Like Tree13Likes
Old 02-11-2021, 04:58 AM   #41 (permalink)
Originally Posted by Smoggie View Post
Originally Posted by bclark View Post
Will a R3 work on the M2 Explore?
Yes, but for the EX series receivers you need the special SBus firmware from Esprit.
The new REX series have SBus support with the latest official firmware.
Ok, so all I need is a REX receiver, and no special update, and just set the receiver output to SBus?
bclark is offline        Reply With Quote Quick reply to this message
Old 02-11-2021, 05:21 AM   #42 (permalink)
Correct, as long as the firmware is up to date the SBus option is available.
Gob Kraken |Gob 700 BT 'T' | Gob 770 Comp | SoXos Strike 7 | Henseleit TDR, TDSF & TDR2 | Kasama Dune | OMP M1&M2 | UK stockist for OMPHobby M1/M2 ScotiaRC.co.uk
Old 02-11-2021, 11:48 AM   #43 (permalink)
Old 02-16-2021, 05:08 AM   #44 (permalink)
So Iím having trouble getting this going using the R4L. I down loaded the sbus 3.24 firmware and loaded onto receiver, in device explorer I see no option for sbus and itís currently on UDI.
Any help please.
Simo71 is offline        Reply With Quote Quick reply to this message
Old 02-16-2021, 06:20 AM   #45 (permalink)
That's correct. Because it's a modified firmware you dont actually see Sbus as an option, it's still labelled 'UDI'. Just select UDI and Sbus will be enabled.
Old 02-16-2021, 06:24 AM   #46 (permalink)
Ok, what port should i use on rx? Thus far i cant get it working.
Ok i got it, for R4L it needs to be plugged into port 3.
Gee new transmitters are a learning curve.
Old 02-16-2021, 06:36 AM   #47 (permalink)
Port #4 I think
Old 02-16-2021, 08:16 AM   #48 (permalink)
Port #4 I think
Definitely port 3, it was a case of live die repeat till I got it.
Smoggie likes this.
Old 02-24-2021, 08:12 PM   #49 (permalink)
Default setup problem
Guys, I'm lost
1) R4i - Updated to 3.25
2) Receiver Bound
3) Device manager R4i set to UDI ( says Y4 ) so.. sbus connected to pins 4
4) R4i connected and live, able to access in device manager.
5) Mapped in transmitter.
6) throttle set 100%
OMP controller lights up and beeps but no JOY
Do I need to tell OMP controller its using sbus?
Any help would be appreciated, thanks much!
Note: I did accidentally change the pin out puts in receiver and don't know if this is a problem or how they were originally set
Its all about having fun
ShaneJourdan is offline        Reply With Quote Quick reply to this message
Old 02-24-2021, 08:54 PM   #50 (permalink)
Default OMP M2 With JETI
Plug to #3 on your RX4light receiver
ID:	906453   Click image for larger version
ID:	906455   Click image for larger version
ID:	906457   Click image for larger version
ID:	906459   Click image for larger version
Henseleit TDR,TDR 2, TDF, TDSF, Diabolo 700BE, Diabolo 700UL, Goblin Raw, Touch, Neo.
Azimuth114 is offline        Reply With Quote Quick reply to this message
Old 02-24-2021, 09:04 PM   #51 (permalink)
I did try that, ok now plugged into #3 on RX4. still no joy.
my screens look the same as yours.
Could you please provide a screen shot of your "receiver outputs" in device manager rx4, this is what I may have screwed up??
Thanks a ton for your help.
Old 02-24-2021, 09:13 PM   #52 (permalink)
Default OKP M2 With JETI
PM if needed
Old 02-24-2021, 09:15 PM   #53 (permalink)
PM if needed
well dang, my screen looks the same as well. thank you.
Old 02-24-2021, 09:18 PM   #54 (permalink)
PM
Old 02-25-2021, 12:46 AM   #55 (permalink)
Originally Posted by ShaneJourdan View Post
1) R4i - Updated to 3.25...
you should be using 3.24 sbus "special" firmware....
some helis, YGE, Egodrift, Spirit 2/RS/GT/GTR, Jeti DS-12/Spirit Ed.
Old 02-25-2021, 01:35 AM   #56 (permalink)
^^^ exactly. The Sbus firmware is a special modified version of 3.24.
Download link: https://file.espritmodel.com/firmwar...x_324_SBUS.zip
Note that it still shows 'UDI' in device manager, just select UDI the output will be Sbus.
Old 02-25-2021, 07:59 AM   #57 (permalink)
Let the fun begin, the little guys has initialized!!
I misread and downloaded UDI rather than Sbus 3.24
thanks much!!
Old 06-06-2021, 03:49 AM   #58 (permalink)
Default Problem Deadband Jeti
Hello everyone, I have a little problem with my Rsat2 configuration, I have a very large deadband, including pitch and roll, do you have the same problem? if so how did you solve that?
Greetings Christoph
Bara68 is offline        Reply With Quote Quick reply to this message
