Like Tree1Likes
Old 03-09-2015, 10:49 AM   #341 (permalink)
The light is to tell you that you are either setting positive or negative pitch. Blue for negative, red for positive.
MSH, Cyclone
Way2evl is offline        Reply With Quote Quick reply to this message
Old 03-09-2015, 01:56 PM   #342 (permalink)
Originally Posted by Bladecpnitro View Post
Where does the BeastX like to have the ball set on say a 450?
I had all the tail blowing dialed out with a GT 5 and now with a Beastx I'm blowing the tail again on hard maneuvers and cross wind conditons?
The GT 5 liked the ball to be out farther than most gyros so I'm thinking I need to move the ball in and bump up the tail gain a little. With current mechanical gain on rudder I can bump gyro gain to 75% and the tail holds well in FB flight and tail down funnels but I get ocassional tail shake in fast forward circuits.
Thanks!
Adjust your gain in small movements. Seems like you have it really close. Seems like you have the ball set in a good hole also. Let us know if it still blows out after you get the wag taken care of.
MSH, Cyclone
Old 03-16-2015, 06:31 PM   #343 (permalink)
Ah well that explains it!!! Thanks!
floatingkiwi is offline        Reply With Quote Quick reply to this message
Old 05-31-2015, 06:13 PM   #344 (permalink)
When changing parameter E, does dead band increase or decrease as you move to the right in the manual?
I had that set to Purple which I assume was almost no dead band, is this correct? I set it to Red
B- Control Behavior is set to TX 120 ail-ele endpoints
C- Pitching Up - works great at Red default
G- Cyclic Responce- I reduced it from high- blue flashing- to red which enabled me to set my #1 Pot back in the middle instead of 10 0clock.
H - Pitch Boost - I set to Red as well to give it a tad more pitch pop.
I got 5 flights on it and it feels better in every way, not quite as much cyclic as I had so might need to bump G menu back up or just reduce expo a little as a still have a good flip rate at full stick.
I had the 450 Pro flying well with the exception of a slow cyclic bounce back on hard flips and crappy hesitating tictocs and piro flips and a soft mushy collective.
If its fixed don't break it!
Old 06-16-2015, 09:42 AM   #345 (permalink)
Hi,
yes that's correct. Purple is the smallest value, very little deadband, and then it increases stepwise up until blue which gives a lot of deadband.
best regards from Germany
Stefan
BEASTX r&d Team
freakware.com
Frenchdress is offline        Reply With Quote Quick reply to this message
Old 07-19-2020, 01:53 PM   #346 (permalink)
Default Is there a tuning guide for 5.0?
I assume this tuning guide will work just the same? is there anything in particular to look out for?
- VultAge -
470LT, G420, G570, Chronos, T-Rex 600N and 700N
vultage is offline        Reply With Quote Quick reply to this message
Old 12-10-2020, 03:51 PM   #347 (permalink)
Default v5.
http://www.beastx.com/download/manua...719_web_EN.pdf
I made a mistake once, but I was wrong...
tommytt1 is offline        Reply With Quote Quick reply to this message
Old 12-10-2020, 03:55 PM   #348 (permalink)
Default v 5.2 Wiki
https://wiki.beastx.com/index.php/Ma...blV52:Intro/en
