Like Tree2Likes
Old 11-28-2018, 03:33 PM   #281 (permalink)
Originally Posted by senzafine View Post
Hello I have two questions please.
Linux doesn't see my Jeti DS-14, how do I install the driver for this? Windows works fine. I can't seem to find any how too's googling it.
Can I view my flights by date in "Jeti Studio" like I can on my controller? So can I see I flew model 1, model 2 and model 3 x number of times that day.
Steve
I am not familiar with Linux but it should mount like any other USB drive. After that you can use Jeti Studio to see your flights from each model. It organizes them by date into folders. So you will see all the flights you did for a particular model for a certain day.
See my Jeti Studio tutorial video for more information. Fast forward to about 2:20 into the video.
JETI Studio 1.1.0 New Features (7 min 40 sec)
Gaui X3-Spartan VX1n | Gaui X4 II-Spirit RS | Gaui X7-Spartan VX1n | Gaui R5 V2-DEMON AXON |
JETI DS-14 | JETI DS-16 Gen2
iscripter is offline        Reply With Quote Quick reply to this message
Old 11-28-2018, 11:05 PM   #282 (permalink)
https://youtu.be/S-EbTEUi2g4
Thanks, I ended up needing to manually mount the drive. It all works after that.
senzafine is offline        Reply With Quote Quick reply to this message
Old 02-12-2019, 05:44 PM   #283 (permalink)
I just sold my DS-14 earlier today and the buyer reminded me to unregister the Jeti so he can register it to him.
Iíve logged into both Esprit Model and the Jeti Czech sites and neither show the transmitter in my account. I tried checking the Jeti US site and apparently Iím not registered there.
Can someone point me in the right direction?
DarkSyd3D is offline        Reply With Quote Quick reply to this message
Old 03-25-2019, 09:16 AM   #284 (permalink)
Default Reset capacity when changing the flight pack JETI - SPIRIT - HW - Telemetry
How do I reset the Flight Pack Capacity when changing flight packs?
I have an alarm set when my flight pack mah reaches 3500mah, this is done via the telemetry, this is for a Goblin.
I am using a DS14, Spirit fbl and HW 160amp esc v4 platinum.
The alarm works, but when I change the flight pack, I want the alarm to stop and the capacity used to go back to zero.
Clicking the logging stop and clear buttons doesn't work.
I have this all setup and working on my Tex, which uses a JLOG S32 , VX1n and HW160 amp, but for the life of me I can't remember how I did it, or if its a function of the JLOG.
On my Trex I have 2 MX switches setup , one is for when the Flight Pack voltage is <5v and the other for when its above 5v, the second one is used to start the logging, but this doesn't seem to work on with my Goblin.
Any ideas?
700N MJ DTS VX1N, Logo 690SX - VX1e, 780L Top - VBar Neo, 700L Top - VX1n, Logo 550SX - VX1n, Goblin 570 (6s) - VX1n, Trex 550E Pro DFC - VX1n, Trex 450L Dominator (6s) - VX1n, Trex 450 Plus DFC - VX1n, JETI, DX9, Pheonix R/C, AccuRC, neXt
99100 is offline        Reply With Quote Quick reply to this message
Old 03-25-2019, 11:21 AM   #285 (permalink)
Just turn the Tx off it will reset your mAh consumed.
TDSF, TDR-II, Triabolo, 2 X TDR, Logo 700,Protos evoluzione, T-Rex 700Dominator, Drake & Raw, SpiritRS, Jeti DC-24,HW,Kosmik,Jive Pro
Puttputt maru is online now        Reply With Quote Quick reply to this message
Old 03-25-2019, 03:11 PM   #286 (permalink)
Not really the solution I’m looking for
Old 03-26-2019, 07:49 AM   #287 (permalink)
Originally Posted by 99100 View Post
Not really the solution Iím looking for
I pretty much expected that but it is the easiest.
There is of course this LUA which has a special set up for Spirit
https://www.jetiforum.de/index.php/l...4-ds12?start=0
It has a reset button for telemetry. I use it because it is a nice display of all parameters but I still think turning the Tx off is easiest for telemetry reset and I donít hear the annoying ę*signal loss*Ľ voice when I change batteries.
Old 03-26-2019, 08:23 AM   #288 (permalink)
Is it something with spirit that stops it resetting the same as the S32 then?
Old 03-26-2019, 09:22 PM   #289 (permalink)
Itís been a long while... but I recall the S32 configuration software has a parameter for mAH consumed reset when a fresh pack is connected. Do you power off the heli when changing packs? I was running Rx packs and recall having to unplug the Rx to reset the telemetry mAH consumed. Maybe check in the Jlog forum.
The Jeti radio can reset the logged telemetry on the radio with a ďlong resetĒ depending on how you have the reset configured. I have my logging stop automatically when I cut the throttle. When I pull power from the model and Rx I press and hold the reset soft key on the DS14 to clear the logged displayed telemetry.
KC8CYF is offline        Reply With Quote Quick reply to this message
Old 04-16-2021, 04:02 PM   #290 (permalink)
Default Jeti Profi Battery Replacement
Before I do any real damage...is there a trick to getting the cover off of the Profi? I removed the three screws and there is still some resistance. Could there be a fourth screw under the label? Any other tricks??
kcasser is offline        Reply With Quote Quick reply to this message
Old 04-16-2021, 05:05 PM   #291 (permalink)
Cancel that thought... Yes there is a hidden screw under the label and I was able to take the unit apart. But, replacing that battery is beyond my skill set. It looks like a very thin, very flat lithium cell that's soldered to the pc board very neatly. I'll just keep running external power to it when needed and keep it going that way.
