Like Tree1Likes
  • 1 Post By ragge1
Old 01-14-2021, 08:01 PM   #1 (permalink)
Default Help. Hobbywing 130a V4 opto Neo Gov.
Setting up or attempting to set up HW 130 V4 current vbar firmware.
I have the HW gov mode set to Heli Linear, active freewheel disabled. The rest are just the stock settings. 12T pinion 112T main gives me a ratio of 9.330 in the Gov settings in VBC touch.
I initially set low head speeds to test 1200 1400 1600.
I test spooled up without blades and my VBC touch says 29300 RPM's But it feels more like 1200ish in bank 1.
Could this outlandish RPM reading be due to having no blades on and the sensor is over shooting?
If anyone could share some current setup numbers within the neo for run up/soft start that would be great.
Attached are my HW internal settings.
ID:	900087   Click image for larger version
ID:	900089   Click image for larger version
joeflash211 is offline        Reply With Quote Quick reply to this message
Old 01-14-2021, 08:14 PM   #2 (permalink)
Does that Opto ESC have an RPM wire? If it does plug it into the RPM port on the Neo
Also disable the voltage cut off
Old 01-14-2021, 08:19 PM   #3 (permalink)
Yes, it does have an RPM out wire, that I have going into the RPM port of the Neo.
Old 01-14-2021, 08:27 PM   #4 (permalink)
that new firmware works with an opto ESC?
Do you have the RPM wire plugged in correctly in the port? It’s easy to plug it in backwards
Old 01-14-2021, 08:33 PM   #5 (permalink)
Do you have the RPM wire plugged in correctly in the port? Itís easy to plug it in backwards
Yes, plugged in correctly, when I flip or unplug it doesnít display any RPMís.
Iíve got 3 other Neoís that work great, just canít get this Hobby Wing right. My first HW.
It has the new firmware so I assume itís for the opto. Only difference with the opto is no BEC.
Old 01-14-2021, 08:57 PM   #6 (permalink)
Unfortunately thereís a couple wacky things that have been happening lately with this new firmware..
Old 01-14-2021, 09:06 PM   #7 (permalink)
I’ve noticed that. Might just throw some
Blades on it and hope for the best! lol
Thinking having no blades on it while spooling could be throwing the sensor off.
Old 01-14-2021, 10:20 PM   #8 (permalink)
no, i check the gov all the time with no blades.. its right on the money.
Old 01-15-2021, 10:01 AM   #9 (permalink)
had lots of HW from the very old to v4 and worked very nice but my last 200A 4,1 didn't play well , might have been the firmware , sendt it back and got me YGE , very nice with the vbct
fiddle likes this.
| Kraken 700 : Neo | Atom 6HV : Neo | Align 500X : Neo | vbct : |
Old 01-15-2021, 12:15 PM   #10 (permalink)
almost all my helis are yge-t's/ scorp.. with the exception of a few hw's with the mikado ui sensor.. i wont get the firmware update. it needs to be a totally new esc from hw.
Old 01-19-2021, 08:32 AM   #11 (permalink)
I had the exact same thing, and well it's is hardware problem with the Hobbywing. They removed a part they shouldn't have and causes the rpm signal to go nuts.
You can solder bridge 2 pads together.......currently looking for a pic, I used a jumper for testing, and well never removed it.
Or you can just get a Hobbywing rpm sensor and hook into your motor wires and run to your Neo to get rpm.
I bought 2 brand new HW130 opto's and had this exact same issue. Hobbywing tech support was useless and I never got a response on the issue. I fellow heli flyer told me about it and walked me through some testing and I installed the jumper and it worked as it was suppose to. I'll look for the pics and post.
My custom charging case build
RCHN #633
Team SYNERGY
