Like Tree33Likes
Old 12-15-2020, 07:30 AM   #61 (permalink)
Originally Posted by richardv View Post
I often sync to a hotspot in the middle of a day, just to update my flight count or be able to view my latest settings.
I do the same thing. After my last flight of the day, I fire up my hotspot, connecting my VBCT and then I pack my stuff up, with my radio being the last thing I put in. I have a 40 minute drive from the field, but it's there when I get home, but really only takes a few minutes or less.
richardv likes this.
My custom charging case build
RCHN #633
Team SYNERGY
Old 12-16-2020, 08:06 AM   #62 (permalink)
Getting this again. Cleared cache and DB with no change in results. Problem exists in Safari on my Mac and on my iPhone.
An unhandled error has occurred. Reload
(2) Protos Max Leggero/VBarNeo/Tribunus200/Xnova/VTX717;rEVO715, Logo 200, VBar Control Touch
Caeguy is online now        Reply With Quote Quick reply to this message
Old 12-16-2020, 12:52 PM   #63 (permalink)
Ok, I see. Not a big deal.
I’m glad you’ll have this available for when I decide to upgrade my TX.
Dave, the problem with adding data that doesn't come from VStabi, is that when you change devices, or run the app on multiple devices, the data doesn't transfer between them.
If I was to add a sync feature that allowed storing data centrally, I would have to run a database, which would increase my costs. At the moment I'm paying hardly anything for a bit of data transfer.
The VBC Analyzer is great. I missed it so much when I changed to the touch, I had to write this. The touch is great though. I often sync to a hotspot in the middle of a day, just to update my flight count or be able to view my latest settings.
Diabolo 700UL / Logo 700 / Oxy 5 / Goblin 500 / Oxy 2 FE / Blade 180CFX / mCPxBL / nano CPS / V-Bar NEO / V-Bar Control / uBrain / DX7
3D Dave is offline        Reply With Quote Quick reply to this message
Old 12-23-2020, 06:33 AM   #64 (permalink)
Hi, No flightgraph of nitro models?
TIA
Align 800e PRO DFC // KRAKEN Yellow // Align 700N DFC, 105HZ-R HV // RAW Yellow // 2x Goblin 420 // RealFlight 7.5 // neXt // AccuRc // Tribunus - Vbar Control Touch - Vbar Neo
msallua is offline        Reply With Quote Quick reply to this message
Old 12-23-2020, 06:53 AM   #65 (permalink)
Did you get one with the program written sometime ago for the VBC?
Do you have a sensor that gives engine output power?
Don't quote me to answer please, just add a comment.
Old 01-02-2021, 11:46 AM   #66 (permalink)
anybody else getting this
Error, unable to load models.
| Kraken 700 : Neo | Atom 6HV : Neo | Align 500X : Neo | vbct : |
ragge1 is online now        Reply With Quote Quick reply to this message
Old 01-02-2021, 12:10 PM   #67 (permalink)
I'm getting the same. Mikado have changed their website and it looks like they've removed the option to delete models, batteries and flights.
It might take me a few days to figure it out but I'm on it
ragge1 likes this.
XL Power - EGODRIFT - ManiaX - Hely-shop
facebook.com/3drchelipilot
richardv is offline        Reply With Quote Quick reply to this message
Old 01-02-2021, 02:41 PM   #68 (permalink)
Version 1.126 is up.
It looks like Mikado changed their site to not show the delete buttons by default. You have to select the controller from the drop-down first, which is what messed up the loading.
After I fixed that issue, I found the app didn't load all of today's flights, so I had to use the "Clear Database" button and login again to get them all. Mikado may have reset the numbering, but if it keeps doing it, I may have to find another way to do incremental updates.
As ever, please report any bugs here.
Old 02-18-2021, 01:56 PM   #69 (permalink)
Hi!
"Error, unable to load models" Any fix for this?
Logo 200, Goblin 380, Align 500XT, Sab Kraken 580, Trex700DFC, Sab Black Thunder 700, Sab Raw, V -Control touch
jazfonque is offline        Reply With Quote Quick reply to this message
Old 02-24-2021, 10:29 AM   #70 (permalink)
delete
Old 02-24-2021, 04:57 PM   #71 (permalink)
Try to logg in but it won't
Lots of Requisting flight pages , then error can not load flight hmm
Skickat från min SM-G950F via Tapatalk
Old 02-25-2021, 02:27 AM   #72 (permalink)
Mikado seem to have changed something again, which causes the app to load flights that aren't yours sometimes.
Mine seems pretty stable if I set the year to 2021, hit the Clear Database button, and then login once again to download.
I'll have a look this weekend, to see if I can do anything to make it more stable or catch the irrelevant flights.
Old 02-25-2021, 02:30 AM   #73 (permalink)
A few people have reported this and it normally comes down to one of the models being retrieved from vstabi.
One way that seems to have worked for a few people is to go through the list of models on vstabi, make sure they all have images and remove any models that were for test, etc.
I'll have a look this weekend to see if I can make it skip any models it errors on.
Old 03-11-2021, 02:32 AM   #74 (permalink)
Version 1.143 is up.
Fixed - model load
Some users were reporting login failing at models. This has now been set to ignore any failed models and continue the load. I'm still not sure why, but in one case it was related to an invalid image on vstabi cloud.
Added - years to Flight by Month chart
Updated - Performance improvement
Improved data loading on the home page
To Do - Login issue
There's still an issue where logins are loading flights that don't belong sometimes. The weather is pretty bad over the next few days, so I should have this resolved by Monday.
https://www.facebook.com/3drchelipilot
I've created a page on FB that you can follow for updates, or to suggest suggestions/bug fixes. I will still continue to check on here, but you'll get a faster response on FB.
ragge1, Grimmy and tonys-heli like this.
Old 03-12-2021, 04:55 AM   #75 (permalink)
Why I don't have flightgraph of a nitro machine?
Old 03-12-2021, 06:47 AM   #76 (permalink)
Because I don't fly nitro unfortunately.
Which means I have no logs to analyse, so I can't see what's available on vstabi .
BTW 1.144 is up.
This is fix for random flights in load. If you clear the database and login again, it should all be good.
ragge1 likes this.
Old 07-18-2021, 10:27 AM   #77 (permalink)
Anyone else having trouble logging in? I know I've got the right credentials, but it keeps saying error, possibly invalid username/password, but I can log into Vstabi's site.
RCHN #633
Team SYNERGY
Old 07-18-2021, 12:36 PM   #78 (permalink)
Mikado has blocked the app from there site , I believe Richard and mikado are talking about it , hope they can make it work again
Old 07-18-2021, 12:52 PM   #79 (permalink)
First I want to say bummer! I hope they can work something out, as that was super helpful, and looked and functioned very well!
Thanks for the info ragge!
RCHN #633
Team SYNERGY
