Like Tree1Likes
Old 09-24-2008, 02:07 AM   #1 (permalink)
Team Taco VP
Default Aerospire MultiGov Pro Setup Videos
Well I finally got a MultiGov to try out! Special thanks to Aerospire. I was helping someone on the forum a few weeks ago with a MultiGov question and Aerospire PM'ed me and asked if I was interested in trying a MultiGov. They did not ask me to do a video setup but you know me
This unit has some serious features! I cant wait to get it installed and replace my Carb Smart and reduce my component count and wiring
Anyway here is a set of "on the bench" setup videos explaining the unit and showing you how to set up.
Overview of the MultiGov and it's Features
Video Link ->Overview and Features (22 Megs)
Connections for the RX, Servos, Sensors, etc
Video Link ->Connecting the unit up (40 Megs)
Hardware setup discussion and "base" radio config for X9303 and the DX7
Video Link ->Hardware & Basic Radio Setup (39 Megs)
Menu Structure and Gov Menu Setup
Video Link ->Gov Menu Setup (47 Megs)
Mixture Menu Setup
Video Link ->Mixture Menu Setup (35 Megs)
Advanced Menu Setup
Video Link ->Advanced Menu Setup (35 Megs)
Setting the Throttle Curves before you fly
Video Link ->Basic Throttle Curves Setup (35 Megs)
OK that does it for the basics of setting up the MultiGov. I will now get mine installed and tested in the field. I will come back with a follow up video of any changes I made for my T600 and how the unit worked out! So Stay tuned!
Bob
Old 09-24-2008, 05:24 AM   #2 (permalink)
Hi Bob the -- Video Link ->Mixture Menu Setup Is not working
madmick is offline        Reply With Quote Quick reply to this message
Old 09-24-2008, 09:15 AM   #3 (permalink)
I am going to try the Spectrum sensor on my Raven because of the difficulty of a standard sensor mount. I have heard that it should work.
Rob...
RadioRob is offline        Reply With Quote Quick reply to this message
Old 09-24-2008, 10:30 AM   #4 (permalink)
Team Taco VP
Ooops.... typo! It's fixed.
Bob
Old 09-24-2008, 10:30 AM   #5 (permalink)
Team Taco VP
Rob...
Yes that sensor will work with the Multigov.
Bob
Old 09-24-2008, 02:25 PM   #6 (permalink)
Have been waiting for the Multigov video.I am downloading now.
Thanks Bob!!
- Michalis |OXY Heli|XNova Motors|
...let the flying be second nature!
acidla is offline        Reply With Quote Quick reply to this message
Old 09-24-2008, 11:20 PM   #7 (permalink)
i have been running the multi gov for about 14 months now and it has been flawless I had time to mess with my friends pro and it with the added stuff is setting the bench mark for govs.( he was using the gv1 before 150 bucks and now knows why i was bugging him to smash his gv1)
sonofcar is offline        Reply With Quote Quick reply to this message
Old 09-27-2008, 07:05 PM   #8 (permalink)
Been using the multi gov for over a year. Chung set it up for me in vegas finaly bob did a video so I can set it up right myself. Not to say Chung did it wrong but you never know what youll get from the guy who hung his heli on a fishing pole to learn inverted hover. Thanks Bob
cmoney79 is offline        Reply With Quote Quick reply to this message
Old 10-01-2008, 11:55 PM   #9 (permalink)
I have been waiting for this series to come for a LOOOONG time! THANK YOU FINLESS!!!!! Cant wait to get your opinion on it as this is the only gov I have ever used I'd like to hear a comparison or a "Finless Approved" stamp on it!
heliadict1212 is offline        Reply With Quote Quick reply to this message
Old 10-20-2008, 12:57 AM   #10 (permalink)
I just installed the gov with the spektrum sensor. But when I test the sensor, it's always "ON" and when the crankshaft is in front of the sensor it's "---". I was waiting for an inverted behaviour... Can I fly like this?
lionc is offline        Reply With Quote Quick reply to this message
Old 10-20-2008, 10:49 AM   #11 (permalink)
Team Taco VP
What motor? If a YS motor then you have to back the spectrum sensor off the back plate a little.
Bob
Old 10-20-2008, 10:57 AM   #12 (permalink)
It's a TT 53 RL. But I will try this. Thanks a lot.
I tried to add more space, it's working very well.
Old 11-06-2008, 05:42 AM   #13 (permalink)
Bob,
How the '3D' mode in the governor mode perfomed? Also, have you tried the limiter mode?
I dont understand why the people at Aerospire recommended that u turn off the limiter, and use the governor mode.
Cheers
Old 11-08-2008, 10:44 AM   #14 (permalink)
Because the MGP, in gov mode, reads the throttle curve and can actually advance the throttle BEFORE the RPM drops.
