Go Back   HeliFreak > R/C Electronics Support > Futaba Radios and Electronics > Futaba CGY750 FBL System
Futaba CGY750 FBL System Futaba CGY750 Help and features Support Forum
Old 06-06-2021, 06:52 AM   #1 (permalink)
Default Heli drifts backwards
Hi All,
I have a Soxos DB7 running a CGY750. The heli is nose heavy, but when hovering will drift backwards. When inverted, it behaves as it should being nose heavy and drifts forwards.
Swash has been levelled using a Soko tool.
Full pitch climb outs are straight up.
I have even gone to the extent of deliberately tilting the swash forwards by extending the servo links, but it still ends up drifting backwards.
Does anyone have any suggestions on what to change?
Thanks.
Regards,
Nigel
Gaui NX7 | Soxos DB7 | SAB Goblin Fireball 280 | Controlled by JR XG14
Nige69 is offline        Reply With Quote Quick reply to this message
Old 06-07-2021, 12:34 PM   #2 (permalink)
Anytime I have experienced drift it was a vibration issue. I ran into this on a helicopter 2 years ago. I tried all sorts of things.
In the end loosening the blades just a little bit did the trick.
Futaba 18SZ (CGY750/760) Gaui X3, Goblin Buddy, Synergy 516s, Synergy N556, Synergy N7, Goblin Kraken, Goblin 700 Sport
colemn615 is online now        Reply With Quote Quick reply to this message
Old 06-07-2021, 11:09 PM   #3 (permalink)
I would also take a look at your head gain. Stock is 50, and I found on 3 seperate units that the head gain is happier around 65-75. I had drift issues on an nx4 and a N5c. I replaced links and though let it solved the issue but still had a slight drift. once I increased the head gain it solved it.
Valon82 is online now        Reply With Quote Quick reply to this message
Old 06-09-2021, 05:28 AM   #4 (permalink)
Thanks Guys.
Never experienced such a specific drift before. I have seen drifting in all directions due to vibration, but not just "back elevator"
Base gain on the CGY is the default of 100%. Gain is then controlled via a trim switch on my radio. On the weekend I increased the gain till I was getting noticeable oscillations on fast forward flight, but when brought back to a hover, it still drifted back.
The main blades are not as tight as I usually run. I have also tried 3 different sets of blades (1x AZ700, 2x 1st 690 blades)
Regards,
Nigel
