Evil Tail Problem - HeliFreak
Old 10-24-2008, 01:29 PM   #1 (permalink)
Location: In deep space, abandoned. Any crew? Negative.
Default Evil Tail Problem
My tail is screaming - loud, and it shakes up and down. I thought I had it fixed with the Trex hub I put on there, but when it finally gets up to speed, it's not happy. It shakes so hard the tail fin is about an inch-long blur up and down, but only on the left side - opposite the tail.
All of the tail case parts are new, as is the belt and the drive gear up front. Tail boom is new, pitch slider and ball links are new - everything is freeking new! I don't understand what is causing the problem - everything is balanced too.
The only thing I can see is when I look through the little hole at the front pulley, the belt seems to get wider and skinnier as I rotate the head.
I took this helicopter in to the hobby shop and they couldn't figure out the problem either... does anyone have any ideas what I can do? If it's "get the metal parts" then yes, I'll be doing that as soon as they are available, but really, I would like to just get her flying again with the plastic parts. I don't understand how it can go this bad when everything is new...
Is there something obvious that I'm missing??!
Jasmine2501 is offline        Reply With Quote Quick reply to this message
Old 10-24-2008, 01:39 PM   #2 (permalink)
Dumb questions, but do you have new bearings in there too? Are you sure the blades are balanced? It shouldn't matter if they're plastic parts, it shouldn't be that bad. Could you have a bent shaft or drive in the front pulley? Did this start after a crash? Some pics may help.
Spektrum DX6i, TRex 450SE V2 black , Scorpion 2221-8, Heliartist N23CP Hughes500D
TRex 450SE V2 silver, Scorpion 2216-12, w/Spidergear, DarthDark Hughes300C, Blade MCX, HK-450, Cessna 182 foamie, 2 AR6100
If it ain't broke, fly it...
JEB123 is offline        Reply With Quote Quick reply to this message
Old 10-24-2008, 01:41 PM   #3 (permalink)
Balance. And it won't work to balance just the blades.. but you need to balance the entire tail. Here's how I did it. Put a dot on one tail (just to recongnize the blades) .. put a 1/4" pience of electrical tape on one blade. (take main rotors OFF for this).. spool it up. better or worse? Worse move that piece to the other blades.. totally experiment.. After around 10 minutes (are 20 or so scrunched up pieces of tape) I finallly got it from wild vibe to small vibe. Impossible to get it totally smooth.
Old 10-24-2008, 01:42 PM   #4 (permalink)
So your saying the horizontal tail fin is what is shaking? But only the left side of it? Unless it's weak itself, that means the axis of rotation is on the right side of the tail fin. Funky. Is that the only thing you see shaking or do you see the entire tail boom shaking and is it up and down, left/right or a twisting shake?
My tail vibration issues have always been related to main blades/head balancing and tracking. But you say yours is balanced. Recently, my tail was wagging cause one of my paddles came loose and was not a 0 degrees, it manifested itself though in poor blade tracking.
Do you have a way to strap the heli down to something and run it up w/ parts of the tail head removed?
dditch66 is offline        Reply With Quote Quick reply to this message
Old 10-24-2008, 01:56 PM   #5 (permalink)
Yes.. when you balance the tail (like the way I mentioned) you must remove the WHOLE head assembly really to get it right. Check for slight main shaft wobble when you have it off too.
Old 10-24-2008, 02:18 PM   #6 (permalink)
Yes, I can hold it down and run it up. Been doing that with the main head removed, so it's just the main shaft and the tail running - still have the problem. The bearings in the tail case are new, but the ones that hold the drive pulley in front are old. This did happen after a crash in which I re-built the whole helicopter. First flight after the rebuild was ok, but the problem has been getting worse since then, and now the heli is shaking so bad that it shouldn't be flown - although it will still fly.
If you look at this picture, you can see a small shake in the tail fin, which all Blade 400s apparently have. Now imagine that little blur being 10 times that size, and really loud sound from the tail... that's my issue. I know about all the basic things to do, but was really looking for some arcane thing particular to the Blade 400 - some bad part, poor alignment, missing washers, some known issue that isn't common. I've done everything I know how to do and the problem is still there, so was just wondering if someone had a nugget of info that I missed.