The old thing that limiters react quicker is BS. If they don't have read ahead, they still have to wait for the RPM to change to respond. Any good governor should be able to respond as fast as the servo does. Maybe in the early days with slower processors, a limiter would "feel" better, but I can't see it with a recent product design.
Terry
AMA#47402, IRCHA # 3395
Old 11-08-2008, 10:51 AM   #15 (permalink)
Team Taco VP
I disagree on your comment about the limiter. Other than the multigov, a limiter has always worked better. It is not chasing the rpm on both the low side and the high side. It JUST looks for overspeed. Your throttle curve is 100% flat and a limiter only touches the throttle when it starts to see an over speed.
Most govs I have tried (I have tried a lot of them) have a problem with under speed. e.g. come out of a loop and it drops the rpm too much. Increasing the middle idle curve point doesn't help either! To fix this you have to teach the gov that the low stick is not as low (when your programming it). Royal pain in the butt as it is trial and error. With a limiter you don't have to do that and overall a limiter reacts faster as it is only doing one thing... Limiting.....
The multigov is the first governor I have used that does not seem to have this problem so the software does a good job there!
Bob
Old 11-09-2008, 03:05 AM   #16 (permalink)
Is there a reason for running the centerpoint so high Bob?
I mean, a centerpoint at 80% would make the heli scream in case of a sensorfailure or losing a magnet.
My understanding of govenors is that as long as you dont have a throttlecurve that dont go below the armingpoint of the gov it wont care what your throttlecurve looks like.
So, cant we use a "flyable" throttlecurve on the multigov?
Then in case of a failure of some sort you still could fly in for a landing instead of having to auto it down.
Jan
Futaba T14SG, Copterx/align 450 Pro miniVbar, Tianzi TZ 50 (Stinger 50), T-Rex 600N pro Vbar, Kasama Srimok 90n ECO Vbar, Minicopter Diabolo 14s Kosmik200 pyro800 Vbar
Y@nkee is offline        Reply With Quote Quick reply to this message
Old 11-09-2008, 12:04 PM   #17 (permalink)
Bob
I did say a GOOD governor. Actually I was talking about the MGP and didn't want to dis any other govs that might also do a good job.
Yes, some of them don't do this, but that is because they aren't reading the throttle curve properly. The throttle curve shouldn't do anything except clue the gov that the pitch is increasing or decreasing. Not really how much.
Talking with Bob of Aerospire yesterday, (he was wondering when you were going to visit? ), for gov mode on the MGP the best throttle curve in Idle Up is 100 - 65 - 100. Steeper can cause the gov some trouble. For running the MGP in limiter mode, use 100 - 80 - 100. Seems he reads the throttle curve even in limiter mode.
As to how govs versus limiters work, it doesn't matter whether you are just looking for over-speed or over- and under- speed. It does matter how you use the info. But there is no reason that a gov should not perform as well or better than a limiter. Only the limitations of the firmware and the designer cause that to happen. Assuming a reasonably fast processor for the work.
Terry
Old 11-09-2008, 12:25 PM   #18 (permalink)
Team Taco VP
Where? I forget where Aerospire is located?
Agreed... but up until now trying many govs and never really using a rev limiter until the AR7100, the Rev limiter has worked better than any gov I have used, UP until using this multigov... I am going to have to try limiter mode on the MGP just for grins...
FYI the 65 low point for the V is relative to the heli setup too.. The center throttle mark is not always 1/2 power depending on the engine, pipe, tuning, etc! So I bet the 65 he is saying is using OS 50 hyper? For instance with the Align gov 65-70 works best on a 600 OS 50... On the 700 you need 80 for YS but about 70 for OS. On my 600 with the MPG I have 70 and it seems fine and probably close enough to 65. Haven't tried the MPG on a 90 with a YS yet.
Also I bet what pipe you use and tuning of it will effect power / RPM at specific carb locations so 65% on one might not be the same on another.
Anyway all I am saying is plugging in 65 for every heli is probably a good starting point but you might have to tweak depending on setup.
Bob
Old 11-12-2008, 12:42 PM   #19 (permalink)
Quick check for a nitro newbie:
Mixture control turns needle valve left when hot, right when cold. Correct? I used a blow dryer on the sensor and the servo turned the valve left (richer mixture).
rubbersoul is offline        Reply With Quote Quick reply to this message
Old 11-12-2008, 12:49 PM   #20 (permalink)
Team Taco VP
Well yes and no... If the arm attached to the needle valve is pointing up then it would be one way. Pointed down would be a different way! So dont look at which way the arm goes.
Looking directly at the needle valve, leaning the mixture you turn the needle valve clockwise. To richen mixture you turn it counter clockwise.
Bob
