KDS Chase 360 KDS Chase 360 Discussion |
05-07-2017, 05:50 PM | #1 (permalink) |
chase update
Well still working on the chase .....
Problems founds 1) boom its just make to thin 2) swash well this is a hit and miss with kits ( mine had a tight spot that just couldn't be fixed 3) bushing // belt gear on the main shaft this is out of spec ... one or the other is wrong... bushing should be made larger on the gear side to remove slop 4) Head this is hit or miss as well ... mine is out over 1mm Please post here the problems you had with your kit.. Maybe we can get changes made ........
KDS Agile 6.4 Proto-Type 750MX 12s with an Ikon / KDS Agile 7.2 / Tarot-Align 600CF-FBL Robird G31 12S / The First X3-385 FROM AUTO-CAD to DIRT NAP in 10 SECONDS ! |
05-08-2017, 03:03 PM | #2 (permalink) |
Tail drive gear not tight on the mainshaft so it pivots a bit around the jezusbolt. Solved it by using bearing retainer.
Lots if tail vibe problems. Solved with a thicker cf boom, new tail grip hub and quality cf tailblades. Rest was all ok. |
