Go Back   HeliFreak > R/C Electronics Support > EGODRIFT
EGODRIFT Support Forum
Like Tree6Likes
  • 2 Post By jrman83
  • 3 Post By AndyO
  • 1 Post By AndyO
Old 06-18-2020, 11:56 AM   #1 (permalink)
Default Oxy 5 + Egodrift 4025, Temp question
Here is some background to my question I had recently built an Oxy 4 max with an Xnova 2820-890 and was very impressed with how it would come down after a full flight slightly warmer than skin temp, was going to go with another Xnova on my Oxy5 build but started reading more about the Egodrift, lighter, stronger, cooler. Built my Oxy5 maiden hovered in my back yard all went well but when I went to hand temp test the motor it was pretty hot, couldn't keep hand on for more than a few seconds.
Now I know that the hand temp test is flawed, but I had read that ED motors come down cooler than Xnovas in the same size. I am running 9 degrees timing, hover test was at 1850rpm for about 5minutes canopy off. Am I missing something or is normal and I should get a temp gun(plan on getting one after work today).
Typically how hot should motors come down after flight?
Toe_Fuz is offline        Reply With Quote Quick reply to this message
Old 06-18-2020, 12:24 PM   #2 (permalink)
So could you add a little more info?
-what Kv motor
-Pinion teeth
-Blades
JimJW is offline        Reply With Quote Quick reply to this message
Old 06-18-2020, 02:09 PM   #3 (permalink)
Egodrift 4025 - 1050kv
Pinion: 12t
Main gear: 110t
ESC: HW120 9 degree timing, Freewheeling on
Blades: Lynx 550
Running Brain2 Gov 1850, 2000, 2200
I realize I am a little low in the RPM range for the gearing I have. Would dropping a tooth run cooler?
Old 06-18-2020, 03:21 PM   #4 (permalink)
If you drop a tooth you’ll loose a little at the top end... (won’t have enough overhead to gov. effectively)
Your setup doesn’t seem that out of whack for it to be gearing. Is everything else running smooth, gears binding, belt tension, etc?
Old 06-18-2020, 05:48 PM   #5 (permalink)
I mean I have the belt pretty tight as per manual, noticed that it doesn't stay spinning as long as my other helis on throttle cut. But then again it is a super fresh 2-3 hover flight belt. Doesn't seem like anything else is binding, maybe just combination of fresh tight belt, flat hover, lower end RPM? or Egos just don't run as cool as my little baby Xnova? Or maybe my frame of reference for motor heat is too small?
Old 06-18-2020, 06:31 PM   #6 (permalink)
You can try going up or down in timing and see what works best. The recommended 9 degree of timing is a starting point.
Sent from my SM-G988U using Tapatalk
Rabid121 and EGODRIFT like this.
Old 06-18-2020, 07:21 PM   #7 (permalink)
Agreed, try at 7 or 8 and see. Bear in mind though that 60C can feel mighty hot to the hand, and that's not an unusual operating temp for the 4025 in an Oxy5. The smaller 40 series motors tend to run a little warmer than the larger 45 series, in my experience, maybe 10-15 degrees C or so. However, certainly nothing to worry about unless you're above the 70C mark - which given your gearing and headspeed, I'd say would be down to something mechanical causing excessive drag on the system - are you logging your average/peak current draw?
Have you actually measured the motor temp with an IR gun?
Rabid121, jrman83 and EGODRIFT like this.
Synergy 696
Minicopter Triabolo 700BE
MSH Protos 380Evo
MSH Brain2 Beta Team & Egodrift Team
AndyO is offline        Reply With Quote Quick reply to this message
Old 09-27-2020, 09:31 PM   #8 (permalink)
Has the OP had any further luck?
I also recently got a ED 4025-1050 for my XLPower 550, running off a HW 120a V4. Made sure no binding, smooth drivetrain etc and also experiencing pretty high temps even off a hover. I also flew a full pack for about 2 min light 3D and was cut off, and when I measured the pack it was down to 3.6v which is highly unusual. Leads me to believe something about this setup is causing excess amp draw and heat.
Any changes to the setup that I should try? My timing is 9 per ED recommendation.
Silvercomet is offline        Reply With Quote Quick reply to this message
Old 12-23-2020, 09:49 AM   #9 (permalink)
Resurrecting this thread. I just got the model together and doing setup flights. I'm also experiencing similar behavior. The ESC is warm to the touch but the motor is hot. Here is my setup:
Pinion: 11t
Main gear: 110t
ESC: HW120 15 degree timing
Blades: Lynx 550
FBL: iKon2
I don't know the exact head speed but I was governed at 50% flat throttle curve for this test flight. I ran 2 packs for ~6 minutes of easy flying.
I left the timing at the default value of 15 because I didn't know any better. I am going to try 9 degrees and see what it does.
I'm confident that there is no binding. Everything spins smoothly. Next time out I will use a temp gun to get an accurate measurement. I'll report back my findings.
kw_rc is offline        Reply With Quote Quick reply to this message
Old 12-24-2020, 08:54 AM   #10 (permalink)
Actual temp readings would be useful, always difficult to tell by hand. Good idea to drop your timing to 8 to 10, try and see. This particular motor does run warmer than what we see from the larger 45** series motors, but even so, I rarely see more than 60C to 65C from mine.
jrman83 likes this.
Synergy 696
MSH Protos 380Evo