Old 10-24-2008, 02:33 PM   #7 (permalink)
How's your belt tension? Could it be too tight, or too loose? If not, I would change out those front bearings. A bad bearing there could cause the belt to oscillate. It would also be noisy. Does it get progressively worse, or does it start to improve again after a certain speed?
Old 10-24-2008, 03:58 PM   #8 (permalink)
I have tried various belt tensions from way too loose to super-tight, and doesn't seem to get rid of the problem, although super-tight did seem to reduce the problem a bit. I'll change out the bearings I guess - that's the last thing I haven't changed. Does anybody know what size those are?
This vibration gets much worse at a certain speed, just below flying speed is when it's the worst, and it gets a little better above that, but the vibration never goes away, and it's there at lower speeds too, you just don't really notice it till it builds up. It is a harmonic resonance building up, but I don't know what is the source of that. Going to try fixing the bearings and putting in a different belt - then I'll post some video if I can't figure it out.
Old 10-24-2008, 04:08 PM   #9 (permalink)
Exactly, that's why I asked about it doing it at a specific speed. Could be that the belt is oscillating and the tail tube is resonating at a certain freq. making it worse. Or maybe I'm totally wrong and it's something else! Don't know what bearings that bird uses but I'd definitely at least check them. Good luck with it, let us know what you find! I get good prices on bearings here:
http://www.bocabearings.com/main1.aspx?p=docs&id=3
Old 10-24-2008, 04:15 PM   #10 (permalink)
Hi,
You might want to take a look at the end of the tail boom, the end that slides into the main frame. Sometimes that end can get bent inwards, causing it to actually touch the belt.
Also make sure that the holes of your tail blades are not worn out. They wear out over time and get an oval shape, causing them to be out of balance.
Do the tail blade grips have enough play to "flap" the tail blades?
Does your tail hub sit firmly on the tail shaft?
The tail slider ring can sometimes get caught at the slider pin screws, causing vibes. Just see whether you can spin the slider ring freely.
Is your tail shaft lubed with TriFlow?
Are _all_ of the ball bearings in the whole tail system ok and without slop?
Is the belt tensioner ok or too sloppy or too tight?
The tail case, did you tighten the two halfes too much? Usually, the very end of the tail case shows a little bit of a gap when mounted. If too tight, the tail case bearings might be too much under axial pressure and start to be notchy or lock up.
Long list ...
Best,
Frank
P.S.: Nice landscape in the background!
Tail boom is offline        Reply With Quote Quick reply to this message
Old 10-24-2008, 05:01 PM   #11 (permalink)
That is actually something I have thought about - I did put them on there really tight, and while I was on lunch today I was thinking if maybe that caused a distortion of some kind, it could cause the problem I'm having. It is taken off right now, but maybe I'll put it back on and make sure it's not so tight before I go trying bunch of other stuff. Going to go pick up a new boom too, because I think sometimes they can be a little off like you said. Everything else you mention is tight and right - the Trex tail hub has a lot less "flap" in the grips than the E-flite hub, but it's not completely rigid, and should be just fine.
None of these parts has any more than 1 flight on it, so they aren't worn out or having stripped holes or anything.
Again, if anyone know the size of the bearings in the tail drive, please post it... I've got multiple sets already at home and probably have the right ones, but you know I hate to be in the middle of fixing something and have to stop and wait for the LHS to open the next day... so I can pick up the right bearings after work today, but nobody seems to know which ones they actually are.
Old 10-24-2008, 05:05 PM   #12 (permalink)
Hey Jasmine! Don't see you around this forum very much! I didn't even notice who was asking the question.. I was just typin'
I am really anxious for the REAL Horizon B400 metal tail stuff to become available. I think I would bite... even though it will be as pricey as Align stuff. CopterX just didn't do it for me at all. I'll be back to my newly balanced stock tail.. going out shortly in fact to fly 6 batteries!
