Jeti Duplex Radio Systems Jeti Duplex Radio Systems Support |
#1 (permalink) |
![]() I have a DS16 and ICON2 Gyro.
flight modes and gyro gain are on switch SA. I cant set my gain for idle up 1 (switch SA middle position) When I go in to my gain settings switch all way back shows as position 2, switch mid point shows position 3 and switch full forward also shows position 3. When I try to set gain for mid or forward setting it effects both of them. full back is fine. Why are mid and forward both showing as position 3??? Thanks
We had a great country once. You know what made it great? “I can.” Then the weak came along, “the I cant’s” and destroyed it. |
#2 (permalink) |
![]() Join Date: Jun 2005
![]() Called the good people at Esprit and got it fixed. I had set it up wrong
![]() I'm running flight mode and gyro gain on the same switch. But in function assignment I had set gyro sense to a switch. That should have NO switch assignment. Cleared that. Then in gyro setting I had globe (G) set and it needs to be (S) based on the flight mode. Changed that and now I can set the gain for each of my flight modes. Tested in IKON software and it shows the new gain setting when flight mode is changed. ![]()
