Frsky RX, RT Blades MKS/BK, Hobbywing
Danker16 is offline        Reply With Quote Quick reply to this message
Old 11-16-2020, 11:48 PM   #199 (permalink)
See the project on github
Old 11-17-2020, 11:32 AM   #200 (permalink)
Awsome missed that page.
