Go Back   HeliFreak > R/C Electronics Support > Spirit FBL system
Spirit FBL system Spirit FBL System Discussion
Old 08-02-2021, 03:58 PM   #1 (permalink)
Default Jive Pro and Spirit RS Telemetry and Governor
So I have this question about the Spirit RS and the Jive Pro, since I’m going to all Spirit RS’s on the other 4 helis. So I’m using a TellMe with the Jive Pro for telemetry and I’m going to use the Sprirt Governor.
What so the I-Motor Shunt?
Also do I need to change the flight mode in the JIVE esc to airplane before activating the governor in the Spirit?
Is there anything else that I need to do to get this telemetry going and also I’m assuming I need to put in the gear info, capacity battery, and motor info for rpm telemetry?
Is there a difference between the Jive info and the spirit info as far as what I display through the Jeti?
Example SRPM vs Jeti RPM
Dark Poacher is offline        Reply With Quote Quick reply to this message
Old 08-03-2021, 05:34 AM   #2 (permalink)
Hi,
maybe i missed some information about that... but afair the Kontronik Escs generally do not really work (well, HeliJive did) with external governors. but their internal gov is know to be really really good.
regarding "i-mot shunt": this one is to fine tune the mAh used telemetry given by your Esc. sometimes the measurement of the Esc is not 100% accurate... just set the i-mit shunt to have it adjusted to meet your need.
Ciao
Michael
minicopters & Logos, YGE, Egodrift, Spirit 2/RS/GT/GTR, Jeti DS-12/Spirit Ed.
Old 08-04-2021, 08:10 AM   #3 (permalink)
So I can’t use the gov in the Spirit if I fly Kontronik? I’m just trying to set the head speed as accurate as I can. I figured it would be easiest to use the Spirit since I can input the numbers I want.
Old 08-06-2021, 09:43 PM   #4 (permalink)
Also last question, I have a TellMe cable connected to the Spirit back to the Jeti, is this not needed since the Spirit is already integrated to see telemetry?
Old 08-10-2021, 01:27 AM   #5 (permalink)
You can use Governor with Kontronik telemetry without any problem.
No need to use TelMe module from Kontronik. You can use Spirit TelMe cable that is much cheaper and lighter to directly connect with Spirit unit.
Spirit System - www.spirit-system.com
ZeXx86 is offline        Reply With Quote Quick reply to this message
