Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Like Tree2Likes
Old 04-23-2016, 02:09 PM   #21 (permalink)
Just one more important thing I forgot to mention:
please de-activate the switch in the TX in case the retracts electronics are installed when using the fixed landing gear as suggested in my former message!
Accidental activation of the retract mechanism with the fixed landing gear in place will destroy the motor as these will clash.
Alternatively make an appropriate cut out in the front leg of the right landing strut!
Regards,
Belgo
belgoheli is online now        Reply With Quote Quick reply to this message
Old 04-23-2016, 11:39 PM   #22 (permalink)
CHC Benefactor
Thanks for that note to the unwary! Definitely might have missed that.
Old 04-24-2016, 12:14 AM   #23 (permalink)
Regards,
Belgo
no need to cut into the leg , just remove the mounting bracket with the links connected to it . this way you have no problem if you accidentally hit the switch .
Fasster is offline        Reply With Quote Quick reply to this message
Old 04-24-2016, 12:58 AM   #24 (permalink)
Correct, that is also a good solution!
Belgo
Old 05-08-2016, 10:10 AM   #25 (permalink)
An other nice view for the electronic (thanks wlombard)
Old 05-08-2016, 11:53 AM   #26 (permalink)
I hope this helps others..damn the space is very limited!
William Blake Team Kontronik
TDR1, Banshee 850 # 22
Diabolo 700
wblombard is offline        Reply With Quote Quick reply to this message
Old 05-09-2016, 06:07 AM   #27 (permalink)
I was having trouble with my optiguard fitting no matter how I placed it. Would give me trouble installing battery tray. So I separated the batterey from the board, and installed the board with double sided clear tape to underside of lipo tray. also gave easier access to the swith to power down the unit without haveing to remove lipo tray.
Rick,
Team pilot ,
EGODRIFT, KST, Helidirect, Lynx/Oxy
crickr1 is offline        Reply With Quote Quick reply to this message
Old 05-09-2016, 06:37 AM   #28 (permalink)
The position as per my pictures the battery tray seems to fit just fine...a tiny amount of pressure is added and some patience to ensure all connection point are in place. Your option is definitely easier with regards to switching off the unit.
Diabolo 700
Old 05-09-2016, 07:32 AM   #29 (permalink)
May be the way my series lead is routed to connect batteries. It runs behind the tray so if I have it in certain position tray slides on or hangs up.
But it definitely makes switching on/off alot easier
Rick,
Team pilot ,
Old 05-09-2016, 07:35 AM   #30 (permalink)
crickr1, if you have time a picture would be nice.
I am trying to make this thread a fast visual of different configurations.
Old 05-09-2016, 09:41 AM   #31 (permalink)
I know it is a tight fit, but this is what I did:
I moved the back plate 2 mm to the front to provide enough clearance.
(obviuosly this takes some grinding of the slots and reaming of the slotted holes....)
I also glued some reinforcement to the front part of the tray (top and below).
Name:	L1000825 - Copy.jpg
Old 05-09-2016, 02:16 PM   #32 (permalink)
Couple pics, I also had to replace batt from optiguard used this one.did try fitting stock unit first before I split. Overall I think a very convenient solution. Easy access to switch, and little more space.
ID:	651422   Click image for larger version
Escornaboi likes this.
Rick,
Team pilot ,
Old 05-25-2016, 09:57 AM   #33 (permalink)
edit
Regards Daniel
dude25 is offline        Reply With Quote Quick reply to this message
Old 05-26-2016, 06:16 PM   #34 (permalink)
Here are a few more that I have seen:
ID:	654067   Click image for larger version
ID:	654068   Click image for larger version
Old 05-26-2016, 06:17 PM   #35 (permalink)
I just love that one although it is not related to electronic and wiring.
Old 05-26-2016, 06:22 PM   #36 (permalink)
An other nice pretty clean set up:
Name:	Screen Shot 2016-05-26 at 7.19.30 PM.jpg
ID:	654071   Click image for larger version
Name:	Screen Shot 2016-05-26 at 7.20.28 PM.jpg
Old 05-30-2016, 02:44 AM   #37 (permalink)
this is mine! no space left for anything
Regards Daniel
Old 05-30-2016, 09:31 AM   #38 (permalink)
Thanks for sharing
I had never heard of the Hitec PAD. I wonder if other manufacturers of servos need a similar device but are not telling.
Old 05-30-2016, 10:33 AM   #39 (permalink)
CHC Benefactor
Good catch. I wonder what it consists of? There is using a cap which it doesn't look big enough to be doing and the inline R2 protection device which distributes power to the servos that I know of.
Old 05-31-2016, 11:09 PM   #40 (permalink)
Has anyone incorporated the inline I/U sensor from Mikado? Or is everyone with VControl waiting for the direct Kontronik/Mikado integration coming later this summer?
Heinseleit TDR-2 w/ Pyro 800-48/Futaba/Kosmik & NEO
DIABOLO 700 w/ XTS/Torq/Kosmik & NEO
Kraken w/ XTS/X8/Kosmik & NEO
Goblin 500 Sport w/ Xnova/BK/Jive & NEO (rebuilt)
dominoedge is offline        Reply With Quote Quick reply to this message
