12-14-2016, 02:57 AM | #21 (permalink) |
When mine did that I noticed a blade grip was craked to the screw hole. I also had a very slightly bent feather spindle. I'd do a inspection/ service before you go Friday
Oxy 2 FE, 180cfx spartan lynx pro tail,130x stock, Goosky S1 x 2 , mcpx stock x2, mcpx bl mod, nano cpx dbl bl, nano cpx wild bl, nano cps, DX8. For fpv Phantom 3 pro. |
12-14-2016, 02:11 PM | #22 (permalink) |
Thanks I will check that out later on
it has had some abuse
C Blade 230S, Nano cpx, nano qx/3dqx/fpv, 200qx MCPX V2, Align Trex 250, 250 DFCplus, Trex 450 plus,Trex 500, JR Forza 450, and more I retired |
12-16-2016, 08:02 AM | #23 (permalink) |
Crashed it into 14 walls and my wifes head
12-16-2016, 06:42 PM | #24 (permalink) |
4 packs in the front yard. I actually did an inverted circuit. Lots of fun
I just need more power. Or better collective management Sent from my Pixel using Tapatalk |
12-16-2016, 08:59 PM | #25 (permalink) |
Ran a few packs before work trying to remember how to fly. 6 yrs off makes you forget!
Ed Always Something New! ------------------------------------------------------------------------------------ T-Rex 500ESP, GY401/9257, 6s 3000mAh 100% Flat TC X9303; Nano CPS |
12-18-2016, 08:48 PM | #26 (permalink) |
I got mine moved to my newly refurbished Dx6i (thanks Horizon!) and spent many packs getting comfortable going nose in doing figure 8s. Once I get this solid I will start moving into Red mode!
12-19-2016, 12:29 AM | #27 (permalink) |
Striped mine down. New frame new lynx bearings. Replaced one cracked blade grip. Flys great again.
12-19-2016, 11:02 AM | #28 (permalink) |
I have had the weekend to test this new motor and so far so good. The old motor i suspect was killing my fight times as it was getting hot and i was only good for about 1.5 min. Now with the brushless I am up to 3 min and I still haven't hit low voltage cut off ( which I try to avoid hitting for the battery sake. The soldering I had to do I took from Heli_passion who is a member on this site. I will place the picture he put up since he takes better pictures. The only thing I did differently is I have mine soldered to the white wire since I used the plug off of the stock motor. The one he used I think was off the Kit that he cut off. I still think I am missing out of some power but it certainly climbs better now than the stock motor.
12-19-2016, 02:23 PM | #29 (permalink) | |
12-19-2016, 03:41 PM | #30 (permalink) |
I flew the one morning when it was 20F and my flight times were on a bit over a minute. The cold seems kill those little batteries.
12-20-2016, 01:29 AM | #31 (permalink) | |
Enviado desde mi Redmi 3 mediante Tapatalk |
12-20-2016, 12:50 PM | #32 (permalink) | |
12-20-2016, 01:00 PM | #33 (permalink) |
I have seen in other threads that the ESC signal should be connected to a small resistor on the main board. It is working properly using the signal of the main motor (plug and play method)?
12-20-2016, 08:10 PM | #34 (permalink) |
Flew outdoor circuits (yah!) and hovered for the first time in Red mode. Wow that is hard!
12-21-2016, 12:16 AM | #35 (permalink) |
Sorry for the triple post, communication problems...
12-22-2016, 07:32 AM | #36 (permalink) |
Flew 2 packs flew my new one
and noticed that when I piro in mode 0 (blue light) it works great, any other mode it seems to shake like a wet dog. after putting up with this a few times it seemed to get better then worse, main shaft replaced if felt soft, feathering shaft seems straight but maybe i'll replace it for kicks. .frustrating, but I got my original one working thanks to parts from a HF member and it works notmally
12-22-2016, 12:51 PM | #37 (permalink) |
There are other ways to solder it to the board but I didn't have a small enough soldering iron nor did I trust my shaky hands. I just cut the plug off of the stock motor and soldered to that for my signal wire. This method to me results in a single speed motor. It no longer seems to vary, but I really don't care as I always fly IU anyway which is single speed anyway.
12-23-2016, 12:16 AM | #38 (permalink) | |
12-27-2016, 10:56 AM | #39 (permalink) |
Ripped a servo plug off the main board simply trying to remove the servo didn't feel like I was rough or hard on it. Had took one off already and then this...
