Like Tree2Likes
Old 01-14-2021, 06:31 PM   #21 (permalink)
I'll try that...don't think I'm doing anything wrong, but maybe I am. Thanks for the assistance.
Once this is figured out, I have a YGE 205HVT and got a VBAR telemetry cable for it. Do you know if it matters which side port it's plugged in, there's 2?
CMAS is offline        Reply With Quote Quick reply to this message
Old 01-14-2021, 07:17 PM   #22 (permalink)
I don’t think it makes a difference but I always go into tele 1. It’s like a little satellite port. The other little wire is the RPM sensor wire, that goes into the RPM port
Old 01-14-2021, 08:55 PM   #23 (permalink)
Uninstall stick MODE switcher app, this is used if you want to fly in different modes, the Neo will switch the mode as it was setup.
Is this a new Neo?
Do you have PRO/RESCUE installed?
Please show us the log from this Neo.
All the videos in one place https://uroehr.de/vtube/cat/english-videos
Gaui R5, Henseleit TDR, TDR2, TDF, TDS, TDSF
VControl
Old hand at Planks
Old 01-14-2021, 09:41 PM   #24 (permalink)
I noticed that the Neo voltage is 8.47 volts. I would try dropping down the esc bec voltage to 6 or 7.4 volts and try initializing.
luckyflyer is offline        Reply With Quote Quick reply to this message
Old 01-14-2021, 09:57 PM   #25 (permalink)
VINGER - Uninstalled "Applications/Mode Autoswitcher"...I think that's what you meant to uninstall?
Yes, again both VBCT and NEO are new
No "VBar Professional Rescue 6.4 Firmware" installed
Log file is at end of short video a few posts back and here...
VBCT with NEO initialization issue (0 min 56 sec)
Thanks for the video link, I favorited and will watch them.
Luckyflyer - My YGE's BEC output is set to 8.4V, there's probably some percentage of +/- voltage variance on the BEC output, I'll try lowering the voltage tomorrow.
Old 01-14-2021, 10:19 PM   #26 (permalink)
Vinger get's the gold star for the day...uninstalling "Applications/Mode Autoswitcher" stopped the switching to Mode 1 during initialization and initialization error(s). I can only assume that it began initialization in Mode 2 and recorded Elevator, then switched to Mode 1 and recorded Elevator again giving me the Ambiguous on Elevator error. It's green and everything appears to be working as it should now. I'll get everything buttoned up tomorrow. Thanks!
Old 01-14-2021, 10:38 PM   #27 (permalink)
All sorted, great news.
VControl
Old hand at Planks
Old 01-15-2021, 07:13 AM   #28 (permalink)
he always does hes pretty sharp..
glad ya got it goin..
Old 01-16-2021, 10:31 AM   #29 (permalink)
Finished setup last night and flew 1 pack this morning. Just had to dial the tail gain down a little. Climb outs looked great, stops are crisp, tracks great in fast flight, funnels and hurricanes in all orientations were good, piro speed looks consistent (no whipping). Just need to make some adjustment to get the disc flat during piros. Pretty happy for a first flight. The radio feel and stick movements felt a little weird since I was used to the smaller case of Futaba 8FG for so many years. Now I have to get NEO's for the other models so I'm not switching back and forth between radios.
GregCA likes this.
Old 01-16-2021, 12:23 PM   #30 (permalink)
dont forget to run the optimizer in all banks for the main rotor and the tail optimizer.. all banks. when you like the way it is, turn it off.. especially for main rotor cause if you have rescue and its on and try rescue, there could be problems.
Old 01-16-2021, 12:43 PM   #31 (permalink)
Ok, I'll do that and turn it off after. I wasn't planning to use rescue.
Old 01-16-2021, 12:59 PM   #32 (permalink)
nobody does, until you need it but rescue is always on.. no way to turn it off.
but both optimizers are important to run, let them do their thing, then turn them off.. just follow the directions
https://www.vstabi.info/en/node/1676
https://www.vstabi.info/en/node/1677
Old 01-16-2021, 06:50 PM   #33 (permalink)
Man...you guys are making this pretty easy to get something that is completely unfamiliar to me setup properly. I'll follow the links and run the optimizer in all banks. I'm running a YGE 205HVT with an Egodrift 2530 550kV and was trying to get it to bog during the first flight...wasn't having much luck!
I don't want to make any fine tuning until I get the tail and main blades I'll be running installed, just ran some old ones that I had...should be here in a few days.
I'll try to keep that error video and added ****"Applications/Mode Autoswitcher" was enabled and causing this issue. Uninstall this Application if experiencing this.*** to the description, maybe it will help someone else who decided to install all the apps and is on Helifreak. After that, everything was a piece of cake.
tonys-heli likes this.
Old 01-18-2021, 06:13 AM   #34 (permalink)
This is something I do in all banks. Takes the helicopter from feeling good to feeling great (for someone who doesn't know how to tune a FBL): https://www.vstabi.info/en/node/2043
Vcontrol Touch, AccuRC Simulator
Oxy 5 MEG, 4 MAX, 2 (215)
SAB Goblin 500 Sport
XL Power Specter 700
