Old 10-30-2012, 02:05 PM   #81 (permalink)
Default kds
Hi Ivor
I am getting crazy
I follow up every instruction, but I when I move the throttle stick I do not have any response from the motor.
With all the same wiring (with FM) if I change the model on the transmitter to the original one, the motor works!!!
I am getting crazy!!!
thank you
pkozloviz is offline        Reply With Quote Quick reply to this message
Old 05-26-2013, 03:42 AM   #82 (permalink)
Default JR XG8 (DMSS) FM setup
Dear All ,
I am new to the hobby and thats why i thought that going with the FM would be a good choice as it will help stabilise .. the heli ..
What i have a
*** HK-500CMT (TT) 3D Torque-Tube Helicopter Kit Align T-Rex Compat
** The Elevator servo in this model is back mounting
** The Aileron(Right side front) 1 and Pitch (Left Side Front) are in the front
What I have done ..
*** I have completed all the installation for the body as well as the electronics
What is the problem :
*** I want to know which wire from the FM will go into which receiver port
My receiver port looks like this
http://www.perthrc.com.au/images/detailed/1/1649.jpg
Ports on my Receiver
AUX2 Bind Batt Sense (Under the above line of ports)
AUX1 ""
GEAR ""
RUDD
ELEV AUX3 (Under the above line of ports)
AILE ""
THRO ""
Please refer to the Link to see the picture.
*** Some how with my present setup my elevator and pitch have switched while i am also not sure if the Gyro is working. (I am trying to start off on MODE 2 standard of transmitter)
Any inputs will be appreciated.
Regards
IshanThakur is offline        Reply With Quote Quick reply to this message
Old 05-26-2013, 04:58 PM   #83 (permalink)
Originally Posted by IshanThakur View Post
Dear All ,
What i have a
What I have done ..
AUX1 ""
GEAR ""
RUDD
AILE ""
THRO ""
Regards
Not familiar with your TX/RX but normally.
FM plug with 3 wire goes to aileron on the receiver. Yellow goes to elevator on receiver. Orange goes to aux 1 ( pitch )
If the FM gyro is going to be used to control the tail then Grey goes to rudder and green goes to gear.
Blue is used to select FM modes and set the gain and would normally go to aux 2 if it is a seven channel.
Blue and green are best left disconnected during set up and flight testing.
Please read the sticky ( please read first ) at the top of the section it is more up to date than this thread.
Ivor Hill is offline        Reply With Quote Quick reply to this message
Old 06-14-2013, 09:14 AM   #84 (permalink)
Default Flymentor wireing and setting up useing Helibal Trex and clones
Originally Posted by Jayray View Post
I am new to the forum been reading a lot. I also have a turnigy 9x and wish to adjust the Position hold and horizontal mode and gain via and or dial for my FM. I just don't understand how to setup total yet. I have gotten the flymentor to switch on and off by using the throttle cutoff and or the gear toggle. But I would prefer another, more like one of the dials.
Hi January I don't know if u got the answer already but to make the fm work from the front left dial place the blue wire into ch7 in the rx then on the aux ch settings set channel 7 to pitch trim , wallah u know have the dial to go from pos mode to balance mode depending on the dial position , now go to display menu and watch the display move when you dial the pit trim, when its at the centre position that is no display left or right mark the dial so u know where balancer is in off mode ,the fm will also be red as well
joshd is offline        Reply With Quote Quick reply to this message
Old 03-17-2014, 07:10 PM   #85 (permalink)
wiring the system now.
so far no flashing light in FM.
is the negative side of fm the one close to the edge? for the servos, i mean.
i see my rx lit.
will fiddle around more.
could use some help here.
thanks
prophead is offline        Reply With Quote Quick reply to this message
Old 03-17-2014, 07:13 PM   #86 (permalink)
does this PCC(porta programmer) needs battery too?
Old 03-18-2014, 04:13 PM   #87 (permalink)
No the programmer does not need batteries. Yes the negative wire on the servo's are closes to the edge. You will find the first sticky, Please read first. at the top of the page more helpful.
Old 03-19-2014, 10:01 AM   #88 (permalink)
thanks Ivor.
though i still have this tail servo jitter which is quite unsettling.
made a few adjustments on gyro gain ups/downs to no success.
tried another servo, less intense but it's there.
i do have another jr tail servo, but it's still at the post office that i'll pick up later and to try it.
could it be my power supply? i'm using a BEC @ 6v/separate rx pack. maybe up the amp?
so excited here since the swash is pretty level from mid to up and responds to tilts accordingly.
i have to go to sleep now. just came out from a night shift.
thanks again.
Old 03-19-2014, 03:29 PM   #89 (permalink)
Originally Posted by prophead View Post
thanks Ivor.
thanks again.
A low battery can cause servo jitters but it's unusual. No do not go above 6 volts I run all mine at 5.2 v without problems.
The FM tail gyro can be made to work ok but is not very good. If you are using a digital tail servo then have a look at the Assam GA250 gyro. It is a tiny SMS gyro that works very well, it is easier to set up than the FM tail gyro and is very cheap, about £8 from the Hobby King UK warehouse or about £15 on Ebay. Will save you a headache and you will have a much better tail gyro. But first check that it is compatible with your servo. Hope this helps.
Old 03-31-2014, 05:24 PM   #90 (permalink)
so I did s no-prop spool up today.
FM flashes red everytime I power the heli. I have to connect to programmer then I get the green light. at times, I have a green light but no response to the servos!
craps man.
loading and reloading from saved memories and sometime from default with same result.
is it my connections from Rx?
need help.
thought I had it.
cause when it does responds to cyclic inputs, all's well. though random.
Old 04-08-2017, 06:29 PM   #91 (permalink)
Default Flymentor problem
I've been reading all the info on the flymentor wiring,my problem is I cannot get it to initialise,keeps flashing red which i think is it is not getting a signal from the rx.I even changed the rx,rebound it again nothing works except the tail which has a align gyro connected.I am using a DX6i and a spektrum 6200 rx and the heli is a trex450.Any suggestions?
Doughoy is offline        Reply With Quote Quick reply to this message
Old 04-11-2017, 07:00 AM   #92 (permalink)
Has Ivor stopped posting on this now,was hoping for some pearls of wisdom from him on my problem with flymentor!
Old 03-09-2021, 10:22 PM   #93 (permalink)
Default Error codes
I know this system is quite old but mine has been operating faultlessly until now.After a minor accident on takeoff the flymentor now will not boot up and the led is flashing red.It pulses three times,pauses,three times,pauses etc and no response from the servos.I donít know whether this was a cause of the accident or the result of it.Any advice would be greatly appreciated.
engineern6719 is offline        Reply With Quote Quick reply to this message
