Go Back   HeliFreak > R/C Electronics Support > Spektrum FBL System > Spektrum FC6250HX
Old 06-11-2021, 09:21 AM   #1 (permalink)
Default Missing Frame Rate and Type setting! SOLVED
I bought a used FC6250HX and update the firmware to 5.0, reset factory setting.
Install and go through the usual setup steps.
In FP, Setup->Swashplate->Output Setup... I do NOT get the usual menu but only Sub Trim!!
So, I can NOT set the Frame Rate, Swash type, etc.
However, even though I did NOT set the frame rate, the cyclic servos are working fine except incorrect direction of course.
What goes wrong here?
I set up several others before with no such issues.
tanasit is offline        Reply With Quote Quick reply to this message
Old 06-11-2021, 12:24 PM   #2 (permalink)
HF Scale Support
What helicopter did it come out of? Was it a pull from a 330/360 or was it a retail box?
Don
Old 06-11-2021, 02:28 PM   #3 (permalink)
Don
Retail BOX full version.
Old 06-11-2021, 05:31 PM   #4 (permalink)
You might check to see if there's an update for the radio. I had something similar where going to the swash type selection I had a blank screen. Mine had an update available and after I could see what wasn't there before.
nubs is offline        Reply With Quote Quick reply to this message
Old 06-12-2021, 07:39 PM   #5 (permalink)
Thanks but the same TX (DX18G2) works fine with the other FC6250HX.
WIll try the update though.
EDIT-1: Updated from 2.07 to the current 2.08 but still doesn't work!!!
EDIT-2: Update the firmware on the FC6250HX again (same 5.5) and now it works.
Old 06-12-2021, 08:09 PM   #6 (permalink)
HF Scale Support
Update the 4651T and then try it again. When you update the 6250, the 4651T is not updated at the same time.
Don
Old 06-13-2021, 07:35 AM   #7 (permalink)
Don
Thanks but it's working now.
So I am not sure if I want to update the 4651T unless it has more benefit??
Old 06-13-2021, 09:45 AM   #8 (permalink)
HF Scale Support
I don't know how much attention you paid to one of the busiest threads in the MSH Electronics Brain FBL section of the forum but it is very important to update the 4551T because of an error in how it handles a loss of signal and passes it along to the 6250 and other FBL controllers. Update it as the problem can be hidden and then one time you get into a position where the remote will get a false Hold and that will force the 6250 to restart the ESC. It is a long thread to read but it has been tested and the new firmware works as it should.
Don
Old 06-13-2021, 03:43 PM   #9 (permalink)
Don
https://www.helifreak.com/showthread...ighlight=4651t
Ok thanks, I did the search and found those above.
Kindly post the link to the discussion you mentioned that I miss.
Thanks again,
Old 06-13-2021, 11:19 PM   #10 (permalink)
HF Scale Support
This,
https://www.helifreak.com/showthread.php?t=885009
Skip to the last couple of pages.
Don
Old 06-14-2021, 07:45 PM   #11 (permalink)
This,
Don
I read parts of those earlier but did NOT connect the dots.
Thanks for pointing this out and I will update the firmware right away.
Good find in deed.
