Go Back   HeliFreak > R/C Electronics Support > EZNOV
EZNOV EZNOV Support Forum
Old 07-26-2016, 03:31 AM   #1 (permalink)
Default Gonna give up this FBL
Bought it few months, never flew happy and can never setup the governor, everything I read has already done, 50% spool up read 2253hz, setup throttle according to it, fly , on the mid air, RPM drop to a non-flyable RPM, almost crash, never gonna use it again if can't use governor, don't know others happy with it wad how to get happy
Bygone is Bygone
unun is offline        Reply With Quote Quick reply to this message
Old 07-26-2016, 07:28 AM   #2 (permalink)
Mine is working fine.
But because of the not existing manual / support, I beliefe that many (possible) users regret or don't buy it at all. Good hard / software simply isn't enough...
Airagitator is offline        Reply With Quote Quick reply to this message
Old 07-26-2016, 10:55 AM   #3 (permalink)
Can't agree more, and I really don't like as I have to make the spool up then use kind of equation to calculate the head speed, why don't just enter the pole number and input you HS, I think it's easier to look for how many poles your motor are then to calculate you HS
Bygone is Bygone
Old 07-26-2016, 11:34 AM   #4 (permalink)
Hm... I like the gov because its really a gov-store. You can adjust your HS between 50 and 90% via TX.
When you type in a fixed Head-RPM, you can't adjust...
Old 07-26-2016, 11:48 PM   #5 (permalink)
I know, but I can't ever make it right, I really want to use its governor so do all my other FBLs, I follow the instructions , turn all governor off , set correct end point, then reset the gov store value in the software, with blades on, I spool up at 50% 0 pitch, get the number 2253 for my oxy 3, as per the formula, I set my throttle like 75 79 83, turn governor back on, go and fly, for the initial spool up, it sounds normal, then I put the little beast to the air, at about 5m height, the rpm drops to sounds like under 2000rpm, and it was a non flying RPM for the OXY, then I push the stick up to drop as low as I can, no damage, what am I missing?
Bygone is Bygone
Old 07-27-2016, 04:24 AM   #6 (permalink)
Hm... you have the last software version?
Gov is definitely active?
Old 07-28-2016, 05:59 AM   #7 (permalink)
I always check for new version, and it's always 1.0.21, gov was active since the green light was blinking rapidly
Bygone is Bygone
Old 08-04-2016, 05:25 AM   #8 (permalink)
I've given up on mine to. I'm pretty sure the throttle output channel on mine is faulty. I might keep it for a plane, but I'll never risk it on another heli. Its a shame because it did fly beautifully when it wasn't playing up.
I could probably mix the throttle to a spare channel and run the esc from the RX instead of the neuron. I think the last few channels on my receivers still work like normal when cppm is active on CH1. I don't think I could be bothered trying though.
The_crack_fox is offline        Reply With Quote Quick reply to this message
Old 08-11-2016, 02:50 PM   #9 (permalink)
No need to mix anything, you can simply plug in the esc in the rx throttle channel and disable the neuron governor
Sent from my Wileyfox Swift using Tapatalk
GAUI X5 with Eznov Neuron and T10J
DannyvG is offline        Reply With Quote Quick reply to this message
Old 08-11-2016, 06:23 PM   #10 (permalink)
The minima receiver doesn't have a throttle output channel when cppm mode is active.
Old 08-13-2016, 09:08 PM   #11 (permalink)
Yes, that's what I did now, disable the GOV in neuron, and use the HW GOV instead but it's not what I wanted, I use FBL gov on all my helis and all were great but neuron, It flies great though but I can't benefit from it's GOV
Bygone is Bygone
Old 11-14-2016, 04:44 AM   #12 (permalink)
Its been months now, and after getting nothing but a couple of emails asking what firmware I had, I posted mine back to france. I didn't want it in the house anymore, tempting me to risk another heli.
Ironically, I bought a KBar to confirm the gyro was the cause of my issues. Turns out Kbars are great and now I have 3 of them. No need for service if one plays up (which they haven't), they're cheap enough to throw away.
Old 11-22-2016, 04:59 AM   #13 (permalink)
I can't agree more, as new firmware didn't out for ages, and lack of support in the forum, I swipe to the iKon again and it flies great, really don't want the neuron anymore, and the only one I had, I regret I'd bought it
Bygone is Bygone
Old 11-23-2016, 02:14 PM   #14 (permalink)
Any off you guys want to sell a neuron?
Pm me
Jamie
via LGv10
James (Jamie) Deavers
MD6_Spartan Vortex_Futaba14sgh_AMA 1083246_Citizen 676
JGDeavers is offline        Reply With Quote Quick reply to this message
Old 11-24-2016, 08:18 AM   #15 (permalink)
Fortunately, it had a recycle usage, I'd de-case it and put it into the 180CFX, a micro heli which wasn't need the govenor
Bygone is Bygone
Old 11-24-2016, 09:33 AM   #16 (permalink)
Hello totally agree, I already shot two helis to the floor a goblin 500 and 380 goblin and to answer from France and a month goes and do not respond disastrous after-sales service the two neurons I have remove them and you're right the Kbar work well. The only thing missing is rescue.
gromble is offline        Reply With Quote Quick reply to this message