Old 10-24-2008, 05:12 PM   #13 (permalink)
I just took my tail drive apart last night and should have measured I guess, but they look like the 3X6X2.5's that are in the tail case.
I just test fit a set of these bearings on the tail drive and ths ID is the right size, I'm pretty sure THESE are the ones.
BennyTRD is offline        Reply With Quote Quick reply to this message
Old 10-24-2008, 05:22 PM   #14 (permalink)
Jasmine,
Did you check the tailboom support rods and the landing strut mounting tabs on the frame?
Sometimes the boom supports come apart at the connectors and the little mounting tabs, for the struts, can crack or break off of the frame.
Both of those problems will cause serious vibrations to the tail fin.
Bearings, tail case or drive gear/pulley is my second guess.
Jonathan Livingston Helicopter
Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.)
CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG.
T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades.
Wolfpackin is offline        Reply With Quote Quick reply to this message
Old 10-24-2008, 06:47 PM   #15 (permalink)
Well, to be honest, I'm a little embarrassed that I can't figure this out myself. I am afraid to admit my failure to fix this issue and didn't want to ask on the other forum because of that. I suppose we all have problems from time to time, but I'm extremely frustrated at not being able to figure this one out. Ever since I did my complete rebuild, I've only got one flight on my Blade because of this problem. I stand by my rebuild videos as being totally correct, but clearly I missed something important.
Old 10-24-2008, 07:43 PM   #16 (permalink)
well... its just inherent in the b400 to some degree.. I just flew six batteries and on the way to spooling up to idle up. my left horizontal fin vibes to at least 1/2" and then calms down but still.. flying.. it's buzzing.
Old 10-24-2008, 08:19 PM   #17 (permalink)
Other forum? Sorry, I'm new so I'm not familiar with another forum so give me a hint so i can avoid being thrashed there too.
Never be afraid to bring up a topic. This is aviation and in most organizations, no question is ridiculed. The breadth of knowledge is such that, you may have worked through a problem and later on, forgotten how to do so. Asking can get you enough of an answer to remember what you did. Or, learn something new, or a new way to do the task.
Aviation and IT are like this such that the participants can discuss the various aspects without being shot down for having asked. That's because everyone has forgotten something temporarily and simply needs a nudge.
No one is perfect so they don't dare toss a stone
TowPilot is offline        Reply With Quote Quick reply to this message
Old 10-24-2008, 08:33 PM   #18 (permalink)
Jasmine, found this on another thread, might help?
Direct to post
https://www.helifreak.com/showpost.p...9&postcount=15
Beginning of thread is at
Beginning of Thread for above post
Old 10-24-2008, 09:03 PM   #19 (permalink)
I had a similar problem and it turned out to be a bad tail blade grip. It had just a little more play than the other. Another time I was lucky enough to purchase a bad tail hub. It was bent from the factory.
Chasing down tail problems can drive you nuts.
Here's a link to an old thread, hope it helps or at least eliminates a few things.
https://www.helifreak.com/showthread.php?t=81050
Redfire SVT is offline        Reply With Quote Quick reply to this message
Old 10-24-2008, 09:07 PM   #20 (permalink)
so your the other video maker just like to say thanks
so loud vibrating tail eh
try to check its with out the main blades on to see if you still feel the vib
this will determine weather is tail or hub may still be both
the lil belt pully gear in the frame also could be your culprate. check slider control belcrank as this thing will have a bent screw on occation and if your slider bearings are too tight will also cause probs
also the bushing in the tail is of its own size may be a lil long or short
i know this may sound dumb but the tail blades are leading edge controled
and make sure the rex hub bearings are not seizes
hope you find your issues
B400 DS285/3400G/401/-8/40Aesc/sonicCNC/CNCframe
TwinRexx: 6xHS-65/2xGY240/jfg500/TH2
CH-47D/UH-1H Crewchief/ Mechanic
sokal is offline        Reply With Quote Quick reply to this message
Insurance
